Question about Kenmore Refrigerators
The fridge is a kenmore model 79852990. This is the second or third time the drain has clogged. The last repair guy that came out was a real ****. If he can clear it, my seven year old can. I actually have some time over this weekend to do it, I am just not sure where the drain is. where's the drain in the freezer? THanks
  • 1462 Answers
SOURCE: Auto defrost not working correctly
the tray at the bottom which collects defrost water usually has its own heater or a section of the main heater runs close to it. check this part of the heater has continuity. an old trick as well which sometimes works is to wrap some copper wire round the heater and lead this to the drain hole. conductiuon of heat thro the copper helps keep the drain clear. this is a common problem across all makes
Posted on May 08, 2007
SolutionGuy
  • 331 Answers
SOURCE: Kenmore Elite refrigator side by side Model # 10655602400
Boomdog, the problem with your fridge is the temperature control board (where you adjust temps at in the fridge section). I serviced one of these just this week for the same problem! It's working fine now. They'll need to bring a control board with them to finish this job. The part number for it is #8201659. Be glad you won't have to fork over the cash to buy it, the retail cost is ~$165.00. Unfortunately, all of my vendors tell me this board is a factory backorder item. Maybe Sears will have it, maybe not. Also, after the repair is complete, please connect your computer controlled appliance up to a quality surge suppression/arrestor device. We highly recommend this one... http://catalog.belkin.com/IWCatProductPage.process?Product_Id=124911
Posted on Aug 11, 2007
the dr
  • 447 Answers
SOURCE: blocked fridge drain
The pan being full doesnt affect the drain being blocked the pans not full anyway its constantly evaporationg it. I use a little air pressure to clear drain lines, than pur a diluted solution of water and a little bleach down the hole water should drain fast and not pool.
Posted on Oct 05, 2007
fridgetech
  • 473 Answers
SOURCE: clogged fridge drain tube
The drain is behind the back panel in the freezer at the bottom. Sounds like it is frozen over which is pretty common. Will need to remove panel and thaw out drain by running hot water down. You can use a putty knife to break up ice first. Make sure you get all ice around the drain above and below the thin aluminum tray at the bottom. After the drain is free don't be alarmed if you get some water on the floor because the drain pan may not hold all of the water you ran down the drain. Not anything you can do to prevent this on this model.
Posted on Oct 07, 2007
  • 3 Answers
SOURCE: My Kenmore fridge/freezer side by side isn't staying cold
Ok so we just had our Kenmore fridge quit cooling , everything in the freezer defrosted , and we lost a lot of food,BUT my husband ordered a part #8201786 which is a starter , and installed it and it worked! The fridge was clicking but it just wouldnt kick on, and the fan still worked. There are websites that you can order the part from, It cost $63.05 with tax!!!! good luck
Posted on May 25, 2009
I have a problem with my kenmore refigerator. model number, 79852990 top freezer. For a while water wud fill the top left drawer. Now, the water ends up on the bottom of the fridge. Where does all this...
The defrost drain is plugged if you do not see a drain cup in the fresh food section then remove the back wall of the freezer and see if the drain trough is iced up.
Nov 22, 2010 | Kenmore Refrigerators
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Jul 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
I have a kenmore refrigerator model 36369262991. I have water accumulating on my top shelf. It drips from the thermostat control panel. what is wrong?
I had a similar problem on a Whirlpool Fridge. In fact, there is a good possibility that your Kenmore is made my Whirlpool. As you probably know, Sears doesn't make appliances, but contracts with well-known appliance makers to manufacture kenmore-branded products.
If your fridge is an auto-defrost model, whenever it auto-defrosts, water from the melted ice collects in a tray behind the freezer, and drains into an evaporation tray at the bottom of the fridge through a drain tube. Over a period of time, the drain tube can become clogged, and instead of draining out of the freezer, the water overflows into the fridge. The clue is that the problem is intermittent -- the dripping stops between defrost cycles.
The fix is to remove the liner panels from the freezer, melt and sponge out any collected ice, clear ice from the drain with hot water, and clear any gunk from the drain tube with compresssed air or a flexible "snake." I used 1/8" pvc tubing as a snake.
It isn't hard to do, but if you are nervous about disassembling parts of your fridge, you will need to get a pro to do it.
Jun 29, 2009 | Kenmore Refrigerators
Doe's not defrost into lower drain pan.
Your drain line is clogged, just clean it out and you should be fine
Jun 26, 2017 | Kenmore Refrigerators
Fridge has water pooling on the shelves and under the drawers.
check the door is sealing properly, use a note book page and close the door on it , then see if you have got some resistance when you pull it out. Do this on all `sides `. Is the drain blocked ? Are all high moisture content foods covered. Are you in a tropical area ? This can also make a differance.
regards ****
Apr 01, 2009 | Kenmore Refrigerators
I have had to have my appliance repair man unthaw and unclog my condensation drain 2 times in the last 3 months. The bottom of the freezer freezes and water drips into the fridge. My refrigerator model #...
Three things. First is that your defrost element is faulty, replace. Second, if the defrost element is working there is usually a thin filiament of aluminium which is attached to the element and inserted into the drainpipe, this keeps the drainpipe from freezing up by radiant heat conducted from the element. Thirdly, your main pc board defrost side is faulty and needs replacing.
Mar 09, 2009 | Refrigerators
Water under veg bins
Hi. thanks for the question . the problem you have is with the drain tube, from under the freezer wall ,in the fridge. that tube is clogged up . pull fridge away from wall. locate the drain hose at the drain tray. clean. also clean all coils behind fridge thanks the appliance doc
Sep 30, 2008 | Kenmore 20.6 cu. ft. Top Freezer...
Aug 10, 2007 | Whirlpool GS6SHEXNL Side by Side...
Refrigerators Logo
250 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
