Question about Bosch Dishwashers
Our bosch dishwasher stops at 1 minute on screen and never advances Since we believe it is under 5 years and the electronic panel should be covered, how should we proceed Model SHE44C06UC/40 Serial FD8608 01614
You need a new microprocessor. Same thing happened to me. Normal cycle runs down to one minute and stops there, running, for maybe another hour or more. Then, when it finally ends, the dishes are not clean or dry. Get the microprocessor replaced. It is Chinese junk. It is an easy fix, but the replacement will last only four or five years.
Posted on Feb 05, 2011
Is there a Reset button for Bosch shu53 dishwasher?
Press and hold Scrub Wash and Delicate/Econo buttons at the same time for three seconds. This will advance the unit to "CL" (clean), meaning the washing cycle is finished, and will drain the water. Do this if your unit gets stuck on 1 minute left, which is common with this model. (I am told that the control panel melts over time, and that the unit is not designed to last more than 10 years.)
Jun 22, 2014 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch dishwasher beeping during cycle
Take the front kick panel off and see if anything under the machine is wet.
Jan 06, 2014 | Bosch Evolution 800 SHE58C02UC 24 in....
My Bosch is only a few months old and it won't drain the water.The filter is fine. It's a shea43p16uc60.
Your bosch washer should still be under warranty:
  • Limited warranty, entire appliance, parts and labor (1 year)
  • Limited warranty for non-electronic components; parts only (1st to 2nd year)
  • Limited warranty for control board (microprocessor); parts only (1st to 2nd year)
  • Limited warranty for motor or any component of the motor (1st year to 10th year)
May 19, 2011 | Bosch SHE43P16UC Builtin Dishwasher
Hi We have a 1 yr old Bosch dishwasher SGS45C02GB-06. It's stopped working for the second time in a year. It stopped mid-cycle and the water is not draining away or being pumped away; although you can...
Did you install the high-loop for the drain hose? If not, you need to pull out the dishwasher and make sure that the hose is not lying below the pump at the bottom of the dishwasher. This will usually fix this problem.
Jan 05, 2011 | Bosch Dishwashers
When I press the start button, Bosch dishwasher (model SHY56A 05UC) just keep running the motor pumping the water out of dishwasher, irrespective of: 1) the wash cycle it is on, 2) whether the door is...
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Nov 26, 2010 | Bosch SHY56A02 / SHY56A06 Built-in...
My dishwasher is not draining
have you checked your float valve and float relay switch
Oct 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water left in bottom of Bosch dishwasher
One possible solution to your problem could be as follows... Could have been little regular soap or something put in that made it suds up causing it not to drain. Pouring vegetable oil into the dish washer tub will remove the suds. After running vegetable oil for about 5 minutes, pour 2 cups of vinegar in to the tub and run it on the hottest longest cycle with no dishes in it. This will clean the residue out and what ever "gunk" may be in the internal parts. Use Only powder detergent. No gel and No tabs. These 2 cause a build-up over a period of time of use and reduce the performance of your machine. This should take care of your problem.
Apr 10, 2009 | Bosch SHV4803 Dishwasher
Won't turn on
The door switch is definitely not the problem if the indicator lights are not coming on. These lights are supposed to come on when the door is open.
The problem is 1 of 3 things:
1) No power to outlet that DW is plugged into;
2) Bad connection where power cord is connected to dishwasher (see very bottom front, under kick panel)
3) Some problem internal to the DW (eg., bad switch, shorted wire, etc., )
Our SHX46A is definitely having problem 3, but Bosch's manual gives zero help. So, off to find more info online or, lastly, to call Bosch repair person. Sigh.
Jun 13, 2007 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Bosch SHU5316
Sounds like the control module is out -- cost about $100 (I am on my third). I got a "lifetime" warranty when buying my second one. If you are handy, you can replace it yourself. You can call Bosch to confirm this (I did). It mounts inside the door.
Apr 15, 2007 | Bosch 23 in. SHU5302UC Built-in Dishwasher
Dishwashers Logo
520 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
