Question about Zanussi TC7102W Electric Dryer
Drier spinning but doesn't get hot/warm. - Zanussi TC7102W Electric Dryer
  • 4,323 Answers
Hi
If the dryer is not drying the clothes then you would need to check for the following things—
Electric Dryer---
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps...
Daniel
Posted on Sep 04, 2010
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
ZWD 1662 W start/Pause button flashing but not connecting to programme
hi,if this is the washer drier type try this,unplug m/c!! take lid off and locate the four connections to the drier unit near the back panel.some connections will be double tagged others single tag.disconnect all four connections and let wires dangle down a bit ,they shouldn`t touch anything.plug m/c back in and try a program such as drain and spin,and then if ok try a fill.the reasoning behind this is that the drier element goes faulty and gives a false reading to the control pcb.if this is successful ,replace the drier element.another option if any of that doesn`t work ,check carbon motor brushes.
Jul 22, 2014 | Washing Machines
My unit will not go below 41 degrees...
I would remove the compressor cover panel and check the condenser coils for being clogged with dirt and dust. Clean if needed. While in there check to see if the compressor is running hot. Operating very warm is normal but too hot to touch is Bad. If that is not the problem, I suggest recovering the refrigerant gas in a tank and replace the receiver drier by welding in a new drier and recharging the system with new clean R134A gas
Feb 08, 2014 | Frigidaire 4.6 Cu. Ft. Beverage Cooler
Mtd4 mistral
Underneath where the motor is,, there is a locking mechanism, which is operated by a cable connected too the lid, check cable hasn't snapped or come off,, it's adjustable also,, may just need adjusting
Jun 17, 2013 | Creda S202pw Debonair Spin Dryer Drier 9lb...
Hello My drier has stoppped warming the clothes, it is still turning - but no heat. Whirlpool Gold Model no 3RLEC 864 6K 08 Thanks Rheinallt Williams
dear Rheinallt , the problem is one of two things either the thermostat or the element itself . Try the drier on different heat settings to see if it heats at all . If it does - then its the thermostat . if it doesn`t then it most probably is the element . Depending upon where you live it would probably be more economical to buy a new one .
Aug 13, 2011 | Whirlpool Dryers
My drier gets warm but not hot???whats wrong....I check exhaust system cleaned it and vent system too. power is normal I put it on express drying too and warm not hot?
Most electric driers have two heater coils, inside that provide heat to dry the cloths. Wires like in a light bulb only bigger. I suspect one of these coils is burnt out and thats why it is only getting warm not hot. Also be sure to remove the hose from the back of the drier and check for a restriction there.
Oct 08, 2010 | Kenmore 63942 Dryer
Frigidaire front loader - clothes come out very dry
be sure and ckd fill hoses the screen on cold hose may be plugged the first bit of water is usually hot or warm to flush detergent the remainder is warm or cold also cold is normally used on all rinse
Jun 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Zanussi TC7102W Electric Dryer Logo
88 people viewed this question
Top Zanussi Dryers Experts
Tim Whalen
Are you a Zanussi Dryer Expert? Answer questions, earn points and help others
