Question about LG Refrigerators
Hello I have a LG refrigerator LRTX18311WW with top freezer. Ice is building up on the floor of the freezer compartment. I have cleared the ice before, but it forms again. The gasket door seal seems alright. Any ideas? Thanks
catriver
  • 878 Answers
SOURCE: water leaking onto floor
Angels, sounds like your defrost drain is frozen over. When the refrigerator is going into defrost it's draining through the front instead of the drain pan. You can remove the shelves and peel off the back cover and clear the drain by pouring hot water on the frozen drain hole. If you have a baster of some sort you could try to squirt the hot water through the venting on the bottom of the panel. Another way to to point a hair dryer on the drain hole. The best method is to remove the shelves and panel and make sure the drain is clear. Catriver..post back.
Posted on Dec 22, 2006
  • 87 Answers
SOURCE: Delfield Refrigerator/Freezer Condensation forming outside door seals
I would expect at the very least a heater circuit around the freezer door. Some of the commercial units also have sprung doors to keep the doors firmly shut which you could check by opening the doors. Door heater circuits are normally very reliable and it would be worth checking the voltage is getting to them, they are also a pain to change out. Hope this helps.
Posted on Aug 26, 2007
SOURCE: Kenmore refrigerator model 46-66812 ice build up on the bottom shelf of freezer
your drain is blocked and it causes blockage and then ice forms..turn of for 24 hoyrs and it should be alright
Posted on May 25, 2008
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
SOURCE: Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
Posted on May 07, 2009
Water is sitting on top of freezer compartment and leaking out on floor
Make sure that your drawer is aligned properly and that there is no ice build up anywhere. Mine built up some ice in the very back and side somehow, and caused the door not to close tightly which lead to a similar problem. Removing the ice build up cured it.
Jun 13, 2014 | LG LFX25960ST Stainless Steel French Door...
Water in refridgerator
Have a look inside fridge compartment (especially the "roof", if it's a top-mount freezer) & see if you can see any ice build-up (look inside vents that allow cold air into fridge from freezer section. Also, if top-mount freezer, look inside the freezer compartment for ice build-up on "floor", inside vents, or on back wall. These symptoms, combined with water dripping from lots of the "roof" of fridge section (in a top-mount freezer model), can mean several different problems, so best to re-post with more info/symptoms included.
If there's no ice build-up (& the dividing area between fridge & freezer sections isn't particularly cold, which otherwise might indicate hidden ice build-up), it can be as simple as a plugged or obstructed drain tube, which is VERY COMMON. Easiest solution for this latter problem is to use a flexible plastic tube (think similar type as attached to aquarium air pumps), stuff it into drain hole, and blow on the other end. Sometimes you have to blow quite hard to clear an obstruction or complete blockage. If you can't clear the drain tube, it's likely a different problem. Again, a re-post with more info/symptoms will help narrow it down.
Sep 17, 2013 | Roper Refrigerators
Condensation building up under crizper drawers icing up somewhat and overflowing out onto floor.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center.
This picture may be a slightly different moldel that years but it shows where that drain is
oldtech2332_6.jpg-->-->
Aug 16, 2011 | Frigidaire FRT17B3A Top Freezer...
Excess water dripping into refrigerator from freezer. I am in the process of defrosting. Ice build up behind freezer back wall. Do I need a new heater or will clearing the ice from drains suffice?
Clearing the ice build up is a good start,the problem though is the drain pan under the coil in the freezer thats iced up is blocked so when the defrost heater comes on and melts the frost from that coil,it the water is collecting in the freezer and in many cases drips into the fresh food compartment,clearing the drain will resolve your leaking/ice build up issue.THE DEFROST HEATER IS GOOD melting the frost in the first place and hence forth that melted frost stays in the freezer and becomec ice.
Gene
Aug 09, 2011 | Roper RT16DKXK Top Freezer Refrigerator
Whirlpool refrigerator (top freezer) is leaking into bottom of fridge. What can it be?
Hi, read about your problem. What's happening is your drain in the freezer compartment in the back behind wall is plugged. Defrost water then builds up under freezer floor and freezes. To fix, remove back wall. Also the floor needs to be opened up. Use a blow dryer to clear ice out of drain, in the trough, and under the floor. Hope this helps
Jan 18, 2011 | Whirlpool Refrigerators
Model No IK 458 -4-4T; Product No 925 780 652 02 Ser No 14100010. I get ice build-up on floor of fast freezer comp which jams pull-out basket.
If the defroster coil is not working, then ice will build up on the coils inside the back of the refrigerator.
But, you're saying that it's accumulating on the floor of the freezer jamming the pull out basket.
I would say that the timer or overflow valve is bad on this refrigerator causing ice to build up on the floor of the fast freezer compartment causing the jamming.
Jul 19, 2010 | Freezers
Once or twice per day, water on floor below freezer door
check for plugged drain at back bottom of freezer if plugged/frozen over defrost and clear with hot water and remove all ice.
Nov 13, 2009 | Admiral 26 cu. ft. Side-By-Side...
Lg frost free fridge freezer gr-399sq
on the back wall inside the freezer unscrew the white panel and then remove the panel behind this . you should now see a tray that runs the width of the freezer with a driphole on the left-hand side which will probably be frozen with ice , chip away whatever is possible and then put boiling water on the driphole and once this is clear you should find the problem sorted , 1 other option is to turn the fridge/freezer off for several days and this will allow the ice build-up to thaw thus resolving the problem
Jan 05, 2009 | LG LFD22860 Stainless Steel Bottom Freezer...
Ice in freezer compartment
Check to see if your drain tube is clear. Sometimes it freezes up at the base of the rear cover in these bottom freezers. Causing an ice dam.
Jun 30, 2008 | LG LFD22860 Stainless Steel Bottom Freezer...
Refrigerators Logo
647 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
