I Have a Model CKL60-1 Goodman a/c unit is it aheat pump or not.
Does the pac an 130 es carry aheat pump
My personal suggestion would be to go for these repair catalogs. I know this
website www.reliable-store.com that i used to get manuals from, and they have all models online.
I also brought for my 1989 BMW, such old model, they had it and it was very good manual. Go ahead, I bet.
Mar 14, 2018 | Cars & Trucks
On a cpkj 48-1B Goodman heat pump I am having condenser fan issues. runs full spedd for a while then cuts down to barely running, Even after changing the motor and capacitor.
Does the condenser utilise head pressure control to maintain head pressure? if so is the unit fully charged...r22. r410 Freon.If the unit is an older model. the fan motor only runs at 850 r.p.m design flaw. The newer units now run the fan at 1075. R.p.m. I have installed many Goodman split systems and was having problems similar to yours. Hope this. Helps you
Jul 11, 2015 | Goodman Heating & Cooling
I just installed this unit and can not get the blower to run
Seriously depends on what unit you have. Model # & serial #? You can "jump" R to G at the unit. If its a standard Goodman AHU there may be a terminal block or just some wires that were factory installed outside of the unit. R to G will send 24v to the blower relay, sequencer or board (depending on model) energizing the relay and then returning to common. If you have tried that you should ensure you have proper line voltage 220-240vac. at the service breakers on the AHU.
May 18, 2015 | Goodman Manufacturing Goodman GPH1330M41...
Goodman furnace a36-20 fan runs non stop
is green wire from thermostat or from outdoor. retrace and change as needed. If not Goodman has a tech support number you can call while looking at unit.
Jun 21, 2014 | Goodman Heating & Cooling
I have a Goodman Heat Pump System Model ARUF032-00A-18,
That sounds to me like you lost your low voltage power. Bad transformer
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 10, 2009 | Goodman CKL30AR30 Air Conditioner
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Goodman heat pump wiring
ok Let me see if this helps if not please comment back with the t-stat model and make as well. The Y terminal on the t-stat needs to be connected to the Y terminal on the heat pump board. If this does'nt fix it your thermostat may have something different going on so please send me the model and make of the t-stat. Also if you know does this unit have outside temperature sensing probes, and or an automatic defrost cycle?
Jul 06, 2008 | Goodman CLQ36AR49 Air Conditioner
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
