Question about HP XW6000 PC Desktop
I want to know all files being read/used at any time
I would like to get a complete list of files on a hard drive AND know which are opened and when and by which program.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
The follwing command will get you a complete list of files in your hard drive.
To list every file on your hard drive, you could pull out some combinations with DIR /S to show files in all subfolders, or you can just type in CHKDSK /V.
Doing so will show every file on your hard disk, and at the end, will show you a report of the total disk space, total free space, and more.
Save this report to a text file for later viewing. Type in
CHKDSK /V > DISKREPORT.TXT
Second :
This can be done by th following software which can be downloaded from here
http://www.refog.com/free-keylogger/key-logger.html
Good Luck.
Live, Love, Laugh.
Posted on May 11, 2008
My autocad dwg files have been corrupted
Displays a list of all drawing files that were open at the time of a program or system failure. You can preview and open each drawing or backup file to choose which one should be saved as the primary DWG file. After a program or system failure, the Drawing Recovery Manager opens the next time you start the application. Drawing Recovery Manager displays a list of all drawing files that were open. The System Variable RECOVERYMODE controls whether drawing recovery information is recorded after a system failure and whether to show the Drawing Recovery Manager or not.
If you want to help yourself, Autodesk and other AutoCAD users make sure to send in any errors to Autodesk when you see the Customer Error Report dialog box (CER).
Finally a solution that sometimes helps if AutoCAD cannot fix the problem is to try to fix the drawing in another program that can open and save DWG files. The more users having the similar problem the better chance it will be fixed in a service pack or future version. Eventually you might
get DWG Restore Toolbox saying the problem is fixed.
from website: http://www.dwg.restoretools.com/
Jun 20, 2015 | Autodesk AutoCAD 2010
Need command prompt for Acer Aspire
The Windows Backup and Restore feature allows you to save files and system images to external backup devices such as hard drives and flash drives. However, backing up files become problematic if the directory your backing up files from isn't configured properly, or if you're having issues with the devices you're backing files to. There are ways to solve or work around backup problems quickly and safely.
Hard Drive b> A backup will not complete if the files you're backing up exceed the amount of space left on the external hard drive. If you're backing up large system files, Microsoft recommends saving the backup to an external hard drive that can hold at least 200 GB. If you're running out of space, you must delete content to create space for others or use another hard drive. Error Codes In some cases, Windows displays the following error codes when it's unable to complete a backup: "0x80070001 (Invalid Function)" or "0x81000037: Windows Backup failed while trying to read from the shadow copy on one of the volumes being backed up." These error messages usually appear if Windows is unable to backup a specific library or if you opt out of adjusting your backup settings and settle for the default settings in the Windows Backup and Restore Feature. Reparse Point b> If you're unable to backup a specific library and run into error code messages, removing the reparse point allows you to complete the backup. A reparse point is a file that contains information about the user on a computer. If it doesn't point to a location that contains some of the data you want to backup, error messages appear when you try to back up your files. Type "CMD" in the Start Search box to open the Command Prompt. In the Command Prompt, typing "DIR /AL /S" and pressing Enter lists the reparse points. Each entry says "JUNCTION," which also means reparse point. The entries also tell you the location of the reparse points in Windows Explorer. If you locate a specific reparse point in Windows Explorer, delete its mounted volume from the device's Properties. Once deleted, you should be able to back up your files. Discs b> If you're backing up files to a disc, you'll run into problems if the discs are non-rewritable and already contain data, or if they are severely scratched or damaged. Non-rewritable discs can only be used once, while rewritable discs can be used to read and write data several times. If the CD or DVD you're using is severely scratched, the optical disc drive spins harder than usual in an attempt to read it. If it's incapable of reading the disc, the backup feature may freeze or display an error.
Windows backup or restore errors 0x80070001, 0x81000037, or 0x80070003
http://support.microsoft.com/kb/973455 - workaroundissue12
Apr 20, 2013 | Computers & Internet
Imaging a hard drive
how much data do you want to back up ? how big is it will it fit on a usb drive
use the copy and paste method to back up your data
click start all programs accessories open windows explorer navigate to your data / files right click on the music right copy navigate back to the destination drive right click select paste or hold the
mouse cursor on the music files drag them to folder
then drop them
if you need more help with this post a reply
hope this helps
Aug 22, 2012 | Computers & Internet
How to transfer my life studio from one computer to another
Connect the external hard drive to the host computer.
This connection is most commonly made with a USB-style connector.
However, eSATA connectors are becoming more prevalent in the general computing market.
Plug the external hard drive into an electrical power source.
Navigate to the external hard drive listing under the "My Computer" window.
This is opened by double-clicking the "Computer" or "My Computer" desktop icon.
Double-click the external hard drive drive icon listing and navigate to the files to be copied using the provided navigation window.
Right-click the files to be transferred and select the "Copy" heading from the context menu.
Navigate to the destination folder on the host computers hard drive using the same navigation window.
Right-click within the folder and select the "Paste" option.
This begins the process of transferring the files to the computers hard drive.
This process takes several minutes to several hours, depending on the size of the files and the speeds of the hard drives.
A progress bar will appear to keep the user informed of the process completion status.
hope this helps
Jul 16, 2012 | Hitachi LifeStudio HLSDBUB10001BBB 1 TB...
How do you clean a laptop ram?
Hi there loverboyjero! :) here are the steps on how to clean a laptop ram :)
1.Log onto your laptop and click "Start." Go to the "Control Panel." Choose "Performance Information and Tools." The window lists data information such as calculations per second and memory operations per second. On the left is a list of tools for disk cleanup. The tools in this window can also be accessed in the "System Tools" folder inside "Accessories," which is also located at the "Start" menu.
2.Click on "Advanced tools." Choose "Open Disk Defragmenter." The window will list the last time the laptop was defragmented. If the "Last run" was over a month ago, click "Defragment now." Defragmenting your hard drive will rearrange files so that the laptop can better access them. Defragmenting may take an hour or longer, depending on the last time it was done.
3.Click back to return to "Performance Information and Tools." Click "Open Disk Cleanup." The window will prompt you to select a drive to cleanup. Select "C:" and if you have more than one hard drive, an external or a partitioned hard drive, do a disk cleanup of these drives as well. Wait for Disk Cleanup to calculate how much space you will be able to free up. This may take a few minutes to complete.
4.Select the items that you want to delete. These files will be permanently deleted. Delete "Temporary Internet Files," "Downloaded Program Files," and the "Recycle Bin." You may have an option that says "Hibernation File Cleaner." Removing this file will disable hibernation on your laptop. Do not remove this file if you use hibernation. Click "OK," then "Delete Files.
Sep 30, 2011 | Computers & Internet
I have a SimpleTech Pininfarina 500GB external hard drive. I used it at work on my PC. Now it's home and I want to restore some files using my Macbook Pro computer. How can I restore and access some...
First connect harddrive to mac with usb or firewire cable. Then go to Open a new finder window by clicking on the icon in the Dock. Click on the name of the external hard drive under the "Devices" list on the left side of the Finder window. This will open a window that displays all of the content currently on the external hard drive.
Drag and drop files from your external hard drive into computer. A progress bar will pop up on the screen. When the copying process is complete, the data has been successfully transferred to the computer. Let me know if you need further assistance. Thanks for using FixYa.
Jun 13, 2011 | Computers & Internet
Dropped my verbatim smartdisk portable hard drive. I'm able to open the disk but when I open the file, it's all gone. what do i do?
What you have listed isn't a hard drive, It's a flash drive and it is practically indestructible by a common drop, If you can plug the drive in and access it then the drive is working correctly. If it does not say something like " Insert disk in drive E: " when you try and open it once again chances are the drive is working fine. The last time you connected it previously to dropping it you might of removed the drive before it was done. Some times Windows does not write the files right away if the computer is also busy, this can cause a delayed write failure to occur when you remove the disk before it has written the file down. If you plug it in and the computer does not see it or you get the stated message I wrote above then it's broken physically. If you can still write new files and read those then chances are you missed a write window.
May 13, 2010 | Verbatim VER95327 USB Hard Drive
A window appears saying "unable to scan. Be sure there is enough space in the destination disk."
Your hard drive may be getting full...
Or the account (user name) you are using on the computer does not have enough "rights" to create the output file.
Assuming it is Drive C:
Open [My Computer]
Right-click Drive C: (one time)
and select "Properties"
In the [General] tab, locate and click on [Disk Cleanup]
The system will harmlessly "scan" your hard drive to try to free up space. It is not deleting or compressing anything.
When the scan is complete, a list will appear, place a check on:
Tempoary files, Temporary Internet Files,
(do not "compress" any files)
and click [OK]
Try your scan again.
This is a temporary fix. You need more hard disk space.
Sep 28, 2009 | Canon CanoScan LiDE 600F Flatbed Scanner
320GB seagate freeagent, cant open some of the files.
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Sep 17, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Firelite Hard drive read as "local disk"
1)Run CHKDSK ON that disc
2)Run antivirus to scan disc
Dec 27, 2007 | FireLite (USBFLB80) Hard Drive
HP XW6000 PC Desktop Logo
154 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
