Question about HP ScanJet 2400 Flatbed Scanner
Vertical lines Hi, While scanning image, the light that moves fron one end to another stops inbetween and in the preview we don't see the image perfectly ,instead we see colorfull vertical lines. Please suggest me an easy solution. Thanx!
    Problem Solver:
  • 6 Answers
The light sensor rod must be probably jammed due to friction . Do clean the iron rod with a soft cotton cloth. and try again.
Posted on May 13, 2008
My Epson Perfection 1650 Photo scanner keeps producing scans that have a 3-4 inch bright panel vertically down the middle. The image is visible, but the outer thirds are quite darker than the middle...
Make sure all the scanning settings are correct first then set everything first before you preview image then hit scan.
make sure the size is correct drag the image on the prview screen make ths dotted lines frame your image then scan
remember you tell the machine what to do by setting it, if you dont the machine trys to do thevscan its self. Good luck, have fun
Feb 08, 2011 | Epson Perfection 1650 Photo Flatbed...
How do I scan with HP psc 1210
Answer is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&lc=en&dlc=en&cc=us&product=90764#N305
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 24, 2011 | HP PSC 1210 All-In-One InkJet Printer
My scanner copies have a vertical yellow streak covering half the page. What can I do to solve the problem ?
Lines or Banding Within the Image
If the scanner is generating lines or banding within the image during preview and/or scan, below is a list of possible solutions.
Horizontal Lines: If the lines run horizontally throughout the image, it is almost definitely interference of some kind. First thing to try is reverse the cable (Astra series only, except for 2400S), trying with and without termination as well. It could also be the SCSI card itself that is causing the interference. Try reseating it in a different slot, away from other cards. Try moving the scanner itself to another location, farther away from computer components such as monitors and CPUs. If none of that works, search for the file ?prescan.dib? on the hard disk and delete it, then try the scan again. If that still doesn?t work, follow the clean uninstall and safe mode install of our software. If these troubleshooting steps do not work, it could be a physical defect within the cable that?s generating extra interference, and the cable should be replaced. If the cable has been replaced already, it may be the UDS-IS11 itself generating the interference from being defective. Replace it.
Vertical Lines: If the lines run vertically throughout the image, it is probably a hardware problem, most likely with the scanner itself. However, follow the cable-reversing instructions above, remove the ?prescan.dib? file, and try the scan again. Often, if they are thin lines they are from dust within the optics. Open the case and blow out the dust with compressed air.
Nov 25, 2010 | Umax Astra 2100U Flatbed Scanner
A yellow vertical line on the copy, which now takes half the page.
What causes the lines in an image?
Hp scanjet G2710 scanner isnt scanning the whole document.the light only moves half way then stops
If you are scanning via software then the software could be looking for a smaller image. Check the preview and adjust the size as necessary.
Apr 30, 2009 | Office Equipment & Supplies
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
HP 5610 scanner won't save image
I just need to understand the exact issue. It sounds like you are able to successfully scan, see the preview of the scanned image, and you initially save it. Then, when you go to open the saved image, you don't see the image you scanned but rather a "line". You've saved the image in a number of different image formats, but there's no difference in the result. It saves the scanned image to the location you want to save it on your computer's hard drive (probably My Pictures if you're using a Windows operating system).
Not sure what you mean by a "line". Do you mean a vertical line, a horizontal line, a diagonal line or what? Also, is it just a solid black line on a white background? Is it the image you scanned compressed into a smaller vertical or horizontal space?
Have to tried scanning both text pages and graphic pages? There have been issues where a document with both text and pictures has been scanned but when the scanned image is viewed, only the text appears. The pictures don't make it. The description of this specific problem is at HP.com.
I take it you don't get any sort of error message associated with this problem. Unfortunately, I can't find your specific problem at HP.com beyond the link I posted in the above paragraph. If you can answer some of the questions I asked, it might help me provide a better solution.
Thanks.
Sep 25, 2008 | HP Officejet 5610 All-In-One InkJet...
Vertical Line on scan and copy
I would like you to exactly follow the steps in order for you to resolve your issue.
JUST DOUBLE CLICK HERE ==>> DOCUMENT
Please update me regarding the result.
Thank you so much.
adonscott
Jun 27, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Thick verticle line on copies and scans
Sounds like the issue is with the scanner bulb. May not be moving across or warming up to full capacity.
Make sure the scanner is plugged in directly to the wall and not into a surge protector or a power strip. If problem is still there and you are in warranty you will need to replace the unit. If OOW then you should call and see if you can repair or upgrade the unit at a discounted price. If you want to speak to someone in English tell them you want mac support - they are in Canada.
Jun 01, 2008 | HP OfficeJet 6310 All-in-One Printer...
HP ScanJet 2400 Flatbed Scanner Logo
198 people viewed this question
Seeker5211
Seeker5211
