Question about Canon PowerShot SD1300 IS IXUS 105 Digital Camera
Canon camera lens is stuck and it's asking me to restart
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Sep 03, 2010
Lens errors are showed on screen and asked me to restart the camera, how?
Restart camera= power off and power on. Probably you have a zoom lens stucked.
Sep 27, 2015 | Canon PowerShot G10 Digital Camera
How do you restart the Canon G9 camera?
There is not way to reset it if you get “lens error”. The lens stuck, you need to send it for repair.
Aug 03, 2009 | Canon PowerShot G9 Digital Camera
Broken lens : error
The lens unit will have to be replaced. This is a factory level service. It will most likely be more feasible to replace the camera!
Jerry G.
Apr 26, 2009 | Canon IXUS V2 Digital Camera
Lens error restart camera
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Dec 29, 2008 | Canon IXY 1000 Digital Camera
I have a canon powershot tx1 and i just got a 'lens error, restart camera' message and my lens is stuck. i just bought it a month ago and haven't mistreated it at all. how can i fix it?
I have a canon powershot a470nd i just got a 'lens error, restart camera' message and my lens is stuck. i just bought it a month ago and haven't mistreated it at all. how can i fix it?
Jul 24, 2008 | Canon Cameras
Lens error, restart camera
the beeping sounds means that your camera lens is stuck. contact the manufacturer (canon), for a possible solution...or they can even send u a new one. My friend dropped her SD630 and had the same problem...she contacted canon, and sent in her camera to be fixed, but it wasn't fixable, so canon sent her a brand new camera. hope this helps.
Jun 14, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens
Switch off and on again? Take battery out and replace. Thats the only 2 ways of 'restarting a camera that I know of. Does your model have a 'reset' function? You will have to check the manual for that. Or ask Canon support.
Aug 22, 2007 | Canon PowerShot A460 Digital Camera
Restarting the camera
this would be because there is something stuck in the lens..could be the rubber protection stuck not enabling your lens to pop bback into position.i tried gently tapping the lens an gently twisting it to enable movement in my lens
Aug 13, 2006 | Canon PowerShot A420 Digital Camera
Canon PowerShot SD1300 IS  IXUS 105 Digital Camera Logo
414 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
