Question about Vacuums
I have a broan central vac system need belt for cv315-b vac head cant seem to find one any idea where i can get 1 thanks
  • Anonymous Nov 30, 2008
    I an looking for a belt also
I believe that the Broan replacement part number for the belt for the CV-315 power head is a 9967-0585. available through a Broan/Nutone dealer.
Posted on Apr 21, 2009
I have a broan central vac 24 yrs old ,vac works if you turn sw on cannister,not by plugging hose att,is this a major problem,thanks
Broan 450 air-watt and 8.5 amp power unit. Covers 3,000 sq. one 30-ft. crush-proof hose with on/off switch, one 10-in. wide hard floor brush features swivel neck for easy maneuverability around furniture. My new home is just under 2000sf. Will this new unit have enough suction?? Just buy or don't??
Jan 22, 2013 | Broan-NuTone CV350 Central Vacuum
My Broan-NuTone central vac shuts off after I am vacuuming for a couple of minutes. I turn it off for about 10 minutes and start vacuuming again and it keeps shutting off. What is wrong with it? I...
Some of these units have had trouble with the motors and this is what causes them to shut off. NuTone has been pretty good about replacing them under warranty. 1-888-336-6151.
Aug 17, 2011 | Broan-NuTone VX475 Bagged Central System...
My BROAN CV-110 hose with the rug beater only works if I turn it on from the base unit. Shouldn't it turn on when I plug the hose into the wall recepticle? Do I need to replace the hardware at the end of...
In order to do this right you need to get in touch with the Broan Company. This could be difficult to do.You can get a VAC repair man that could answer you as well. They could even have parts for your machine.
Nov 05, 2017 | Vacuums
No suction
Use the guide at builtinvacuum.com/flowchrt.html to find the issue and solution. Most likely you need to test it without any filter and be sure the bottom of the unit is attached :) To get access to the motors you need to unbolt the very top sides.
Jul 28, 2010 | Broan-NuTone CV350 Performance Bagged...
Beater brush won't spin when on carpet
You need to change the belt. When it does that it means it is worn. You can get replacement belts for it here:
Central Vacuum Belts
or here is
Broan Central Vacuum Belts
Nov 04, 2009 | Broan-NuTone CV350 Performance Bagged...
Central vac will not turn off
You have a defective internal relay on the vac. Check for warranty coverage as this is a common occurrence on these big box store units.
If beyond warranty the relay should be a straight forward unit, miniature circuit board type plug in device. Find a Broan Nutone service center or take to vac pro shop for parts.
Nov 01, 2009 | Broan-NuTone VX475 Bagged Central System...
I have the same central vac and the same problem
I don't see a problem. here. Post details and I'l be glad to help ASAP
Oct 04, 2009 | Broan-NuTone VX475 Bagged Central System...
I have a Broan Nutone central vacuum. The power head seems to stall unless you lift up on the handle. I think I may need to change the belt but cannot find a place to purchase one to see if this is the...
If the power head is spinning when you lift up the handle then the head could be blocked with dirt. You may need to undo the floor head to see if the entire brush roll is clear as well as the main dirt channel/turbine wheel. Ensure that everything is clear before assuming it may be the belt that needs to be replaced.
You may well have to call or contact the main company who makes Broan Nutone models for them to send out / query the power head problem.
Apr 19, 2008 | Vacuums
Vacuums Logo
177 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
