Question about Garmin Nuvi 660 GPS Receiver
Turns on, maps load,will not accept input for funcions
  • Garmin Master
  • 2,130 Answers
Sounds like a defective touchscreen. Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Sep 03, 2010
I have a 2003 dodge neon 2.0l 16v engine that cranks over but will not start any ideas?
P0108 (M) MAP Sensor Voltage Too High, P0118 (M) ECT Sensor Voltage Too High Engine coolant temperture sensor input above the
maximum acceptable voltage, P0123 (M) Throttle Positon Sensor Voltage High Throttle position sensor input above the maximum
acceptable voltage range, P0522 Oil Pressure Sensor Low Oil pressure sensor input below acceptable voltage. Sounds like you have an electrical problem, either computer failure or bad sensors. It's hard to believe that you gained so many sensors just from replacing the cylinder head. Disconnect your battery for one minute, then reconnect. Try driving it down the road.
Aug 11, 2014 | 2003 Dodge Neon
Quest unit not accepting map info
u need a firmware update i think
Mar 21, 2008 | Garmin Quest GPS Receiver
Which codes (OBDI or II) do I use for my 1994 Jeep Grand cherokee laredo 4.0 2wd
before 1996 they use onboard diagnosis system for jeep.
when you turn on key you need to count check engine light blinks.
here are codes taken from internet.
11* No crank reference signal detected during engine cranking.
12* Direct battery input to PCM was disconnected within the last 50 key-on cycles.
13** No difference recognized between the engine MAP reading and the barometric (atmosphereic) pressure reading at start-up
14** MAP sensor input below minimum acceptable voltage.
or
MAP sensor input above maximum acceptable voltage.
15** No vehicle distance (speed) sensor signal detected during road load conditions.
17* Engine coolant temperature remains below normal operating temperatures during vehicle travel (thermostat).
21** Neither rich nor lean condition detected from the oxygen sensor input.
or
Oxygen sensor input voltage maintained above the normal operating range.
22** Engine coolant temperature sensor input above maximum acceptable voltage.
or
Engine coolant temperature sensor input below minimum acceptable voltage.
23** Intake manifold air temperature sensor input above maximum acceptable voltage.
or
Intake manifold air temperature sensor input below minimum acceptable voltage.
24** Throttle position sensor input above maximum acceptable voltage.
or
Throttle position sensor input below minimum acceptable voltage.
25** A shorted condition detected in one or more of the idle air control motor circuits.
27* Injector #1 output driver does not respond properly to the control signal.
or
Injector #2 output driver does not respond properly to the control signal.
or
Injector #3 output driver does not respond properly to the control signal.
or
Injector #4 output driver does not respond properly to the control signal.
or
Injector #5 output driver does not respond properly to the control signal.
or
Injector #6 output driver does not respond properly to the control signal.
33* An open or shorted condition detected in the A/C clutch relay circuit.
34* An open or shorted condition detected in the speed control vacuum or vent solenoid circuits.
or
Speed control switch input below the minimum acceptable voltage.
or
Speed control switch input above the maximum acceptable voltage.
35* An open or shorted condition detected in the radiator fan relay circuit.
41* An open or shorted condition detected in the generator field control circuit.
42* An open or shorted condition detected in the auto shutdown relay circuit.
44* An open or shorted condition exists in the engine coolant temperature sensor circuit or a problem exists in the PCM's battery temperature voltage circuit.
46** Battery voltage sense input above target charging voltage during engine operation.
47** Battery voltage sense input below target charging voltage during engine operation. Also, no significant change detected in battery voltage during active test of generator output.
51** Oxygen sensor signal input indicates lean air/fuel ratio condition during engine operation.
52** Oxygen sensor signal input indicates rich air/fuel ratio condition during engine operation.
53* PCM internal fault condition detected.
54* No fuel sync (camshaft signal) detected during engine cranking.
55* Completion of diagnostic trouble code display on the malfunction indicator lamp (check engine lamp).
62* Unsuccessful attempt to update SRI (service reminder indicator) miles in the PCM EEPROM.
63* Unsuccessful attempt to write to an EEPROM location by the PCM.
* - Check engine lamp will not illuminate at all times if this code was recorded. Cycle ignition key as described and observe code flashed by check engine lamp.
** - Check engine lamp will illuminate during engine operation if this code was recorded.
PCM = Powertrain Control Module (the engine computer)
MAP = Manifold Absolute Pressure (the sensor that measures how hard the engine is sucking air through the intake manifold
EEPROM = Electrically Erasable Programmable Read Only Memory (a type of computer chip used inside the PCM)
Nov 19, 2011 | 1994 Jeep Grand Cherokee
Where I found the Pan funcion?
Here is a link to the manual:http://www.tascam.com/products/2488mkii;9,16,109,19.html Go down to Resources, Documents. As far as I know you have to map your input to a track. If you want Stereo you have to use 2 tracks. The owners manual explains it better than I can here.
Aug 24, 2010 | Tascam 2488mkii 24 Track Recording...
C330 garminstreetpilot not working
hey man your prob is so simple just go through this
1.connect your device to computer
2.go to my com
3.right click on your device
4.click format
5. then restart it now its time to update driver
right click on computer then
1. click properties
2.hardware
3.device manager
4.universal serial bus controller(open the + sign)
5.click upper one double click
6 go to driver
7.click on the update driver
8. then choose second one (advanced) then next
9.click don't search
10.then next next if it is over
same process with anotherone then restart your computer a
Nov 18, 2007 | Garmin StreetPilot C330 GPS Receiver
Navman S50 problem
get your maps reinstalled
Jun 28, 2009 | GPS
06 pt cruiser dtc p0108,p0113,p0123,and p0508 car will not start
P0108 (M)
Manifold Absolute Pressure/Barometric Pressure Circuit High Input
P0113 (M)
Intake Air Temperature Circuit High Input
Intake air (charge) temperature sensor input above the maximum acceptable voltage.
P0508 (M)
Idle Air Control Motor Circuit Low
Idle Air Control Motor Circuit input below acceptable current.
THESE DIFNITIONS ARE FROM THE FACTORY REPAIR MANUAL, LOOKS LIKE YOU MAY HAVE A WIRING HARNESS PROBLEM OR DISCONNECTED COMPONENTS, CHECK THE IAT AND MAP SENSOR AN MAKE SURE THEY ARE CONNECTED.
Mar 15, 2009 | 2006 Chrysler PT Cruiser
Will not accept pre-loaded map
bring for waranty, just changge it, or you can go to warez and download your maps and so on ;)
Feb 27, 2009 | Tomtom ONE GPS Receiver
No data available mess
Did you try to perform a map upgrade to 2008? Turn on the Garmin and from the main menu touch the wrench, then press Map, then look for Map info.
Jul 12, 2008 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 660 GPS Receiver Logo
26 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
