Two black lines are appearing on everything I print. Glass is clean. What can I do?
  • 2,229 Answers
Sounds like the printer/scanner is dirty inside. You could probably clean it, but it would be better to take it to a printer repair place where they could clean the rollers inside.
Posted on Sep 03, 2010
SCX 4826FN everything that goe in through the top feeder (scans, copies, faxes) comes out with a solid vertical black line on the paper. All other printing jobs that pull paper from the tray are ok. It...
This black line sounds like it is definately coming from the ADF scanner glass. This is the thinner strip of glass that is located just to the left of the large original glass. You can verify this by making a copy from the large glass instead of using the feeder on top. If the copy comes out clean then it is definately the scanner glass. Just clean the glass well with glass cleaner and a soft cloth. This glass is only used when copying/scanning using the top automatic feeder
Good Luck and Thank You for using Fixya.
WheatlandServices
Nov 04, 2010 | Samsung Office Equipment & Supplies
Black line appears in copying from Konica Bizhub 200
If the black line appears ONLY when copying and NOT when printing then you need to clean the adf strip glass. This is the thin strip of glass that is just to the left of the large original glass. Clean this glass very well with a soft cloth and glass cleaner. The line is caused by a small particle stuck to this strip of glass.
Jul 06, 2010 | Minolta Di3510f Bizhub Copier
Incoming faxes have black line running through the centre
If it is just from incoming faxes and not from anything you print/copy then it is the sender's fax machine that is dirty. If everything you do has that line, try cleaning the scanner glass and corona wire.
Jun 09, 2010 | Brother IntelliFax-2920 Fax
Hp laserjet 3050 - black line down the center of copies, everything elese works
If the lines only appear on copies from the auto feeder and printing is clean, then lift the auto feeder section and clean the scanner glass underneath.
If printing and copying have similar 'streaky' results you probably have a bad toner cartridge - try a replacement. If that doesn't work you have a fuser problem - which is quite a costly repair based on the replacement cost of your unit
Feb 26, 2009 | HP LaserJet 3050 All-In-One Printer
Samsung CLX-3160FN All in One Printer
open the scanning unit. in scanning unit clean the mirrors.
Sep 16, 2008 | Samsung CLX 3160fn All-In-One Printer
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Black lines
Here you go.
1. Put a paper on the glass don't use the ADF see if you printed copy has a black line on it.
If you do not have a black line on it, do the following.
Lift up the ADF tray go in to additional functions #6 Adjust/Clean and then #2 clean the ADF feeder.
The roller is in the top of the ADF feeder at the right and is white in color. When you press the (set) button you will see it spin.
Also clean the glass you have some whiteout on it. (Look at the glass real good when cleaning it).
Nov 19, 2007 | Canon imageCLASS D880 All-In-One Laser...
Thick Black Line on my copies and faxes
Can't image it being anything but scan glass, if prints are fine, are you sure you cleaning scan glass(inside of where originals are fed)?
If so then scanner lamp faulty, but I've never come across it myself on this model.
Oct 26, 2007 | Brother MFC 8500 All-In-One Laser Printer
Canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Jul 04, 2007 | Canon PIXMA MP780 All-In-One InkJet...
Print Problem - vertical lines
If the problem only occurs when using the document feeder, the problem is not usually caused by the drum. When using the document feeder, try to notice where the scanner (the light assembly under your scan glass)stops just before the paper is being fed. Some multifunction machines have a small piece of glass that is separate from the large scan glass and the scanner assembly stays parked underneith it as the original is being fed over it. Most likely there is something on the glass where the scanner parks as originals are being fed thru the feeder. When putting your original on the large scan glass to copy, the mark on the glass will only show as a spot, but will show as a vertical line thru the whole copy when using the feeder.
Feb 23, 2007 | Brother MFC-7820N Laser Printer
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
