Question about Montgomery Ward Refrigerators
I have a Wards upright freezer & was wondering what year it was manufactured? It is a model # FFT-4649-00B 16.1 cu ft
fridgetech
  • 473 Answers
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Posted on Oct 12, 2007
SOURCE: WHIRLPOOL 25.3 CU.FT MODEL ED5FHEXNT00
Possibly freezer drain blocked causing ice build-up behind back freezer wall. This internal wall should be accessible by removing screws.Check fan motor in that area is working and also check that all door seals have no cracks or tears. This can cause ice build-up and motor to run longer than normally. benham's suggestion another possibility.Naturally have power off when dismantling anything.
Posted on Jan 11, 2008
  • 42 Answers
SOURCE: Our refigerator is not cooling .
Hello Laura,
If you look at the rear wall inside the freezer compartment down low and find a bunch of frost on that wall, you have an automatic defrost system failure. The most likely part that has failed is the defrost thermostat. It is located on the top of the freezer coil, clipped onto a piece of tubing. It will have 2 wires coming out of it and it is about the diameter of a quarter and about 3/4" tall. To test this part you would need a test meter and enough skill to check if the contacts are closed when the thermostat is frozen withing the specifications stated on the thermostat. I believe yours would close at 25 degrees F and opens at 47 degrees F. Part # 5303918214
I hope this helps you. supertechks
Posted on Mar 28, 2008
Master_Tech
  • 770 Answers
SOURCE: Kenmore upright freezer
Where do you see the water coming from ?
Posted on Jul 21, 2008
SOURCE: Haier 1.7 CU Ft. Refrigerator - what is warranty
1 year parts and labor
Posted on Aug 17, 2008
16 years old. cold inside, but not freezing food. making small rattling noise
check the RepairClinic site, as they indicate what may be wrong when there is a 'rattling' noise in a freezer
Jan 13, 2016 | Kenmore Freezer 20.3 cu. ft. Frost Free...
What is the cu ft for frigidaire upright freezer mfu21m3gw1
Thank you for your post, friend!
I see you would like to know the cubic footage of your Frigidaire freezer. Based off the model number you have provided it appears that you have a 21 cubic foot freezer. Hopefully this information is helpful. -Matt
Feb 20, 2015 | Frigidaire Freezers
Why is the top shelf of whirlpool upright freezer not freezing?
Just had this issue. Freezer is packed usually & suspected airflow. Emptied bottom 2 shelves & vent strip was solid frost. Bottom 2 shelves were filled w/ solid roasts & other solid large items. Used blowdryer & currently waiting to see if it begins freezing top shelf.
Jul 03, 2014 | Whirlpool EV160NZTQ Upright Freezer 16 cu...
What is the year of manufactured mfu21m3gw1
January 2001 and july 2003 is when it was sold between. Some new old stock is still getting around. Shocking model for faults . But most were easy fix
Apr 28, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
Kenmore upright freezer, about 16 cu ft. Buildup
symptoms you are describing are faulty door seals, try putting a thin piece of paper between door and frame to make sure doors are sealing,also when did you do a full manual defrost??(once a year even with auto defrost)
Apr 07, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
Freezxer dosn't work
Is the fan inside the freezer working? If the fan isn't working the freezer will never get ice cold.
Nov 23, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Neff 3.8 cu ft freezer.
if it works on superfreeze then the stat is faulty. all that supoerfreeze does is to bypass the stat. easy job
Sep 10, 2008 | Neff 3.80 cu. ft. / 108 liter Upright...
Jul 21, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Refrigerators Logo
569 people viewed this question
Top Montgomery Ward Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Montgomery Ward Refrigerator Expert? Answer questions, earn points and help others
