Keyboard mapping is messed up, It's like the fn key is always pressed down
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
Clean the keyboard.
Try to lift the key and check whether it is actually stuck or not.
If the key is stuck just pop the key off with a butter knife or something flat.
Clean the rubber boot with warm water and replace. if that don't work, you need to get a new one.
Some don't have the rubber boot. in that case you can use a que-tip with rubbing alcohol to clean under the key.
You could even try silicon spray as a last resort. last suggestion...I promise.
Good Luck.
Live, Love, Laugh.
Posted on May 11, 2008
  • 42 Answers
This could be a few things:
The simple ones first:
1. fn key is stuck (bang the keyboard lightly on the desk a few times)
2. The wrong driver for the keyboard is loaded (Unistall the keyboard driver, download the lastetest and reinstall with the setup.exe supplied, otherwise windows will just install the old keyboard driver again)
This this does not work, post me the make and model of the keyboard, operating system, as I'm asumming it's windows.
With a little history: i.e. Is this a new install etc..
Aspire one AOA110 keyboard problem with Fn keys
Hook external keyboard to your laptop, if okay! the internal keyboard on your computer will need to be replaced to fix this problem.
Mar 31, 2012 | Acer Aspire Computers & Internet
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
How brighten the screen?
Look on your keyboard on the "f" keys (f1, f2, etc...) for a symbol that looks like a sun or shining light. Something that would indicate brightness. Now, hold down the 'fn' (function) key on the bottom left of your keyboard and then press the backlight key you just found.
Mar 01, 2011 | Gateway MX6214 Notebook
I need an explanation as to the secondary function of the keys on my NB305. Mainly the top row of 'F' keys, but the remainder of the keyboard as well. What do all these little symbols on the keys mean?
F1 through F12 are called function keys because they execute programmed functions when pressed. Used in combination with the Fn key, keys marked with icons execute specific functions on the computer. The function executed by individual keys depends on the software you are using.
1. Sound Mute: Pressing Fn + ESC in a windows environment turns sound on or off. Press Fn + Enter to simulate Enter or the enhanced keyboard's numeric keypad. 2. Instant security: Press Fn + F1 to blank the screen to prevent others from accessing your data. To restore the screen and original setting, press any key or press the Touch Pad. 3. Power save mode: Pressing Fn + F2 changes the power save mode. 4. Standby: When you press Fn + F3, the computer enters Standby. 5. Hibernation: When you press Fn + F4, the computer enters Hibernation. 6. Display selection: Press Fn + F5 to change the active display device. Hold down Fn and press F5 again to change the device. 7. Internal LCD screen Brightness: Pressing Fn + F6 decreases the display brightness in decrements. 8. Internal LCD screen Brightness: Pressing Fn + F7 increases the display brightness in increments. 9. Wireless setting: If your computer has both Bluetooth and Wireless LAN functions, you can press Fn + F8 to select which type of wireless communication you want to use. 10. Touch Pad: Pressing Fn + F9 in a windows environment enables or disables the Touch Pad function. 11. Press Fn + F10 or Fn + F11 to access the integrated keypad. When activated, the keys with gray markings on the bottom edge become numeric keypad keys (Fn + F11) or cursor control keys (Fn + F10). The power on default for both settings is off. Press Fn + F12 (ScrLock) to lock the cursor on a specific line. The power on default is off. 12. TOSHIBA Zooming Utility (reduce): To reduce the icon size on the desktop or the application window, press the 1 key while holding down the Fn key. (13. TOSHIBA Zooming Utility (enlarge): To enlarge the icon size on the desktop or the application window, press the 2 key while holding down the Fn key.
Jun 15, 2010 | Toshiba 310CDT Keyboard
Can you tell me how to switch my laptop keyboard
Hold function (Fn) key down and press the key on the top row that has a sign (picture) showing a padlock insde a square. (Num lock key) Normally "scroll" key
Apr 02, 2010 | Gateway 2520915 Keyboard
How do you set the time on the Logitech keyboard MX3200
Please do the following:
1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
2. Press (FN + F10). You are now in 'Set mode' - you can exit this at any time by pressing the Esc key.
3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
Jan 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
Key board problem
Try to press Fn key, hold it down and press the Numlock key.
Jan 16, 2010 | Velocity Micro NoteMagix x30 Laptop
Keyboard key not typing primary character, shift/fn strokes work
this is to do with your FN key....it is activated to be on all the time...
googlesearch this ...
Sep 15, 2009 | Dell Inspiron 1521 Notebook
Keyboard trouble
you need to reload that software that came with the keyboard. Uninstall the keyboard from device manager :- Control Panel>system>device manager. Then reload the software for the keyboard, which should also have the drivers. If you do not have the software, let me know the make and model of the keyboard and I will see what I can do.
Hope this helps
Oct 28, 2008 | Gateway Computers & Internet
Display brightness
You should have an "Fn" key. It's between CTRL and Windows key on the lower left corner of the keyboard. Hold down the Fn key while pressing the UP arrow key.
Aug 13, 2007 | HP Compaq Evo n610c Notebook
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
