Question about HP Photosmart C8180 InkJet Printer
Cannot print - printer says to replace the empty ink cartridge even after I replaced it. Error message will not go away.
Boba
  • 64 Answers
SOURCE: Can't seem to print in black only.
Are ya sure it isn't only preventing scanning direct to printer output? Is it also disallowing scanning to file? Epson printers canĀ“t operate if one of the cartridges is empty. There is no workaround for that. Epson printers actually use a LITTLE ink from ALL the color carts, even when you select "black only" in the driver. They do this to help keep the nozzles from clogging in the case of users who mostly print in black. Nobody [besides perhaps Epson] ever claimed Epson printers were the most efficient or environmentally-friendly ones in the world. for quite a while now Epson uses piezoelectric printheads, as opposed to the thermal heads used on most other printers. The enemy of piezo heads is air bubbles. They candamage the costly head, and that's why you cannot continue to use the printer if ANY individual cartridge runs out of ink. In fact, Epson designed its cartridges to signal "empty" when there's still around 15% (higher by some estimates) ink left! That's to make certain you can't run the cart completely dry and thereby introduce air into the head. If you don't believe that, carefully open up a spent cartridge over a sink, slice open the plastic film covering the various ink channels and rinse it out -- repeatedly push in the spring loaded outlet valve as well. There's so much ink left, it will take quite a while before the water begins to clear! It's incredibly wasteful and annoying, but it actually saves money in the long run, because it's even MORE wasteful to run tons of cleaning cycles just to purge the head once you've gotten air in the system. Aftermarket carts and ink can save lots of money, but they're a crap shoot. Fed up with OEM price gouging and scare tactics, I decided to try a clear-cartridge refill kit for my R200. The RX600 uses the same kit: http://www.inkjetcarts.us/servlet/Detail?no=8 Good Luck!
Posted on May 08, 2006
SOURCE: Overiding Empty Cartridge error for Dell A10 962
Hit the options button (just under the digital display on the printer) (and between the two arrows) 10 times. The hit the +arrow once to change. Go through the change motions again and you should get a new ink read.
Jim
Posted on Jan 20, 2008
SOURCE: Brother MFC 5840CNZ displays Ink Empty on CYAN when new cartridge is installed
Put a piece of masking tape on the sides of the little window on the cartridge. That will make the machine think all cartridges are full all the time.
Posted on Mar 14, 2008
SOURCE: Empty ink cartridge message
I replaced the old cartridge with a new one (Magenta) and it still asks me to replace it with a new cartridge.
For 1 colour which is LOW, it stopped me completely from PRINTING or COPYING at all.
Any clues how to fix this?
Posted on Jul 18, 2008
dnewcombe1
  • 1564 Answers
SOURCE: Printer thinks cartridges empty
Unplug your printer from the computer and then the power supply. Remove the inks from the printer. Plug the printer back into the computer first then connect the power supply. Install the inks "very slowly" one by one and then check the levels, they should now read full. Thank you, Dana
Posted on Nov 06, 2009
Testimonial: "You have just saved me sooo much time and money!Thank you."
Hp 2540 deskjet. Just replaced BOTH cartridges with genuine HP ink 60. Printer still flashes on the cartridges being empty. Error message. I cannot print anything. I can scan but that is all.
Per HP: After installing a new print cartridge, a message appears on the front panel that the print cartridge is low on ink. This may be caused by installing the cartridges with the power turned off. Cartridges should always be installed with the power turned on.
Found the following directions online:
How to Replace an Empty Ink Cartridge in the HP Deskjet 2540 All in One...
May 20, 2016 | HP Office Equipment & Supplies
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
I just want to print with the black ink, even though some of the colors are out of ink, so now my printer is giving me an error message and I cannot use the printer at all. How do I override this NOW...
Unfortunately you can't print anything unless you replace all the empty ink cartridges. There is no way to override it. Epson printers work that way, sadly!
Feb 10, 2010 | Epson Stylus Photo RX500 Printer
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
I have the error message that it can not recognize the ink cartridge and it is blocking me from using the macine in any function. I have removed the ink cartrdige and it still says it cannot recognize...
An ink tank which has once been empty is
installed. Replace the applicable ink tank with
a new one.
Printing with a once-empty or refilled ink
tank can damage the print head.
If printing is continued without replacing the
refilled ink tank, press the Stop/Reset button
for 5 sec. or longer to record the use of a
refilled ink tank.
Oct 08, 2009 | Canon MP610 Photo All-In-One Printer
Wont print with all new ink cartridges
If the error message is only "magenta/cyan low", it doesn't cause any error. The low message stays after replacing ink cartridges if they're replaced too early (before they're indicated as actually empty), it doesn't cause the printer to not work.
However, some other problem might be faulty, or there might be another error message. Try emptying printer queue and print from Ink Management -> Menu/set (twice) to check wether the problem is with communication from pc or if the printer actually is unable to print.
May 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Hp 6150 won't print clearly --new cartridges are in
Clean the print head if you suspect that the nozzles might be clogged. Cleaning the print head consumes ink, so perform print head cleaning only when necessary.
Hope this initial info/idea helps.
May 01, 2009 | HP Photosmart C6180 All-In-One InkJet...
Message in LED is ''Remove and check color cartridge''
It means that the printer has detected a problem with the color cartridge. If it holds multicolors one could be empty & the cartridge must be replaced in order for it to work. Best advice would be to try a new cartridge and see if the error message goes away. Hope this helps.
Mar 25, 2009 | HP OfficeJet V40 All-In-One InkJet Printer
Cannot print with new ink cartridge
Sounds like a non genuine, aftermarket ink that is dodgy.
if not ensure it is indicating the same colour that you replaced
Dec 12, 2008 | HP Photosmart C6280 Printer
Printer is not printing and black cartridge has ink Black not printing, changed two cartridges but still no print. Contacted HP who will offer no help unless I use their extortionate phone support system....
Are there any error messages that display on the control panel of the printer or on your computer? That might narrow down the problem and the solution.
With what you have said so far, it could be a couple of things. The printer series you have tends to not print at all unless all of the print cartridges have ink in them. If even one of them is empty or near empty, printing seems to stop, even if you aren't going to print using the color that is empty. My first recommendation is for you to check all of the cartridges to make sure they all have ink in them. Replace any that might be empty.
This sort of issue can also be caused if the electrical contacts between an ink cartridge and the print carriage are dirty. Assuming all the cartridges have ink in them, you should check the electrical contacts on *both* the cartridges and the print carriage. HP.com has a web page that shows you how:
Cleaning Electrical Contacts
Go to Step Two in this document for the proper instructions.
If my suggestions don't solve the problem, please post back any other information that might help narrow this issue down. As I previously said, if an error message appears on the printer or computer, please post the exact text of the message. That will help a lot. Thanks.
Oct 10, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C8180 InkJet Printer Logo
239 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
