Question about Garden
Hitachi CS33EB16 16" Rear Handle Chain Saw Starts a little rough - brand new. Run for 15 minutes and turn it off, if started within 3 or 4 minutes it starts right up. If I wait 7, 8 minutes or more it won't start I need to let it totally cool down before it'll fire again.I've been reading some reviews on line which sound to be about the same. What is the issue?
  • 252 Answers
Might pay to check the fuel tank breather , make sure its venting
check the ignition coil it may be going open circuit loosing its spark when it getts warm or hot , you have to wait till it cools to re-start
you will need a spark tester fitted in between ht lead and plug to check this visually when its running
check for a kill wire grounding 1st
cheers
Posted on Sep 05, 2010
Husqvarna 450 e chainsaw chain tension wheel doesn't lock and the cover comes off during use
The adjustment handle snaps down to lock. If the handle is coming loose, I recommend replacing the handle. You can also go to standard bar bolt set up if you prefer. Check with your Husqvarna dealer for part numbers.
Apr 22, 2014 | Husqvarna 450 e-series 18" Chain Saw
16 inch poulan chainsaw got hot and started to smoke and now the recoil no longer works. I took the cover off and there is two springs that seem sprung. should I toss it and forget it or this something I...
how old is the polan 16 inch is it a solid body saw or does it have anti vibration handles, so your hands dont go numb after cutting for 15 minutes.reason i asked is: you can buy a brand new reconditioned homelite with anti vibration handle for 85.00&shiping.
at the very least,your polan needs the recoil starter fixed
and that does not address why the poulan got hot & started to smoke.
For the problems you described , at least $100.00 labor plus parts to fix at a chain saw shop
It might barely be worth it if you were a do it yourselfer and wanted to try to fix it.
if you dont want to be a diy chain saw mechanic, sell your polan for parts for $20.00 on ebay and buy a new homelite
16 inch 38 cc with anti vibration handle ,so you can cut for 6 hours straight, if need be. You get a reconditioned saw that is ready to go and a 90 day warranty. or buy the saw brand new for $110.00 and free shipping@ amazon.com
Oct 07, 2013 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Hitachi Chain Saw won't start hot
check for spark when it fails to start could be a bad coil
Aug 10, 2012 | Garden
I was wondering if there is anything I can do about the oil leaking. I have a hitachi cs33eb it is brand new.
The oil pipe is poorly fitted to the oil pump and allows bar/chain oil to sneak past the seal. Buying a new oil pipe may not fix the issue since this is common on brand-new saws. Warranty work probably won't help you.
How I fixed my saw: I bought two small O-rings about the diameter of the oil pump and fitted them to act as hose clamps around the oil pipe. See attached picture. It worked perfectly and now my saw runs out of fuel before oil. Sears/Craftsman have a great video on how to remove the clutch assembly.
Jul 10, 2011 | Hitachi CS33EB16 16" Rear Handle Chain Saw
Just bought a new 455 Rancher, within 15 minutes of use the chain fell off the guide. Could not put this chain on guide again. Tried brand new chain and within 15 minutes of use, chain came off of guide...
if you loosen the nuts holding the bar on there is a tension screw on the opposite side from where the nuts are you should see it if you look from the front of the saw by the muffler you need to use it to put the proper tension on the chain if you turn it clock wise it should move the bar out tightning the chain you want a tiny bit of slack in the chain it should not be dogged down tight with the tension screw if you go counterclock wiseit should release tension. once tight tighten screws to hold on bar and spin chain by hand should be able to spin chain if not it is to tight. hope this helps
Jan 17, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
We used our Husqvarna for about 20 minutes when it stopped rotating. Turned it off and was idle absolutely fine but the chain still won't turn. Sorry, don't know the model, but it's brand new....??
on some of the new chain saws there is a safety switch on the guard in front of the handle, it goes forward to lock the chain and pull it back to unlock the chain sometime make sure it is in the it is pulled back and check to see if it is still hook up to the switch.
Feb 20, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna chain saw starts and runs for 20 minutes then stops.
two things could be happening.......first is vapor lock......make sure you breather tube is clear and working........next is ....it could have a bad ignition coil on it.....after the coil gets hot the spark can become irratic or just not work any more.....
Feb 21, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Saw runs for 3-4 minutes then dies
check the spark plug
change the seals with new ones
check compression
regards Mihai71
Nov 26, 2008 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Garden Logo
260 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
