Question about Brother MFC-9840CDW Laser Printer
What does "Drum Error" mean on Brother MFC9840cdw? And how do I fix?
5 Suggested Answers
SOURCE: my brother MFC9840cdw has an error message that
The guy that replied solved the problem. He rocks and I can't believe that brother does have a large posting on this issue. Sham on them:
ben2913 did the job "This is NOT the solution to this error code. The code is telling you that the Corona wire must be cleaned. Remove all 4 color drums. Look down into the tray that you removed them from and you will see 4 green tabs. Open the plastic cover that protects the corona wire and move the green tab back and forth several times. After you have done this with all 4, reinstall the drums, close the machine front and everything will work fine again."
Posted on Aug 18, 2011
komguy
  • 2306 Answers
Look on the right side of each drum unit, there's a gear on each and each has a number that needs to align on the top with the marks make sure all drum gears are in synch.
Posted on Feb 25, 2010
fawazkhalil0
  • 5 Answers
SOURCE: i have brother dcp-7030 got an drum error even if ...
error code EC
Posted on Jan 28, 2011
SOURCE: Brother laser printer MFC9840CDW prints
Hi, well this is a problem with the transfer drum/corona wire you see what's happening is that the entire page is being covered in the "ink" and it's meant to "Fuse" to the paper where it has been sensitized via the laser, however in your case the wire is also "Setting" a fine covering over the entire surface. Somehow the entire page is also being sensitized, via the corona wire?, that transfers the charge to the paper, the image then made via the laser and set by passing over the heater. in your case both the image and the printing surface are being charged somehow... and then both surfaces react with the printing process.
You need to clean the machine so it is like a sterile area too, any loose particulate in the machine will add to the problems too. Also i believe you need to change the corona wire too.. and or the driver board for said corona wire, it, they may be faulty?
http://www.scribd.com/doc/15024880/mfc9840cdwservice-man
Please find a link for your service and repair manual above, have a look in there and use the troubleshooting steps, that may point you in the right direction.
Posted on Apr 23, 2011
My MFC9840cdw quit printing or copying. The page is completely blank.
Probably the high voltage power supply is bad. This is what charges the transfer roller which allows the toner to cling to the roller and then transfer to the paper. No charge = no toner leaving the toner cartridge.
Mar 24, 2013 | Brother MFC-9840CDW Laser Printer
Brother mfc9840cdw print unable 74
This error is about empty toner.
Get it fixed.
Oct 01, 2010 | Office Equipment & Supplies
Brother Mfc9840cdw (except for fax send) has been very good. During print job (2nd computer sent job during print from 1st computer), red light suddenly came on. everything stopped. No sign of a jam. No...
the machine is nearing service time.. Normally this is maintenance and resetting the print clock..
  • press both 3 and 9 buttons at the same time and hold
  • select each item 1 at a time and press ok
  • press 1 to reset it..
  • do this for each item in the list
  • repeat for each item.
Apr 05, 2010 | Brother MFC-9840CDW Laser Printer
My brother MFC9840cdw has an error message that says, "drum error, slide the green tab on each of the colored drum units. Refer to the users guide". I have tried sliding the green sliders several times. I...
Feb 25, 2010 | Brother MFC-9840CDW Laser Printer
BROTHER DCP 8040 MULTIFUNCTION HAS AN ERROR MESSAGE: 7A. How do I fix it?
This error means that the Main motor is not synchronising with the reference clock.
This can be caused by several things...
  1. Could be a faulty motor.
  2. A faulty Engine Circuit Boaard.
  3. Fault on the Main PCB.
  4. A siezed Drum unit.
  5. Something seized up in the drive train.
Try to get it to start up with the Drum unit removed, if it does the initial rotations OK with no Drum unit installed, then try a new Drum unit.
Failing that, you will need to dismantle and inspect all the drive train and motor assemblies.
Good luck.
Dec 27, 2009 | Brother DCP-8040 Copier
I have a Brother 2170w with all lights flashing. Turning on and off does not fix problem. Help!
This is in reference to another solution on this site--please search before posting as others have already solved this problem:
Per http://www.fixya.com/support/t2462964-all_3_error_lights_flashing_4_count_go
When all lights flash it's a service problem. You press and hold the go button and see what lights are on then.error light means main PCB failure, Toner light means fuser failure, drum light means laser failure. Toner and error light means main motor error, drum plus error light means its a fan failure.
Jul 09, 2009 | Brother HL-2040 Laser Printer
All 3 Error lights are flashing (4 if you count the GO button)!!
Jun 26, 2009 | Brother HL-2170W Laser Printer
Brother MFC-9840CDW Laser Printer Logo
495 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
