Question about Ricoh Aficio 1013F Copier
Richo 1013f copier problems-grey lines on copies
  • 1,110 Answers
Most often this problem is coming fro the PCU or Photoconductor Unit. If you open the right side door just look for the long greenish colored cylinder. It should be clean. If you see a toner film or more specifically the same "lines" on the surface of the drum that you see on the copies then you will know. If this is the case you will need a new PCU. Installation is a piece of cake.
Here is a link with pictures, part numbers etc.
http://www.precisionroller.com/search.php?q=ricoh+1013+drum
Good Luck and Thank You for using Fixya.
Posted on Sep 03, 2010
The copies are full of lines since I changed the ink bottle!
How about running a Can you reach an alcohol pad into document feeder to clean off
Mar 28, 2014 | Ricoh Aficio 1013F Copier
How can i default ricoh 1013f and I needed the pasword
follow this steps press yellow cancel and 107 and hold on red cancel 5 seconds and press1 copy and 4 # 810 and press 1 simultaneously with photo press yo will see reset accepted and close machine and opened
Apr 18, 2011 | Ricoh Aficio 1013F Copier
Please, I need help with Richo MP7500 with error
SC534 D Fan error 5: duplex exhaust fan
The lock signal remained HIGH for 5 sec.
while the fan that draws air out of the duplex
unit was operating.
• Motor overload due to
obstacle interfering with
operation of the fan
• Fan harness loose,
disconnected, defective
• Fan defective
Jul 28, 2010 | Ricoh Aficio 1013F Copier
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to Ricoh-USA.com to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
Bad copies/grey lines
hi do u have cleaned the scanner miror and the coppy glass may be coz of that u having that grey line
thanks
May 11, 2010 | Canon imageCLASS D761 Copier
My Ricoh Aficio 1013f has 16,000 copies on it. It
Ask the service agent, what the maintance cycle of the model is. Sound like it needs a periodic service.
This being the drum and some rollers. this will resolve the squeak as well
Good Luck
Mar 03, 2010 | Ricoh Aficio 1013F Copier
How to set factory default at Ricoh Aficio 1013F
Hello sir;You may go to SP mode to print out default setting list;
Press "clear mode" key then enter107 then press and hold down "clear/stop" key, touch on screen for "copy" then press 5992 hit enter, touch 0 to print out the standard setting list, turn off the copier when you finish.
Jan 04, 2010 | Ricoh Aficio 1013F Copier
Large broad grey lines on all photocopies
Hello sir; The problem you have , you do need a drum cleaning blade to replace and also image transfer roller need to clean with alcohal.
May 26, 2009 | Ricoh Aficio 1013F Copier
Ricoh 1018
possibly the process unit and if you look in through the right hand door you can see the drum ...or it could come from a worn out upper heat roller.
all the best
Apr 05, 2008 | Ricoh Aficio 1013F Copier
143 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
