Question about Jenn-Air JES9800A Electric Kitchen Range
Meat probe problem
So here is the issue, my jenn-air when oven is being used usually at a higher temp like 365 degrees will in the middle of cooking will start beeping flashing "Insert meat probe" When I obviously do not put meat probe in since I do not have a meat probe it still beeps then the whole oven shuts off in the middle of cooking. I try to bake again but still within a few minutes will beep again and well just turns into a cycle. What is the deal with this any advice would be helpful.
thanks so much
  • 117 Answers
Replace the oven sensor
Posted on May 11, 2008
Error code 000f
Use a multi-meter to check the ohm's resistance of your temperature probe: should be 1100 ohms at room temperature = 72 degrees F. Range Stove Oven Temperature Sensor 12001655 Multimeter DM10T
After time, the connections between the temp. probe and the control board usually benefit from being disconnected and re-connected to keep corrosion from interfering with the resistance redings the control "sees" from the probe...
Jul 11, 2016 | Jenn-Air Ovens
F3E3 Meat probe Shorted
faulty meat probe, probably a factory defect, if still covered by warranty, return oven for replacement.
Mar 22, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
How do you use a cooking thermometer to cook pork properly so that it is not raw?
Check out this YouTube video that shows you how to cook pork with a thermometer;
Feb 14, 2013 | Home
How do you use the meat probe
Insert the probe into the center of the meat, in an area where it's likely to cook the slowest. Anything above 63 degrees celcius is considered safe for consumption.
Dec 25, 2011 | Jenn-Air Ovens
Jenn-Air SCE 30600, oven error codes F1 and Probe
An F-1 error code on your model means the element was energized when it should not have been, A shorted interconnect harness or failed power relay board.
A probe indication could be a failed meat probe jack or bad harness in a unit that has one. In a unit without a meat probe, suspect a bad board.
Both conditions would warrant bringing in a tech.
Before you do, turn off the circuit breaker fot 3 miutes and turn it back on. This will reboot the boards. If problem persists, the call a service tech.
Nov 04, 2009 | Jenn-Air SCE30600 Slide-In Electric...
My Jenn Air oven is asking me to remove the meat probe. The only thing I did before it asked me to do that was to turn it try to preheat the oven to 350 degrees
you could have a bad probe receptacle. Or a board problem. Kill power to oven, wait 10 min, cross your fingers and restore power.
Oct 26, 2009 | Jenn-Air Ovens
Jenn Air W256B error code F8
Hi, F8 on later model jenn-air ranges/wall ovens indicates an issue with the meat probe, usually the resepticle. The fault is sensing a temp. at the probe above 250. Unless you actually have the meat probe inserted into the recepticle and the oven has heated above 250, then it's not likely the meat probe itself. Hence why the recepticle is likely faulty or in need of inspection/adjustment. Here's how (this may or may not work...sometimes it does though). First unplug the range or shut off the power to it. **The probe is attached on the oven liner via a nut, however you,ll need to gain access to the outer side of the liner by removing the side panel if the recepticle needs to be replaced, but hold on.** You nay only have to loosen the nut and re-tighten it to insure the recepticle has a good "ground" to chassis. there is only one wire attached to the other side (you can't see it) because the probe converts temperature to resistance in the control, that is why this "ground" is essential and can cause "faults" if not secure/sufficient. At times that's all it takes to force an F8 code. Try this first, reset the power and see if it yields a successful remedy. Hope that helps, good luck Hope that helps, good luck
Oct 03, 2009 | Kitchen Ranges
5 yr old Jenn Air Electric oven won't maintain oven temperature
Technician just left our house with same issue. Jenn-Air had issued a technical bulletin as the temperature probe is mounted directly to the heating element, and measures the heat of the element, not the oven. Their fix is a revised temperature probe that goes at a 90 degree angle away from the heating element.
If your temperature is consistent, just off by a set amount of degrees, there is an adjustment you can make at the control panel.
Mar 09, 2009 | Jenn-Air JJW8130D Electric Single Oven
Jenn-air stove temperature not constant
Sounds like your oven probe sensor has got issues. Pretty easy to fix, just look inside oven for the probe (small round cyclinder, about a pencil width or smaller, mounted usually in the back top corners), remove the two screws, then slide it out. Some models have the probes where you will have to take the back off to get to them. If your probe is ok, then you might possibly have an issue with your main oven control, which may be computer or knob type. These (especially if computer driven) can be very expensive to fix, and some need calibration. Good luck and let me know if you need any other assistance.
Nov 16, 2008 | Kitchen Ranges
Jenn-Air JES9800A Electric Kitchen Range Logo
933 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
