Question about Dell Inspiron XPS Gen 2 Notebook
Dell Inspiron XPS Gen 2 won't boot up only 3 green lights come on. Changed out motherboard and both cpu and graphics fans, same results. Any suggestions? Thanks, Robert
  • 3 more comments
  • rpmoakland Sep 03, 2010
    Yes, swapped out the 2 512 MB for 2 1 GB cards. Nothing. Also, installed the hard drive into another Dell and it's working fine.
  • rpmoakland Sep 04, 2010
    Hi; thanks for responding. Yes, I changed the motherboard with a refurnished one from TXcess Surplus. I have since contacted them to swap out the one I installed and have received a replacement. I plan to install to see if this corrects the problem. Is there a way to check the video card/thermal cooling assembly?
    Thanks,
    Robert
    Hi; yes I did swapping out the 2 512MB for 2 1 GB cards. Didn't correct the problem.
    Thanks,
    Robert
    Replaced the battery several month ago and changed motherboard again today, The 3 green lights indication previously has now changed to a one "A" green light remaining on much longer than the 3 green lights. Also, with the power supply plugged in the battery status light is blinking periodically.
    Thanks,
    Robert
    Ok, should I work on replacing just the graphics card or the thermal cooling attached as well? You should know I swapped out the motherboard today. Previously only 3 green lights for maybe 5 seconds. Now one green light "A" but staying on much longer maybe 10-12 seconds before shutting off. Also, the computer now is giving an indication of the battery being charged by the power supply. Looking up, maybe?
    Thanks again,
    Robert
  • 320 Answers
Try installing new ram. bad ram is a constant reason for computers not to boot up. you cant have video with out it. i have worked on quite a few pc's that wouldnt boot and this was what was causing them not to.
Posted on Sep 05, 2010
  • Dell Master
  • 4,737 Answers
Would you mind if I ask you for a clarification? I am a little confused when you say 'changed out motherboard and ..." Do you mean, you've changed the motherboard?
Referring to your condition and the light, I would suspect Graphic card (video module).
Awaiting.
Posted on Sep 04, 2010
    President:
  • 4,070 Answers
Hi! Have you tried swapping the memory card? This can be a memory card issue.
Posted on Sep 03, 2010
  • dj_relly999
    dj_relly999 Sep 04, 2010
    Hi! HOws it going?
  • dj_relly999
    Hi! battery working fine?
Xps 7100 has power, green light in back is on, but cpu will not turn on, changed the power supply, still not powering up.
is the fan over the cpu running? if it fails to spin the pc will not boot. could be bad connection of wires, a short, also could be corrupted boot file or graphics card boot? are fans spinning/usually two. cpu not then find why?
Dec 03, 2013 | Dell Studio Computers & Internet
Need new video card for dell U2424 motherboard
What is the Dell model? XPS-G2? This is a Laptop?
Jan 17, 2013 | Computers & Internet
My dell xps won`t stay on
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Apr 15, 2012 | Dell XPS 410 PC Desktop
My DELL XPS dimension Gen 4 wont boot up. The amber light is steady and no diagnostic lights are lit on the back. The processor fan is going at maximum speed. Before this problem I could not plug in a...
The indications are of a NO POST. This can be caused by:
  1. Failed motherboard
  2. Failed Front IO Panel
  3. Damaged IO Panel Cable
If issues connecting USB connections occurred via the front connection, I'd suspect the IO panel as the issue. If the IO panel doesn't resolve, then motherboard is likely failure point.
Jun 27, 2011 | Dell Dimension XPS Gen 4 PC Desktop
Respected Sir, I installed an nvidia 8400gs graphic card a year ago..........it works fine ....then two weeks ago i dusted up my cpu...........i inserted the graphic card then the computer...
it is because your nvidia card was broken, it makes the windows won't boot up, try to clean up your nvdia card (yellow circuit which will connect to the pci of the mother board) using a pencil eraser
i suggest you to change your nvdia card with a new one
May 14, 2011 | Dell Inspiron 6000 Notebook
Usb2.0 laptop tv tuner driver
http://www.inetbridge.net/forum/download/file.php?id=2295&sid=432f7c52d98676c2400b20b83f88c355
Dell Emuzed Angel USB TV Tuner Driver v.1.0.2.32 A00 Windows XP.
Supported Models: Inspiron 6000, Inspiron 9400/E1705, XPS/Inspiron XPS Gen 2, Inspiron 9300, XPS/Inspiron M170, XPS M1710.
Driver : Dell Emuzed Angel USB TV Tuner Driver v.1.0.2.32
Mar 01, 2011 | Computers & Internet
Need to replace video card in Dell Inspiron XPS Gen 2 PC Notebook. Dell wants $ 750.00 + -, Is there a less expensive card I could use. I don't need a high performance card. I am certain it is the card...
No they change out the whole motherboard and in saying the its invasive and costly and there is no way you can buy a video card for a laptop there all on the motherboard.
Apr 22, 2009 | Dell Inspiron XPS Gen 2 Notebook
Dell inspiron xps 9100 cpu upgrade
Highest compatible cpu for your system is the Pentium 4 3.6 ghz Prescott. Hope this helps & please rate this solution fixya. Thanks.
Here is a link to a spare parts supplier for your system: http://www.dellweb.co.uk/spares/inspiron/9100.htm
Feb 04, 2009 | Dell Inspiron 9100 Notebook
Dell XPS 400 Card Cage Fan Failure
dell xps 400 pentium d once i turn it on, it beeps and says "card cage fan failure" everytime i press f-1 to continue it shuts off and boot up again it does it everytime how can i fix this CARD CAGE FAN FAILURE??
Apr 22, 2008 | Dell XPS 200 PC Desktop
Dell Inspiron XPS Gen 2 Notebook Logo
50 people viewed this question
Alun Cox
