Question about BenQ FP767 17" LCD Monitor
Display POWER LIGHT IS ON BUT NO DISPLAY ..
  • angel rodriguez Jun 07, 2008
    I HAVE A BENQ FP767. WHEN I TURN IT ON I GET A GREEN LIGHT BUT IT TURNS ON AND OFF. I READ ON THE BOARDS TO TEST transistors 2SC5707 AND FUSE. HOW DO YOU TEST THEM AND WHAT ARE THE SPECIFICATIONS FOR THEM SO I WOULD KNOW WHICH ONE IS GOOS OR BAD. THANK YOU
  • angel rodriguez May 11, 2010
    WHERE CAN I GO OR WHAT WEBSITE CAN I GO TO SO I CAN PURCHASE THE transistors 2SC5707. HAVING A LITTLE TROUBLE TRYING TO FIND IT ONLINE. THANK YOU
    Champion:
  • 220 Answers
Problem is with invertor board.You need to open the monitor and check Invertor transistors 2sc5707.Test all 4 transistors and replace defective,also check /resolder associated circuitry.Also check fuse with PFxxx circuit reference no.
Samir
Posted on May 12, 2008
Testimonial: "good one!exactly ringt"
Blinking light on 20 inch apple display
Blinking light on Apple cinema display usually indicates insufficient power from the power supply. Test it with another power supply from ANY cinema display (23" and 27" power supplies are ok to test with).
Feb 03, 2014 | Apple Cinema HD 30" LCD Monitor
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
Power is on but after 2-4 seconds display turns off but power is still on where the power light is in blue.it's not in sleep mode where the power color is orange.it just goes back to normal at random...
Without looking at the monitor to confirm this, I suspect you have failing capacitors which power the HT circuit, simply, the power needed to light the display, is leaking to earth, capacitors have lost the ability to store the charge necessary to illuminate the screen, which is why it is working erratically.
You need to get this checked out by a TV technician.
Jul 23, 2011 | Acer Computers & Internet
HI, I HAVE A SYLVANIA MODEL SA 170 , I CAN´T SEE THE NUMBERS WHEN I´M IN FROM THE SCREEN, IT´S APPEARS VERY DARKS
If I understand correctly, you have Sylvania 170 timer and the display doesn't light up.
If you have different problem, add a comment.
A) If this is existing installation and timer display worked correctly before, then it sounds like timer malfunctioned or power to timer is interrupted. Check breaker, and then pull out timer and test for power.
B) If this is new installation, then 2 possible things:
1) Timer defective: exchange for new one.
2) Timer not wired correctly.
Review wiring:
Timer replaces single pole switch.
Single pole switch has two wires
Timer has 3 wires: Blue Black White
Timer has additional wire to run internal clock and to light up display.
If timer not wired correctly, then display will not light up.
Here is correct wiring:
a) Two wires from switch.
b) Connect timer-blue wire to one of the switch wires. Choose either one for now. You will have to choose other wire if display doesn't light up.
c) Connect timer-black wire to other switch wire.
d) Timer-white wire does NOT connect to either switch wire. Look in back of electric box. There are white wires twisted together and covered with wire nut. These are neutral wires. Connect timer-white wire to neutral wires. This will power the clock and display.
e) If your box does not have the white wires described in d), then connect timer-white wire to bare ground wire.
f) Turn power ON. Does display light up?
g) If display lights up, switch is wired correctly.
h) If display does not light up, then reverse timer-blue wire and timer-black wire shown in step b) and c).
Dec 02, 2010 | Zip Heaters Sylvania SA170 15 Amp Zip-Set...
Our computer (SAMSUNG type GH15LS,540N MODEL,COLOR DISPLAY UNIT) CAN NOT DISPLAYED WITH BRIGHTNESS.DO NOT SEE DISPLAY DUE TO LIGHT LACK IN MONITOR.BUT OTHERS ARE CLEAR.KINDLY GIVE A SOLUTION FOR POWER...
The light on display is produced by a lamp over or under the LCD (TFT) display, or by the heated CRT electrodes on CRT display. Your lamp or CRT may have gone damaged.
Jun 05, 2010 | Measuring Tools & Sensors
Power light is blinking but no display on SMT-170 MONITOR OR SECURITY SYSTEM. SYSTEM DUAL QUAD SOQ-080N
u have problem with Display from the Coputer not from the Moniter
try to run from baios mode
and re setupp your display
May 11, 2010 | Samsung SMT-170 PROFESSIONAL 17" TFT-LCD...
I can find nowhere on the tv that has an on off button, just got this tv
Turning the Display On and Off
There is a power switch on the bottom of the display and a power button on top. The power
switch is used to cut off power completely, whereas the power button turns the screen off but
allows the remote to continue working.
To turn the display on:
1. If the power light on the front of the display is off, turn on the power switch on the bottom
of the display.
2. Press the POWER button.
To turn the display off:
1. Press the POWER button.
2. If the display will be unused for an extended period of time, turn off the power switch on the
bottom of the display and disconnect the power.
Allso go here for full manual:
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Oct 29, 2009 | Protron PLTV-32 Television
MY toshiba satellite 2430 CAN NOT POWER UP. BUT IT ALL THE LIGHT IS ON WHEN I SWITCH ON THE DC POWER SUPPLY SWITCH. WHAT IS THE PROBLEM? HELP.
remove the battery and remove the power adaptor ... press and hold the power button in the ON position and count to 20.
attach the AC adaptor only and press the power button ...this should fix the issue ... then re connect the battery.
if this does not work then add a external monitor .. if it lights up then hit the
Fn + F5 keys
Display modes
Fn + This hot key cycles through the power-on
display mode options.
The display mode options are:
Built-in display panel only, Built-in display panel and
external monitor simultaneously, External monitor only.
Fn + This hot key cycles through the power-on display options.
The display modes are:
❖ Built-in display panel only
❖ Built-in display panel and external
❖ External monitor only
video device simultaneously
❖ External video device only
Oct 07, 2009 | Toshiba Satellite 2430 Notebook
Viewsonic Va912b monitor
it seems that there is a problem in the lcd back light or may be in power supply section
Sep 12, 2009 | ViewSonic VA1912wb 19" LCD Monitor
Cintiq 12WX screen not working :(
may be the power chord is damged go to a nearby shop and tell tham to give you a new power chord of monitor and then try it should work fine
thank for visiting fixya
have a nice day
Feb 19, 2009 | Wacom Cintiq 12WX Interactive Pen Display...
BenQ FP767 17" LCD Monitor Logo
680 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
