We had a bad storm last night while we were asleep and now this morning the HDMI source on our Olevia 537H LCD tv doesn't work.
    Sergeant:
  • 209 Answers
Dear butifli21
This HDMI issue with regards to your television could be due to the tv resetting itself within the menu, and therefore you will have to re-enable your HDMI settings before the tv will make use of this facility or work with what ever is plugged into your TV's HDMI connection point.
Now the major thing with any electronic product, electrical thunder/ lightning storms, faults with the product and human beings in the same location at the same time, is the fact that the human being will presume that such major damage has occurred that the product is rendered useless, however the product could still be perfectly sound, apart from minor issues, but it is largely due to the awesome power of electrical storms that make humans fear it in terms of the damage that these storms do.
Now if you can answer yes to any of the following questions, then it is possible that your appliance/ vendored product has sustained serious damage from the storm.
Has your house/ location sustained a direct hit from lightning at the time your product malfunctioned?
was any power line/ aerial cable directly linked to your product hit by lightning?
was the electrical storm in the vicinity of a mains supply line/ power transformer which will supply electricity to your house and local area?
has a blackout been reported (no matter how small or large)?
have ANY telephones/ radio systems been affected? (also include cellphones, mobile hansets, land phones, satellite phones, HAM and CB radios)?
are you running your equipment from a power supply that is NOT SUPPLIED and protected by a SURGE PROTECTOR/ anti spikes.?
has a product of the same manufacturer/ vendor model been affected in the same way to yours after the incident?
The previous questions here are only as a base guide and will aim to assist in how to rectify this fault. Much in the same way as when a sick person goes to a doctor complaining of pains in the stomach, and saying they think they have a pulled muscle, when in reality, the questions are asked and the doctor states that it is merely just a slight upset tummy due to eating to much spicy food. This is how we will deal with your problm, and is why i have asked the questions about your storming situation.
Now, lets suppose this is sustained damage from lightning (direct hit), firstly, you are lucky your television is working still, so this makes repairing you model a little easier.
Secondly, if any component is damaged internally, we will be able to work out which ones, and how they are damaged. This means that yo will have to disassemble your TV. Once you can find the circuit board where your HDMI connectors are, then just look on that circuit board, and the circuit board that supplies power to this area. In this instance,, you will be looking for any cylinder shaped objects that have markings on them (uF, F, pF etc) and these are capacitors. If damaged, they will be blackened, will smell, and may even be split. These components are designed to discharge electricity on a set timescale and have a maximum voltage threshold which should not be exceeded, in addition to this, the polarity must NEVER be reversed on certain types of cap otherwise they can explode. Now as lightning is somewhere in the millons of volts, and carries huge amount of amperage, i would find it extremely unlikely that anything electronic would survive a direct hit from a strike, unless shielded. However the component i have given reference to here, and indeed, other components such as fuses, resistors and logic gates can be damaged by exessive amounts of current, load, or frequency.
Now i think the best course of action to take here, is firstly to acquire yourself a copy of the service/ overhaul and repair manual, now you can either do this by going to various websites and enquiring for the manuals there. I have given a few details of these to get you started.
http://www.retrevo.com
http://www.service-manuals.info
http://www.adobe.com (needed for you to read the manuals as they are in PDF format)
http://www.google.com (type in your model details followed by repair manual
Now before going off to get the repair manual, its best to start with the easier tasks and the cheaper option. So i would start with checking those menu settings just in case they have been reset, next up, it would be to ask about, and enquire if anybody else has had the same or similar models go corrupt, and what they did about it. After this, i would probably open up the TV and have a look (and a sniff around........quite literally.......for burnt out parts and other faults), then find your repair guide, and then commence repairing the unit.
WARNING:
Firstly, you will need to isolate your TV from the mains electricity supply for at least 24hours as telly sets carry high amounts of voltage within them, and some can store electricity for long periods of time. In addition to this, if you are not sure about a component, or something within the set, just ask me, and i will help you. Now for obvious reasons, you should never work on a TV or high voltage equipment if you have heart problems, if you are physically ill (even a headache can effect your judgement), if you are drunk (now believe me, ive seen this happen) or if you have hyperelectrical sensitivity (sensitive to electrical, or static environments).
Lastly you will need to be pretty handy with a multimeter, soldering iron and tools, so going to a library, evn goign online or to a school/ university is always a good option, or yo can ask someone in the know.
One more site to check out is
type in the search bar the words THE ELECTRONICS CLUB..
here you will get a vault of information which IS useful to you if you want to repair this fault yourself. If not, then there is always the option of the good old fashioned electronics engineer who can fix it for you.
I really wish you all of the best of luck on this one, and hope that my information to you is the fixya for you. I also look forward to hearing from you soon, and you can fel free to ask me any question about this matter in full, and I WILL ANSWER it for you.
Until then, i give you my best regards and wish you the best of sucess once again.
Yours sincerely
Oz
Posted on May 11, 2008
    Scholar:
  • 131 Answers
This is very common if you dont have a power surge protector on your cable line or wall outlet. the lightining travel through the line and most likely damaged the hdmi board.check first go to menu and check if settings are correct.
things to do:
1. unplug and plug back in 5 minutes might reset
2. see if you have warr or home insurance to cover repair
3.call local tv repair shop to come over and look at ask about estimate on phone.
Thanks doctor video
Panasonic tv hdmi inputs not working
It appears that during the storm there may have been an electrical surge that damaged the electronics of your tv. If the tuner is working fine then the affected area (board) is the one that has the HDMI input sources.
Aug 30, 2015 | Panasonic Viera TC-P58S1 58 in. Plasma...
No video or audio input through composite video or HDMI 1 on an Emerson 32 inch LCD HDTV
Check and replace its main power regulator board. It is not working. Might be faulty.
Jan 29, 2013 | Emerson LC320EMX 32 in. LCD HDTV
I have a 32" Sharp LCD tv and last night we had a
You have a bad HOT, horizontal output transistor. It will have a number on it, and you can find it here.
http://shop.ebay.com/i.html?_nkw=horizontal+output+transistor+&_cqr=true&_nkwusc=horizontal+output+transitor&_rdc=1
Watch part replacement videos to get this working again. Also check for bad parts around this transistor if you have multimeter and component experience.
Jun 19, 2011 | Sharp 32R-S50 32" TV
We had a lightning storm last night. The tv was working after the storm and was left on all night . This morning all that was on was the VIZIO light on the front and it will go off and on with the remote....
Sadly, only testing of each component can suggest the extent of damage. Many years ago, lighting can in through the window of my living room, hit the TV, blew the knobs off the TV (that date's me), shot into the kitchen and shattered the kitchen counter top. What I want you to take from that is that the course of a power surge is a bit unpredictable. No one can guess how far it got until you find a lamp that works.
Jun 14, 2017 | Vizio VO47L 47 in. LCD TV
Olevia 537H LCD - Set up options now disabled
No idea what happened but about an hour after posting this the TV started to function properly - now I can switch everything that was previously lokced up. So I'm all good - hopefully it doesn't do it again.
Nov 08, 2009 | Syntax Olevia 537H Television
Tv repair
I soudcs like the backlight inverter board is bad or the power supply is npt supplying 24vdc to the inverter board.
Oct 31, 2009 | Olevia LT37HVS 37 in. LCD HDTV
The HDMI port on my Olevia Model 337-B11 LCD tv quit working. Is there an easy fix?
Without replacing the main board, probably not. Did you try another HDMI source to verify the TV is at fault? If it is the cheapest fix is to use component only.
Sep 10, 2009 | Olevia Televison & Video
Tv wont turn on worked fine last night
If there is no power at all, then the problem is likely the power supply unit.
The PSU must be tested, then eventually replaced.
May 30, 2009 | Spectroniq PLTV3250 32 in. LCD TV
Televison & Video Logo
306 people viewed this question
Top Televison & Video Experts
