Question about Brother MFC 420CN All-In-One InkJet Printer
I have a Brother MFC 420CN and I need Control Centre software to download. Where can I find it?
Mix-it-up
  • 832 Answers
SOURCE: Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Posted on Oct 23, 2007
Mix-it-up
  • 832 Answers
SOURCE: Double prints or Text shadow printing by MFC 420CN
yes. you have to run the alignment feature. press ink - set - arrow-down til alignment. After alignment test print read the paper and choose the right setting by nr.
Posted on Apr 09, 2008
cene765
  • 787 Answers
SOURCE: I have a brother mfc-420cn. I am getting a unable to clean messa
Do you mean "unable to clean"?If it this follow this instruction.
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41 or 4F the print head is defective.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If numberis over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Posted on Nov 02, 2009
pineworks
  • 4041 Answers
SOURCE: Brother MFC-420cn Message appears,
Hi you can try this is for your error and please call back and let us know if it worked for you so others can do the same.Solution:
  • Machine off
  • Switch on the machine while holding down the “menu”button until all the leds are flashing on/off. Now you are in “maintenance” mode.
  • Press 80
  • Press the “mono start” button several times until you see “purge: xxxx”
  • Press “2783” in order to reset the purge counter. You will see: “purge:0000”
  • Press the "stop" button.
  • Press “99” to exit the maintenance mode.
All the Best: Pineworks
Posted on Jan 30, 2010
pineworks
  • 4041 Answers
SOURCE: Just replaced ink cartridges on my Brother MFC
Hi there you can refill Brother cartidges, like other printers it will not have it sorry.
This is the only way you can trick it.
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 04, 2010
How can I scan more than 1 page from my printer brother 420cn
If you use the auto document feeder, the scan function will scan each page. If you are using the glass platen then in the scan software (control centre 2.0), select a multi-page option in the "save-as" file type box. The software will prompt you for the next page after each is completed until you choose "finish". Details are in the software user guide... http://download.brother.com/welcome/doc000240/BH3_UsaEngSoft_C.pdf
Apr 08, 2015 | Brother MFC 420CN All-In-One InkJet...
Please , I need drivers MFC-420CN
You candownload the Brother printer drivers from their support WEB site. Please clickon this link and select your model printer to download :-http://www.brother.com.au/ProductsSolutions.aspx
Feb 11, 2011 | Brother MFC 420CN All-In-One InkJet...
Anyone has any idea how to use my MFC 420CN scanner with Windows7 OS? Can't install the software that came with the printer as it is not compatible with windows7.
Click here Click on above link and download driver for windows 7 then install it in computer.First uninstall old driver from start menu->control panel->program and features. Then install driver from above download. Let me know if you need further assistance. Thanks for using FixYa.
Oct 05, 2010 | Brother MFC 420CN All-In-One InkJet...
Need to download driver for MFC 420CN for windows 7 system
Hi vernherbert,
So, you need to download the driver for your Brother MFC 420CN printer for Win7? No problem there! Go here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_index.html?reg=us&c=us&lang=en&prod=mfc420cn_us&dlid=&flang=English&os=74&type2=1
Copy and paste that right into your browser and that will take you to the Brother Solutions Center site to download the full driver software you need for Win7.
Good luck and let me know if that solves your problem,
Dragon PC Training & Repair
Jan 08, 2010 | Brother MFC 420CN All-In-One InkJet...
Want to print with black ink only using Brother MFC-420CN
I see it's been a while since you posted your question but in case anyone else is wondering about this, I'll answer.  The information is not in the User's Guide booklet but in the Software User's Guide which should be available on your software disk, or you can view it here http://welcome.solutions.brother.com/BSC/Public/files/dlf/doc000240/BH3_UsaEngSoft_C.pdf
Basically, you go to the advanced tab under the printing preferences and select grayscale.
Dec 17, 2008 | Brother MFC 420CN All-In-One InkJet...
NEED HELP NOW!
you can purchase the ink here: http://www.brother-usa.com/accessories/Accessories.aspx?Model=MFC420CN&ACASCID=30
you can download the software for your Brother MFC 420 CN printer here:
http://welcome.solutions.brother.com/BSC/Public/Templates/DownloadTop.aspx?NRMODE=Published&NRNODEGUID={2C7B4D65-D5B3-47BF-958E-322BE5EFDCA8}&NRORIGINALURL=/bsc/public/us/us/en/dlf/download_top.html%3freg%3dus%26c%3dus%26lang%3den%26prod%3dmfc420cn_us&NRCACHEHINT=NoModifyGuest∏=mfc420cn_us®=us&c=us〈=en
Oct 27, 2008 | Brother MFC 420CN All-In-One InkJet...
Software
www.brother.com
plz choose your country, your mfc and download the whole mfl-pro driver suite (unfurtunately only without paperport)
Apr 03, 2008 | Brother MFC 420CN All-In-One InkJet...
I need new software for my copier to work with new computer
Try MFC-420CN Downloads and click on download, or go to www.brother.com and browse through their printers for your model.
Nov 29, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
52 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
