Question about HP Pavilion F1703 17" LCD Monitor
Resolution Cant raise resolution above minimum
  • 42 Answers
Can you supply a little more info?
What monitor? make & model
What graphic's card? make and model
What PC?
What Operating system?
What res are you trying to get from?
In the mean time, things to check:
1. Graphic card driver is installed, and not just the "standard VGA" windows driver. (As this will give you this error)
2. The Graphics card is not conflicting with another device. (This you can find in Control Panel, System, Hardware devices.)
Posted on May 11, 2008
Can not get the right resolution on windows 10
http://www.tenforums.com/tutorials/4910-screen-resolution-display-change-windows-10-a.html
https://www.microsoft.com/en-us/windows/windows-10-specifications
https://sysdev.microsoft.com/en-us/Hardware/lpl/
If it is a driver problem, try the manufacture's website, supplying brand and model number. That info is a bit of a minimum requirement for the problem to be researched. However, the above webpages may be of some help.
Aug 25, 2015 | Computers & Internet
I have used last 4 year canon 2900B printer. How to set 300 dpi printing resoluation
Canon PIXMA Manuals MG2900 series Resolution
Resolution The data in the image you have scanned is a collection of dots carrying information about brightness and color. The density of these dots is called "resolution", and resolution will determine the amount of detail your image contains. The unit of resolution is dots per inch (dpi). Dpi is the number of dots per inch (2.5 cm). The higher the resolution (value), the more detail in your image; the lower the resolution (value), the less detail.
How to Set the Resolution You can set the resolution in Resolution on the (Scanning from a Computer) tab of the Settings dialog.
Appropriate Resolution Settings Set the resolution according to the use of the scanned image.
Item Type Use Color Mode Appropriate Resolution Color photo Copying
(Printing) Color 300 dpi Creating a postcard Color 300 dpi Saving to a computer Color 300 dpi Using on a website or attaching to e-mail Color 150 dpi Black and white photo Saving to a computer Grayscale 300 dpi Using on a website or attaching to e-mail Grayscale 150 dpi Text document (document or magazine) Copying Color, Grayscale, or Black and White 300 dpi Attaching to e-mail Color, Grayscale, or Black and White 150 dpi Scanning text using OCR Color or Grayscale 300 dpi Important
  • If you double the resolution, the data size of the scanned image quadruples. If the file is too large, the processing speed will slow down significantly, and you will experience inconvenience such as lack of memory. Set the minimum required resolution according to the use of the image.
Note
  • When you will be printing the scanned image by enlarging it, scan by setting a higher resolution than the recommended one above.
Oct 07, 2014 | Canon LASER SHOT LBP-2900 Printer
Using Windows XP with a terrible, terrible video card. Will not go above 640x480 resolution. Only has 8mb video ram and Windows won't let me raise past that. Was wondering if there was any way to force...
if windows does not have the correct driver for the graphics card the resolution may be stuck at a "safe" setting, try downloading and installing a graphics driver, if the graphics card is very old and its maximum resolution actually is 640x480 there is no way other than replacing the card to achieve a higher resolution
Jul 25, 2011 | Computers & Internet
Help I have just installed this software called corel video studios express 2010 but i cant open it as it displays a window saying the supported minimum screen resolution is 1024x768 help
The screen you are using is set to a resolution below what is needed. My guess is you are using a TV or widescreen monitor you have set to 1280 x 720 which is not large enough. Change the screen resolution to some higher than what is recommended like 1366 x 768 or higher.
May 14, 2011 | Computers & Internet
Cant get the tv to go from 720 to 1080
Changing the resolution of 720 to 1080 is dependent of the input television. Make sure the HDMI cable connection or a PC cable connected properly.
If you uses a PC input, you should set the resolution with 720 to 1024 first. then set to higher resolution. If there is a problem when doing settings dark picture or not support, it means that the TV does not support the resolution.
Perform way above the HDMI connection too.
Hope this helped solve your problem.
Mar 12, 2011 | Samsung Televison & Video
Cant adjust video resolution onboard videocard failed installed jaton trident videocard cant adjust above 800 600 screen resolution
Try downloading the most recent drivers for your new video card from the manufacturers website, that should get your resolution problem fixed.
May 03, 2009 | Computers & Internet
Resolution problem in Cricket 07
you need to check if your computer monitor supports resolution above 640 X 800 pixels or not, if you have a windows operating system you can check this by right clicking on your desktop ->Properties -> Settings -> Screen Resolution, check here by moving the slider bar what is the maximum video resolution supported by your PC
Also check if your computer meets the minimum requirements required to play EA Cricket 07
Apr 07, 2009 | EA Sports Cricket 07 for Windows
I cant play a cideo
The viewty will play .avi (divx) and MP4 files providing the display resolution is not above 320x240. If the the display resolution is above this for either format, you will receive a "file type is not supported" error. Please be aware that the viewty CAN play Divx .avi, Xvid .avi, .3GP and MP4, but only if they are not above that resolution.
Jan 28, 2009 | LG KU990 Viewty
I have Acer monitor 22, and I cannot get the right resolution. It is stretched and the text is not really sharp as it should be. I'm running windows 2000. thank you in advance
first u see your computer configuration, if u have a pentium 4 or core 2 due computer, u go to satting and control panal and system change the resolutio 1040x1025 or above, if your problem is not solve u purchase a AGP card minimum 256 mb and install the card your computer and change the resolution and enjoy...........
Jul 24, 2008 | Acer Computers & Internet
HP Pavilion F1703 17" LCD Monitor Logo
60 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
