Question about Amcor ALD12000EH Air Conditioner
UNIT TURNS ON WORKS FOR FIVE OR TEN MINUTES THEN SHUTS OFF
  • Amcor Master
  • 17,129 Answers
Check the thermostat, the sendor the control or the relay unit.
You must trace from the sensor to the control unit , check at the point of running and stop the change in voltage to confirm.
The control unit can be trigggered externally to test. If so the sensor can be the suspect.
Posted on Sep 03, 2010
It will run good for a while on hot heat and then shuts off for abut 5 mins but it doent shut off on cold cyc
why does my roper electric dryer shut off after five or ten minutes of running fine. then wait five or ten minutes, restart and it runs fine for another five or ten minutes, and so on....
Dec 29, 2012 | Roper REX4634KQ Electric Dryer
2002 vue v6...starts and runs well however when I stop , shut off the engine, then try to start after half hour , it wont start
Lookfor a light on the dash that says SECURITY or ANTITHEFT. If you see this light, that is a sign of a failed or failing antitheft system, which will disable your vehicle. This link explains
http://vatspasslockpasskeysecurityhelp.yolasite.com/
Nov 06, 2011 | 2002 Saturn VUE
New fuel pump new pres regulator car will run about 4to8 seconds then shut of every time wut to do next?
Sounds like the security is set. turn the key on, don't start, let it sit for ten minutes, turn the key off for five seconds. try to start the car.
Jul 25, 2011 | 2000 Buick Regal
Wife used cig lighter adapter last night to blow up air mattress this morning new battery less than 1 month old wont start car. charged battery now when i turn the ignition key to start car the car alarm...
turn the igntion on, don't start, let it set for ten minutes Turn it off for 5 seconds then try to start it. If it lost memory for some reason and doesn't start . then do this three times , after the third time start it. that is the relearn procedure. Have a charger on it for the 30 minute relearn. Relearn is on for ten m off five s on ten off five on ten off five then start
Jul 02, 2011 | Chevrolet Lumina Cars & Trucks
I have a whirlpool gas furnace that come on for about 4 seconds and shut off. it does this four times and then it shut off fir about five or ten minutes then restarts again. sometimes it wiil stay on until...
well jumper out r and w see how it cycles .If it runs fine than it narrows it down to t stat change t sta and be done .If unit does the same thing I would recommend a new circuit board
Nov 29, 2010 | Heating & Cooling
Shutting off and turn back on ever five to ten minutes
Did you replaced lamp in Hitachi 60VX500 tv in last 2-3 years?
If not then it is time to replace lamp to solve tv issue.
Let me know if you have additional question.
Thanks.
Nov 28, 2010 | Hitachi 60VX500 60" Rear Projection HDTV
Samsung monitor MN:2333HD, monitor will shut off after about five or ten minutes
The power supply on the unit needs repair. In some cases you can find a damaged one with good power and install the board. A good technician should be able to fix the unit for 80.00 or so. If you want to send the unit in to us we can usually have the repair completed in less than a week. Thanks
May 04, 2010 | Samsung SyncMaster 2333HD 23 in. LCD TV
Error 5400
Solution: Press ON/OFF switch and wait a few minutes before powering back on the device
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear an error, power off the printer and power it back on. Before powering back on the printer, wait five to ten minutes.
  1. On the operator panel, press the <ON/OFF> button. (The display will go blank.)
    Note: On rare occasions, it may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately five to ten minutes and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
FYI - There is a firmware update for this unit as well
Apr 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Optoma ep716
Go to the onscreen menu and check lamp settings. Disable auto shut-off.
Nov 09, 2008 | Optoma EP716 Multimedia Projector
Amcor ALD12000EH Air Conditioner Logo
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Michael Youngman
Michael Youngman
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
