Question about Sanyo DP42746 42 in. Plasma Television
NEED A PART NUMBER FOR A Y STAIN BOARD - Sanyo DP42746 42 in. Plasma Television
  • 2,335 Answers
You will find the Y sustain board part number here.
Posted on Sep 03, 2010
Can someone tell me what the square footage is in a board 2 inches thick 8 inches wide and 8 foot long please
if you are staining the edges and both sides it will work out as follows
Each flat side is roughly 5.28 square feet or 10.5 square feet total per board.
The edges add rougly another 2.4 square feet so rough answer would be 13 square feet per board.
Jul 10, 2016 | Office Equipment & Supplies
OIL STAIN ON A CLOTHES out of washing machine E12477
Are they getting the oil stain from the washing machine? If so, you need to get a tech out to inspect your washing machine. If you are putting oily clothes into the washing machine hoping it will come out, it's too late, you need to pre-wash with Shout or Tide to remove oils and grease. The more you wash and dry it the deeper the stain will set. Sounds like you need to throw those clothes away.
Jan 20, 2015 | Washing Machines
My stain is darker on one side of floor...used minwax polyshade and it looks like two totally different colors.
Did you mix the stain up before you used it? Is it possible that there are two different woods on the floor? Is the difference delineated from one board to another or is the difference in shade blotchy? You can try to mix the stain you have with a lihjter stain, but that is a hit-or -miss propostion.
May 05, 2014 | Minwax Hpt Interior Semigloss Polyurethane
How to stain wood veneer
You would need a stain that would penetrate the wood veneer. A good oil based stain should be able to penetrate all the way through. Lightly sand the face of the veneer with 220 grit or higher sand paper. I use a sanding block made out of rigid foam and sand by hand. You will need to keep the veneer wet with the stain until it penetrates. I would stain both sides of the veneer until it penetrates to the depth you desire and then wipe off any remaining stain. You may need to press the veneer until it dries thoroughly! Good luck.
Mar 21, 2014 | Crafts & Hobbies
How do I clean my bissell PROheat 25A3 tough stain tool?
I have heard of people washing them in an empty dishwasher! Most people just buy a new one!- Justin Buy Bissell 314 9162 Tough Stain 3 Tool Assembly for Bissell Deep...
Mar 05, 2014 | Bis ProHeat Upright Deep Cleaner 25A3
Sanyo TV DP42647 Screen Has Dark Stain
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 27, 2017 | Sanyo Televison & Video
I am looking at buying a Wagner Max HLVP sprayer. The jobs are staining a modest stretch of fencng and a larger staining project of an overhead pagoda-type structure. Is this a good choice or would you...
I was a painting contractor for last 10 years of my work career.
If you are using HVLC cup gun, you will have to select correct tip,
You will need to thin the latex 50-50 with water, and keep paint strained to keep out all clogging.
If the tip is not reversible, then expect disassemble each time clog happens.
And you will be continually re-filling the cup.
And then if the surface is rough, the spray won't flow into the holes.
You have a mess coming your way.
Painting a fence: A roller is the only way to paint/stain rough surface.
Buy big hairy 1" roller cover from Sherwin Williams. Don't get the cheapo 1/4" thick roller cover because it doesn't hold any paint. The big roller holds a big volume of paint.
Now if fence is rough, like cedar, you need to thin the stain.
About 1.5 gallon water per 5 of stain ... and suddenly you have 6-1/2 gallons of stain which means you bought too many gallons of stain.
So don't overbuy the stain. And pick up 2 plastic bucket for mixing.
Empty gallon of stain into mixing bucket > put water into empty gallon > put lid on gallon and shake up > pour water into mixing bucket with stain > to mix: pour mixing bucket of stain back and forth between other mixing bucket until stain is mixed. Do this work on the grass where it won't run out onto concrete surface.
Put roller and frame on a wood pole that you took off the push broom. Now roll that stain onto every surface the roller can touch. Think of it like picking up quarters. If it was money, could you get the roller on that spot >> the answer is yes. Don't try to smooth it out and make pretty. Throw the stain on any way the roller can turn. Customers used to call that 'slapping it on' and I used to say, 'that's how it works, lady.'
Use a piece of masonite at the bottom. If you get stain on anything, wash it off immediately and use a wire brush on concrete surface or towel on smooth surface.
Wait for a day, because stain looks 100% better next day. And then go back with a brush and hit the spots you couldn't get with the roller. It will be faster and cheaper and fewer headaches than trying to spray latex stain with a HVLP cup gun.
To clean the roller: Leave it on the roller frame and wood stick. Turn on water hose and get the roller spinning until it's clean. Do this away from everything you don't want stain on.
Dec 13, 2010 | Garden
Philips 32pfl5322d/37 went off and won't come back on
Hi!
Sounds like you have a bad power supply board! This is not hard to do yourself, as long as you are somewhat handy! Take the case apart (back side), and look some bad caps (capacitors) on the power supply board. They will look bulged on thetop an may be a little leaky (brownish stain).
Then you can buy a new one at www.shopjimmy.com or ebay, you will need to use the brand and model number! Good luck, I hope this is helpful!!
Mar 02, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Sanyo DP42746 42 in. Plasma Television Logo
430 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
