Question about Kenmore Dryers
My dryer works but does not heat. I figure it is the heating element. Am I correct?
  • 262 Answers
If your dryer is 220 V electric you could be correct, but keep in mind that there are a few other componets that could keep your dryer from heating. There is a high limit sensor that could go out or a thermal fuse or even your breaker box could have triped one side of the breaker. or a broken or burnt wire. The timer could have a bad finger inside of it or if you have a control board you could have a bad relay on it. or even the switch on the motor could have gone bad.
you will need to check the componets to find your problem
Posted on Sep 03, 2010
  • Kenmore Master
  • 1,525 Answers
Hello you may have a problem with the heat sensors, if 1 is faulty . change both of them
regards
shaun
I have an electric whirlpool dryer model# wed5300sq0 and it stopped heating. Still operates just no heat. Figured it must be the heating element so I followed your instructions and did a continuity test on...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;
Jul 14, 2011 | Dryers
Gas dryer won't heat
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual!
Nov 11, 2010 | LG DLG7188 Gas Dryer
Kenmore dryer makes no heat
replace the heating element. Or the control panel has weakening capacitor not sending correct current flow to the heating element
Jul 09, 2009 | Dryers
Dryer is not drying, no heat
your dryer has a coiled unit inside that heats up...this is what actually where the heat comes from is off this coil. Your coil (heat element) has a break in it some where this be the reason for your dryer not heating up. As for VERY temp solution..one could twist this heating element together making connection but again this is JUST to be temporary ..as only should be 1 day before actual heating element to be repaired correctly. If one is mechanically inclined this is not a hard procedure with the correct common tools...and heating elements can be bought offline as well as possibly if you have a Sears repair facility close by your loction. IF not, then suggest you to call a trained tech in this field if you are not mechianically inclined or unsure of yourself.
Jul 04, 2009 | Whirlpool GGQ8831L Gas Dryer
Won't heat
If it spins - you have a problem with the heating elements (usually they are 2 heating elements).I suggest you call a tech and have the deffective elements replaced
Apr 27, 2009 | Whirlpool LER4634J Electric Dryer
Dryer has no heat.
the heating element has probably burned open.
pull the element out and you'll probably find the break in the heating coil.
or possibly one of the leads going to the element has burned open.
good luck.......jay
Mar 21, 2009 | Whirlpool Kenmore 5.9 cu. ft. Extra-Large...
Relaced thermostat and therma fuse, now dryer is tooo hot
Sound like the thermostat is not working bud first check and double check the thermostat is connected properly and the wires are on correctly (not mixed up)and check the stat probe or bulb is in the correct place to pick up heat(assumeing that the stat is not a energy switch wich has no bulb)If you are not sure where the wires go there should be a diagram on the inside of the back panel or go on line to the manufacturer site and get one from them,
Hope this is of some assistance
Jan 19, 2009 | Maytag PYE2300AY Electric Dryer
Heating Element for Whirlpool Dryer: GEW9200LW0
I think on this one you can take off the bottom panel on the front and get access to the heating element.
Dec 16, 2008 | Whirlpool GEW9200L Electric Dryer
GLER642A dryer heating element
Things that could stop a electric dryer from heating: - house fuse or breaker ( needs 2! )... - heating element ... - burnt wire ... - thermostats ... thermal fuse ( not all models )... - motor heat switch ... - timer ... - selector switch ... - burnt power cord/plug
Oct 10, 2008 | Frigidaire GLER642A Electric Dryer
Dryer will not heat up
It could be the heating element, thermal fuse, or high temp thermostat. The timer won't advance at all on auto dry cycles, if the heater isn't working.
Get an Ohm-meter and find the component that measures infinite ohms.
Mar 10, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
