Question about Watches
Need instruction for watch skagen 22uss - Watches
SOURCE: skagen mesh band shorten
just solved the mystery...U probably have too ..by now....but just in case..
here is a fun link to the solution by an actual user....was actually inspired by him...coz like I said I had mispaced the manual...
http://www.amazon.com/review/product/B0000C9ZBX/ref=dp_top_cm_cr_acr_txt?_encoding=UTF8&showViewpoints=1
I just used my nail file and lifted the locking mechanism and moved it forward...Now I can sleep better tonite....!
Mrs Martin
Posted on Dec 27, 2008
escapement
  • 2334 Answers
SOURCE: How to adjust Skagen watch band.
You may have arrows inside bracelet.Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
Posted on Jan 10, 2009
SOURCE: inability to remove link segment from skagen watch
I finally found instructions at: http://emea.skagen.com/service/watchBandSizingChart.fx and was able to remove the links.
Posted on Mar 07, 2010
  • 103 Answers
SOURCE: i need a replacemnt mesh band for the skagen 281LSS
go to skagen.com they have cheap replacement bands for your watch you can even send it in and they will send it back to you like new.
Posted on Aug 04, 2010
  • 103 Answers
SOURCE: replacement battery for Skagen 430SSXD watch
send your watch into skagen since you have a lifetime warranty you do not want to breech that. plus they reseal your watch and other watch repair places cant.
http://www.skagen.com/service/home.fx
Tip
SKAGEN watch manuals/instructions.
Here is direct link for all original SKAGEN watch manuals/instructions: http://www.skagen.com/service/watchInstructions.fx
on Jan 23, 2010 | Watches
Hi. I've got a Grenen mesh watch band and need to move the clasp mechanism further down on it to make it tighter, but I can't figure out how to loosen it to move it. Can you help?
Grenen watches are made by Skagen exclusively for Kohl's. Here is the link to the their website instructions for watch band adjustment.
http://www.skagen.com/service/watchInstructions.fx#adjustment
Apr 11, 2010 | Watches
Where can I find a manual for a Skagen 390LTR?
Put http://www.skagen.com/service/watchInstructions.fx into your search engine and you should arrive at a page which gives you a list of instructions you can choose from.
One of these should be suitable.
Apr 09, 2010 | Skagen 390LTR Wrist Watch
Replacement battery for Skagen 430SSXD watch
Mar 13, 2010 | Skagen 430SSXD Wrist Watch
Inability to remove link segment from skagen watch
Mar 07, 2010 | Watches
I have a Skagen that i cannot figure out how to set the time on. it has 4 different buttons and looks like it is designed to tell time in a variety of places.
You can get instructions for your watch by going to the skagen web site "skagen.com", choose your area.
At the bottom of the page you will see a number of menu options, click on "customer care" and then on "instructions" (under the heading "warranties").
There will then be a set of instructions for all their watches and you can choose the one that is similar to yours.
Jan 23, 2010 | Skagen 355LGSC Wrist Watch
SKAGEN 521LBLB1 ALARM INSTRUCTIONS
everything you will need is right here.
p.s. there is another little stem on the lower right side that controls the alarm it must be pulled out.
May 08, 2009 | Skagen Alarm Watch Black Square 521LBLB1
Watches Logo
285 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
