Question about HP LaserJet 1300 Printer
When the printer has big green light and a orange light what does this mean?
  • HP Master
  • 5,166 Answers
Do you mean that the orange attention light is lit and the Go button/light is lit? If the attention light is blinking, then the printer is in manual feed mode or out of memory.
Put in the media and press the Go button. To reset the media selection, go to the Printer Properties. When printing from an application, click Print and then Properties. From the Printer control panel (Start > Devices and Printers (on recent Windows versions) or Start > Settings > Printers (on older OS versions - prior to XP).) In either case right click on the printer icon and choose Properties or Printing Properties.
If you have too large a file (too many large images) and are out of memory, stop and cancel this file in the print spooler. Then reprint with a lower resolution. (This is in the Print Quality options. See the above and then the Paper/Quality or Finishing tab) Options will vary depend on the OS. Alternatively, add memory to the printer.
If the Ready light is also lit, the error depends on the pattern. If the lights are blinking in rotation, then the printer is initializing or printing a test page. If the lights are steady, you have a fatal error. Try unplugging the printer for at least 5 minutes (remove all cords from both the wall, computer and printer for the best chance of clearing the error.) If the error persists, the printer needs service. If all of the lights are blinking together, than you have an accessory problem. Try removing the memory. You may be able to reseat the sticks; alternatively replace the memory.
I hope this helps.
Posted on Sep 03, 2010
Orange light on lexmark E260D printer is on steadily & green light on as well & will print, but orange light stays on. what does this mean & what do we do to resolve issue?
We would like to know more about the lights you're referring to. The lights are represented by Error, Jam, Load Paper, Toner Low, Ready and Continue (green button).
Since the printer will print, for us to give the common light sequences, please provide us information which light is orange on the printer.
For further assistance, please call Lexmark Technical Support.
Jun 08, 2011 | Lexmark E260dn Laser Printer
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Canon Pixma IP4000 - Printer on/off button flashing orange light X 5 and then green. I have just re-newed all the ink cartridges Can you help ? will i be able to re-set printer ?
5 times orange means you need to replace the print head.....if the led are Blinking in Orange and Green Alternately you need to replace the sheet feed unit.
Mar 28, 2011 | Canon PIXMA iP4000 InkJet Photo Printer
What do it mean when a orange light comes on
It depends!!
At times paper jam and also at times ink cartridge is low or defective.
Also wrong position of cartridge gives that error.
Jan 14, 2010 | Canon BJC 3000 InkJet Printer
I70 wont print & Printer Head won't return to the centre
The first error was waste ink near full which you can bypass with resume button, now the absorber is full which means it won't print until you have the drain pack replaced and the counter reset by a shop.
Aug 01, 2009 | Cannon i70 Printer
5 orange light flashes and 1 green light flashes ???
Hi There, 5 orange light flashes and 1 green light means that the printer is not recognising the cartridege. Iam having the same problem with mine and Iam currently trying to find out why. I have installed the correct cartridge so I'm not sure why it isn't recognising it. but once i know i will let you know
Jun 12, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Error lights
Dear mary,
Blinking in Orange/Green or jus Orange is one of error indicator of canon inkjet printer. You need to specify how many times it blinks to get more help. Find how to identify error indicator here. Read more article there and you will get what I mean.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 21, 2008 | Canon PIXMA iP1600 Printer
I need to know what the error codes 5100, and 5700 mean, and what causes those errors to come up on the screen. Thank you
Try resetting the printer:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Jun 20, 2008 | Canon PIXMA iP90 InkJet Printer
HP LaserJet 1300 Printer Logo
157 people viewed this question
Seeker5211
Seeker5211
