Question about Bosch Washing Machines
Bosh 1400 E-nr waa28160gb/01 fd8512 06267 0gb the brushes on my washing machine are not working i have got some new ones but do not know how to fit them. Would be very grateful for any help that you could give me. Regards Debbie
SOURCE: Frigidaire Gallery FWT449GFS1 washing machine
http://www.repairclinic.com/referral.asp?R=154&N=1094128
The internal brush can be used to replace brush in similar holder on certain Electrolux, Frigidaire, and Kenmore washers (at least motor # 131276200).
Posted on Jan 02, 2008
  • 4 Answers
SOURCE: HOTPOINT F-01 error code
Try http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Feb 16, 2008
SOURCE: Hotpoint washing machine WMA66
Thank you gittos73.
It's as gittos says. When you open the door and look inside, at the very top of the door is a white square. This holds the metal clip. If you push the little white dot in the middle of this clamp gently, it gives way and you will see the round metal clip that goes all the way round the door rubber (gasket). Remove this and you can put your fingers round the gasket and pull it toward you.
Then take the lid off the machine and you will see a 6mm nut with a spring behind it and a wire clip similar to the front one, going round the gasket where it attaches to the drum. This has a crosspoint (phillips type) head on it and you can get a small screwdriver into it and undo it all the way. Then slide the gasket off and it will come away.
Fitting it is the reverse but it is a little bit tricky as you have to get the gasket behind the lip to make the seal. Take your time and they will both go round properly.
Posted on May 28, 2008
abhishek33
  • 1239 Answers
SOURCE: Whirlpool 6th Sense AWM8123/1 error code FH
hi Most washing machine timers are digital or mechanical. The timer controls most of the operations of the washer: water level, tub filling and emptying, length of cycles, and cycle setting sequences. For this reason, any repairs to the timer should be made by a professional service person. However, there are a couple of checks you can make when you suspect the timer is faulty -- you may be able to install a new timer yourself.
Step 1: Unplug the washer. To access the timer, remove the control knobs and the panel that covers the controls. This may be a front panel, or access may be through a panel at the back of the unit. Carefully examine the wires that connect the timer to the other parts of the washer. If the wires are loose or disconnected, try pushing them into position; they usually fit into their terminals like plugs. Use long-nosed pliers to avoid breaking the wire connections -- never pull a wire by hand.
Step 2: To test the timer, use a VOM set to the RX1 scale. Disconnect the power leads to the timer and clip one probe of the VOM to each lead. The VOM should read zero if the timer is working. Since the timer is a multiple switch, turn it through its cycle and test each pair of terminals in turn. The meter should read zero at all of these points. If one or more readings are above zero, the timer is faulty and should be replaced.
Step 3: To replace the timer, unscrew and disconnect the old one. Install a new timer made specifically for the washing machine. If there are many wires on the timer, have a helper hold the new timer next to the old one as you work. Disconnect the old wires one at a time, connecting each corresponding new wire as you work, to make sure the connections are properly made. Or, draw a diagram showing the connections before removing the old timer. After all the wires are connected, check the connections again for correctness and screw the timer assembly into place.thank u....please rate it
Posted on Nov 28, 2008
SOURCE: Hotpoint wma57
the filter is at the back where it enters the machine undo the cover you will see a big black tube clipped in a few places undo and the filter is inside there
Posted on Dec 23, 2008
Siemens xlm 1400 will not rinse clothes, it makes noise but the drum will not rotate eventhough it will turn by hand.
your motors drive brushes need replaced
so look to use the model number in EBAY
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xxlm+1400+brushes.TRS0&_nkw=xlm+1400+brushes&_sacat=0
i used the search string
'xlm 1400 brushes'
and they are quite easy to replace..
it may do a whole wash cycle and count down etc just wont spin or move the drum with heavy water laden clothes
goes eeeeeeeheheeheh but no drum rotate
so
you can drain the machine only
lay the machine down with the soap drawer away from the ground
then it wont leak
two screws and one power clip removes the brushes
from the main motor {the one with the belt that drives the drum}
their are two brushes one each side
so 4 screws
and replace both ..
so...
good times
let us know the size of the brushes left
they should be like new 2.5" - 3" long
if they are less then 1.5" replace them
this is the issue
the main advice is not to use it just now
till you check the motor brushes
as this type of fault can further damage the motor
so .. dont use it till you check / replace the brushes as the intermittent contacting will damage the motors stator {the bit the brushes make contact with}
Aug 19, 2014 | Siemens Washing Machines
Bosch classixx 1400 express
have you cleared the filter
Feb 03, 2014 | Washing Machines
To remove motor to renew brushes
Most washing machine motors have no brushes. They are induction motors. And they are made so cheaply that they are welded together hence they cannot have the bearings or many other parts worked on. They may have a centrifugal switch that can be rebuilt or replaced.
Nov 28, 2013 | Washing Machines
Bosch logixx f:43code E-Nr. WAS32741AU/20 FD 8901 200134
F:43 meant motor error. We have electronics engineers as father-in-law (lucky). We checked motor - all good. Replaced worn brushes (cheap replacement). Still f:43 flashing after reset. Replaced PCB (Power Control board) with one that we ordered from Bosch factory and installed. Working like new. New brushes make light buzz which is normal.
Oct 11, 2013 | Washing Machines
My bosh classic xx 1400 express washing machine door has came off. is there any way of getting it back on ? thanks wendy
you can buy a new rim easy to fit is it the inner or the outer rim check before you buy ???? you will need the enr no
Jun 24, 2012 | Bosch Exxcel WFX 145S Front Load Washer
Bosch exxcel f01 code comes up after switching on
Question?#$@???
Exxcel 1400 express with the number E-Nr. WFX2867GB/10 FD 8410604749,
The last time I used the machine I interrupted it while it was washing and thereafter its stopped working. When turned on it will collect water and detergent but will not turn or wash.
What do I do????
Jul 16, 2011 | Washing Machines
I have a Bosch Classixx 6 1400 express washing machine which works fine but only splns very slowly,What can be the problem ?
Probably needs new brushes fitting in the motor, you will have to remove the motor to do this.
Dec 02, 2010 | Bosch Washing Machines
Bosch WAA28160GB front loader blocked
Bosch WAA28160GB.This washing machine tutorial will show you what to do if the washing machine does not drain or empty the water out this repair was done on a Bosch, Neff and Siemens type appliance.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 26, 2007 | Bosch Washing Machines
Washing Machines Logo
70 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
