Question about Dell Inspiron 1420 (dncwja1_1) Intel Core 2 Duo T7250 (2MB cache/2.0GHz/800Mhz FSB) 80GB/1000MB PC Notebook
Dell inspiron 1420 not recognizing ac adapter
  • 2,567 Answers
One possibility is that the power cord attaching the power adapter to the DC jack in the laptop might be broken or damaged. Inspect it visually to verify this possibility.
Also, try measuring the DC output from the power adapter's outlet to make sure it is providing the correct output voltage needed to run the laptop (if at all).
Another possibility is that the DC jack where the power adapter connects to the laptop might be either loose or damaged, & needs to be either re-soldered or replaced. However, in order to do this, you will need to disassemble the laptop & get the motherboard out.
If this did not work, there might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 06, 2010
5 Suggested Answers
  • 3940 Answers
SOURCE: AC adapter not recognized
The AC adapter has a small wire in the center of the connector to the system. This sensing wire, if bent or broken will cause the error you mention.
Check the inside of the connector, since it is new, you can call Dell 800-624-9896 for a replacement adapter.
Posted on Sep 14, 2008
  • 75 Answers
If you don't get any errors when you startup on battery then all you have to do is call Dell. Get work order number and send them the laptop and adapter. They are very fast. I sent a laptop to them last month and I had it back in 3 days! I was surprised.
Posted on Dec 04, 2008
  • 18 Answers
SOURCE: Dell 1501 Error- AC Adapter is not recognized
myabe the battery is faulty have you tried replacing it?
Posted on Sep 07, 2009
Testimonial: "Don't have an extra battery to test so was hoping the error was causing the battery not to charge. "
  • 184 Answers
SOURCE: have a dell inspiron with
From doing a google search for "AC Adapter Cannot Be Determined" it appears your power adapter is defective and/or the output voltage is not up to full voltage. From the many posts about this that I find doing the google search it's a fairly common problem. If it's still under warranty contact Dell Support. If not, you'd better buy one replacement. There are tons of online stores selling this.
Try this:
http://www.chargerbuy.com/dell-inspiron-1501-ac-adapter-65watt-19-5v-3-34a.html
Posted on Nov 17, 2010
My DELL Inspiron 1420 battery is not charging when i connect the AC Power Adapter. I checked up in the BIOS and it shows that my Adapter is an "UNKNOWN DEVICE". I tried with three new adapters...
Can you take your battery out and turn on just with the adapter plugged in? Works? The adapter is ok.
Windows is not recognizing your battery so it can not charge it. Remove the power again, put the battery back in again and notice if it is loose or not a good fit.
Ask the service center to test your system with a different battery as they do wear out!
Samr thing with a different battery, the charging curcuit and connection from the battery system to the motherboard may have gone out or received damage from a short curcuit or power problem... in this case they may be correct about the motherboard.
If the system is still under grarantee, let them do the work... if not, continue to use the machine without a battery, only connected to wall power... till something else goes wrong. The repair may be more expensive than a newer model.
Aug 27, 2011 | Dell Inspiron 1420 Notebook
Dell Inspiron 1420 switch off while on at Internet site and it will not start up again when pressing the on button.
you can first try to connect your laptop to an AC power source via the ac adapter, if it fails to charge the battery, then it must be your battery died. try a relacement dell inspiron 1420 battery,which usually lasts longer and is compatibale with your dell and costs much less than the original one!
May 09, 2011 | Dell Inspiron 1420 Notebook
Have a dell inspiron with original ac adapter and battery. i get error message saying that the AC adapter cannot be determined is not recognized by dell and need a dell 65W AC adapter. I have the...
The adapter could be faulty or has failed slightly and is below the operating limits. This means you probably need to replace the power adapter.
Nov 01, 2010 | Dell Inspiron 1501 Notebook
Battery won't charge
Either battery or charger is faulty.
Mar 24, 2010 | Dell Inspiron 1420 (dncwja1_1) Intel Core...
My dell inspiron 1420 dont charge. the indicator in the taskbar does not indicate that it is charging if it is plugged in
Either you got a faulty AC adapter or there is a problem with the DC power section of the Inspiron (or maybe the DC jack). Usually it's the adapter. You can check it with any commercial multimeter: it should give you 19V with internal positive. If it's broken, most Dell use the same adapter and it's easy to find cheap deals on eBay, for example.
Unfortunately, if it does work, and yet the notebook is NOT working if you take out the battery and plug the AC adapter only, you'll probably have to call Dell tech support.
Dec 05, 2009 | Dell Inspiron 1420 Laptop
I had the battery not recognized on boot up. then
the Dell AC adapter has a sensing pin so the bios can determine the wattage of the adapter. If the system cannot ID the adapter, the battery charger circuit is disabled. You'll need a functional DELL ac adapter to get the battery to charge
Sep 26, 2009 | Dell Inspiron 1501 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
Dec 04, 2008 | Computers & Internet
Sep 13, 2008 | Dell Inspiron E1505 Notebook
Dell Inspiron 1420 (dncwja1_1) Intel Core 2 Duo T7250 (2MB cache/2.0GHz/800Mhz FSB) 80GB/1000MB PC Notebook Logo
171 people viewed this question
Alun Cox
