Put the spinner 1000 to go horrible noise stopped the machine tokke some clothes ou in case of to much weight started again did a short spin seemed ok and then the noise stared again (drum is turning but whines)
Bearing going bad
Posted on May 12, 2008
Why my washing machine vibrate when spinning
if it only vibrates when in the spin cycle turn off the machine and cloths distribution re-balance you have to many heavy cloths on one side of basket. Turn it back on and let it continue this should solve your vibration problem
Jul 13, 2015 | LG Washing Machines
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
Loud banging noise when machine goes into spin mode. sounds like it is banging on the side. Please help !
Usually this is an out-of-balance condition caused by too much weight on one side of the tub, move the clothes around and try again.
Apr 26, 2009 | Washing Machines
The machine fills and drains on wash cycle but willnot spin
C1. Your motor was stopped due to overloading, inbuilt device, reduce weight of clothes (put less clothes). Press 'stop' & 'cancel' to clear the display.
How abt a good rating? Thanks
Mar 21, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The spinner gets off balanced make knocking sound
Ok first is it a top load or front load and I need the model number inside the lid or door.
Sep 23, 2008 | Kenmore 24032\24036 Top Load Washer
Squeak upon spinning
Hi, I wanted to comment on this because I have the Majestic MJ9200 Washing machine front load for the RV. I am having the exact same problem and I cannot use my machine at this time. This is NOT an unbalanced load problem. An unbalanced load will cause a loud banging noise because the drum is off balance. There is something wrong inside your machine. Mine never had this problem before either and an unbalanced load does not cause this horrible screech while on the spin cycle. My machine like yours made the noise only on certain spin speeds, high 1500 rpm spin the first time and when I adjusted the spin cycle just to see what happened it stopped making that horrible noise. I washed another load and it began that same screetch while spinning and it was then in all RPM ratios available on my model.
My husband took the top off the machine and could not see anything evident but when looking into the front of the machine we could tell that is seems the interior drum is much looser in the washing machine than in the dryer. There are two drums on the front load. A larger outer drum and a smaller inner drum. The inner drum is what is looser in our machine and the noise is a very loud screetch while spinning the water out of the clothes.
Is your machine under any kind of warranty? Mine is not and I am waiting to get it fixed.
Good luck on getting yours fixed and perhaps we can both help each other out on this one although we have different brands of machines...
May 25, 2006 | Whirlpool AWM5145/2 Front Load Washer
Keeps fusing
It seems like something is prevent tub's free movment. Try to spin the clothes tub by hand and look for a free movment. In case it doesn't move smoothly,maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent its clear spin. In this case it may then get into the drain hose that's attached to the pump.Remove the hoses from the pump and pull the item out. In case it clean there, check the outer tub port- open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then,try to remove the clothing through the port. Be aware you should disconnected the power cable before starting your tests !! Good luck !!!
May 23, 2006 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
