Question about HP Deskjet 6980 InkJet Photo Printer
Message says top is open when it is securely closed
Is there some way to override this or adjust the lid somehow so the printer recognizes the closed lid?
    Genius:
  • 2,785 Answers
Its seems there is a mechanical problem with your printer send it for servicing
Posted on May 13, 2008
Help "Closing" Conveyance Door
Their is a switch letting it know that it is not closed.
find the switch and either adjust it so it closed the contacts ,when the
door is closed,. or temporarily jump it out to confirm that it is the switch. Sometimes switches can be shimmed up with tape etc.
Jun 03, 2014 | Konica Minolta Konica 7020 W/fax Kit...
I have replaced the color cartridge and now the printer does not recognize color. Can you please help me on this?
Hello
Turn on the printer and check the LCD screen for messages. If your printer isn't recognizing what you know to be a new cartridge, the "Low Ink" warning will still be on the screen. Press the green "OK" button for now--if you want the message to reset later, just open and close the lid.
Try printing a test page. Sometimes the ink cartridge simply has a faulty chip and the printer cannot recognize the ink levels.
Open the lid via the handle under the copying tray and remove the ink cartridge in question. Check the bottom for the plastic tab. This tab must be removed or the printer cannot recognize the cartridge. Sometimes when the tab is pulled off, a small strip remains, and this can interfere with printing. Hold it in good lighting and use your fingernails or a knife to gently pry off any remaining bits of the plastic tab. Replace the cartridge, close the lid, and print a test page.
Call the store or website customer service where you bought the ink if the above steps do not work Tell them what you tried, the exact error message your printer is giving you, and when you bought the ink. If it's within 30 days of purchase, they probably have a return or exchange program.
Oct 04, 2010 | Lexmark Office Equipment & Supplies
U130 ink message on pixma mp620
Very simple solution: When the pixma mp620 screen shows error U130, Hold down the stop (red triangle) key for about 7 - 10 seconds. This overrides/turns off the ink monitoring function. The printer will begin "thinking" for a bit and then start printing. Note: you may have to do this seperately for each color. You'll also notice that when the lid is open and the cartridges are in position for changing, the cartridges that used to be "out" are no longer flashing red, nor a stead red. They are dark.
Feb 17, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Mp145 E5 problem
Cannon has made their ink cartridges in a way that you have to buy new ones every couple of refills.This is a way to bypass that..worked on my MP145.
Reset Ink level Canon Printer Cartridges PG-40, CL-41, PG-50, CL-51, CL-52
To reset the ink Level (method 1)
  1. Paste with a thin strip tape the upper horizontal row contacts
  2. Insert the cartridge into the printer and close the lid.
  3. The printer will now on the move, but wait until there on the screen Your computer is the message that there is a wrong way to a Ink cartridge is loaded. Click OK in the message
  4. Open the lid of the printer and remove the cartridge from there.
  5. Download Now the strip of adhesive tape and paste it contact now on the Second row (from top) horizontal contactjes. (Picture 2)
  6. Insert the cartridge into the printer back again and closed the lid. Weather will The printer is on the move again, and again we place an alert on Your monitor. This time, the message that the cartridge can not Be recognized. Click on OK again
  7. Open the printer and remove now for the last time the cartridge from the
  8. Remove the tape and insert the cartridge in the printer and connect it Lid.
  9. The printer is the cartridge back as a new and indicates that the cartridge full again
Resetting the ink Level (method 2)
Works only in some cases
  1. Paste with a thin strip tape the bottom row of horizontal contact The cartridge off
  3. The printer will now on the move, but wait until there on the screen Your computer is reported that on one wrong way Ink cartridge is loaded. Click OK in the message
  5. Download Now the strip of adhesive tape and paste it contactjes now on the Contact uppermost horizontal row.
  7. Open the printer and remove now for the last time the cartridge from the Printer.
if that doesnt help... u will most likely be required to call canon...
thank you for using Fixya....
A very Helpful rating is appreciated...
have a nice day
Jul 11, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Mp 145 errors E 5
ud semua cara sy coba g mau juga mas, tlng bantuanya mas.
Apr 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Deskjet 5650 broken door latch
I have seen this problem with this series of printer. (all the ones shaped like this ie. 5150) The lid will not close all the way on the right side (this is where the lid triggers the door open/close sensor flag). Somehow the sensor flag gets out of alignment over time where the top can't close properly to trigger it. The simplest solution is take something and wedge it where the tab from the lid would come down and make contact with this sensor flag. Print with the lid open or set the lid down on whatever you use to trigger the sensor flag. Hint: when testing and problem solving in house, I use a small piece of paper folded up several times to trigger door open/closed sensors that way I can watch the printing process and diagnose problems.
Inkworks
866-381-0541
Nov 03, 2008 | HP DeskJet 5650 InkJet Printer
Hp deskjet5650
When closing the cover very slowly do you feel at the very bottom before it "closes" a slight resistance?You should have to push it down to finish the movement. Simply let the lid rest on your fingers and lower it into place, if there's no resistance just at dead bottom then the physical tab attached to the pegs of the cover may have broken off. The swich to "close lid" is probably internal by the lid joint.
Check to make sure the print carriage isn't snagged either. any little piece of anything can cause problems.
Good luck.
Sep 05, 2008 | HP DeskJet 5650 InkJet Printer
My printer doesn't recognize that I've closed the scanner lid
there is a switch on the lid, look for a protruding piece of plastic which corresponds to a hole in the machine if you put a flat screw driver ( or a business card ) in the hole it should push on a micro switch, if the message goes away when you do that then the switch needs to be adjusted, remove covers and adjust lever.
Feb 11, 2008 | Lexmark X1150 All-In-One InkJet Printer
Getting a "close document feeder message" on my HP office jet 7300
open feeder and check the back where the hinges are you will see a plunger or switch there. manually push on it and see if it changes, if it says close when it is pushed, needs to be adjusted or changed.
Nov 27, 2007 | HP OfficeJet 7410 All-In-One InkJet...
HP Deskjet 6980 InkJet Photo Printer Logo
Seeker5211
Seeker5211
