Question about Microsoft Xbox 360 Console
No lights flashing around the power on button and nothing coming up on the tv screen. Any quick fixes?
  • 767 Answers
Sound like ( no video ) but you get sound and all green on
the power button . If that's the case then your G.P.U. has
lost the connection ( Video Feed) to the HANA / ANA chip set.
You can do what's called a x clamp mod with screws and
washers and then force the G.P.U. to over heat. This is
a quick fix , But It probably wont last long 1-3 mouths on average.
Or you can have a local repair shop reflow the G.P.U. and properly
clamp it . This is a much more durable repair , average cost is
50.00-80.00 so shop around for the best warranty if you decide
go this route.
if you have any questions feel free to ask
Rob
Posted on Sep 03, 2010
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
What part(s) should I order to repair a RCA LED TV that does not "turn on" correctly. When it powers on there is flash of a image but goes away quickly and no sound.
sadly since we can not see the set it makes it tough to diagnose unless it is a huge TV then fixing it might be more costly than getting a new set from say Walmart .the buy and try method usualy cost way more than a repair shop.
Nov 18, 2015 | RCA Televison & Video
What part do I need to fix my smart TV?
Fault to the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Sep 12, 2015 | Vizio E-Series E470I-A0 47" LED TV...
Polaroid TV screen will not always come on.
Are you talking monitor rather than tv? I have an LG 22 inch monitor and the on off button is on the bottom, If I don't hit it right or just tap it, it won't turn off but flashes. Where do you have it plugged in? Is it with some other electronics, or right to the wall outlet? I'm really at a loss as to what your problem really is. Are you using the remote? One quick fix might be the battery's in the remote. If they don't have enough power, short or no signal will be sent to tv or not being able to decipher it.
Feb 05, 2015 | Polaroid 4011-TLXB LCD TV
The power button keeps flashing
If the tv is not coming on, then you may need a new tv. If it is coming on and its just the light that bothers you, a quick fix would be to put a small piece of black electrical tape over the light. I read thru the owners manual and found no setting for this specific issue. Id suggest contacting Olevia. Hope this helps a little.
Sep 30, 2014 | Olevia LT42HVi 42 in. LCD Television
Tv won't come on. It has a flashing green light on by the power button.
the tv is not come on.it has a flashing green light on.tv model hd 1080.
Oct 19, 2008 | Mitsubishi WS-65809 65" Rear Projection...
My big screen tv went off and reset it but you push the button and the power comes on and goes right back off
when we push power button the green light flashes as if thinking about turning on and nothing happens, any way to fix this?
Feb 18, 2008 | Televison & Video
Another question
you can pull the plugs inside tv to convergence yoaks if tv starts up . you will need convergence ic,s
Apr 13, 2007 | Panasonic PT-47WXC43 47" Rear Projection...
Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
Dec 19, 2006 | Samsung HCN4226W 42" Rear Projection...
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
