Question about LG LHD459EL Dehumidifier
My dehumidifier will not run. If I turn it on, it runs for a few seconds, then shuts off and the "bucket full" light goes on, even though the bucket is empty. I had been using it with a hose in place instead of the bucket, and it worked fine for a year or more.
  • LG Master
  • 43,501 Answers
Here is a tip that explains what can be happening to make the dehumidifier show that the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
Posted on Sep 09, 2010
I have a FDL70S1 Dehumidifier. Unit runs for just a couple minutes and shuts off-blinking bucket full even though no water in bucket. Unit won't stay on
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
May 17, 2011 | Frigidaire FDL50R1 Dehumidifier
'bucket full' light on, but bucket empty
There is likely a switch operated by a float to turn that light on and turn off the compressor, sometimes manufactures use a rubber "O" ring on the float shaft and they can slip. take the cover off the pump and check the float or in some cases one of two floats are used. Once float turns the pump on and off and the second float shuts OFF the compressor and turns ON the full reservior light.
Jun 04, 2010 | Dehumidifiers
Unit only runs a few seconds and then shuts off
If the water reservior is empty then the float is stuck in the full position.
May 26, 2010 | Comfort-Aire BHD-651 Dehumidifier
Stopped running
water level sensor,problem by pass and test run unit if ok replace switch.
Apr 20, 2010 | LG LHD45EL Dehumidifier
Empty bucket light is on and dehumidifier will not run
The float switch for the condensate reservoir (bucket) is malfunctioning.
It's sending a false signal that the bucket is full.
Maybe just stuck and needs cleaning or it may have failed.
May 31, 2009 | Whirlpool AD65USL / AD65USM Dehumidifier
Shuts off-"full" light when it isn't
Hi, I'm not familiar with your model but there is usually a plastic rod sticking down from the "roof" of the place where the bucket goes, and this is pushed up by the floating part of the bucket.As the bucket gets full, the float pushes up on the rod which activates the microswitch to turn of the compressor.
With me so far? OK, it could be that the rod is stuck in the "up" position and needs to be pulled down so the microswitch can go to the normal working position.
There is likely to be another mechanism which prevents the compressor running when the bucket is absent, or maybe they are combined on your model. Check that little rod and find out if it moves as it should.
Hope this helps. If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Cheers, D.
Jul 11, 2008 | Maytag M7DH65B2A Dehumidifier
LG LHD459EL Dehumidifier Logo
655 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Michael Van Der...
Michael Van Der...
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
