Question about Lexmark T632 Laser Printer
I have an error message that says 924 service Fuser Error What does that mean?
  • Anonymous Mar 14, 2014
    924 service fuser error
  • 2,296 Answers
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser yourself which costs around $350, so I think you would be better off getting a new printer unless you find a second hand fuser on Ebay.
Posted on Feb 11, 2011
2 Suggested Answers
Printtech
  • 1087 Answers
SOURCE: i have an error message
You have to replace your fuser assembly. (Assembly 115V fuser) (40X3569)
I suggest you contact Lexmark Technical Support for further diagnosis.
Posted on Jul 29, 2011
How to fix Lexmark T632 924 service Fuser error
924 is an open thermister error. The thermistor controls when power is actually applied to the heating lamp on the fuser. I used to have this problem with other Lexmark models and was able to replace the thermister itself. The thermister is located on the top cover of the fuser. If you have a real Radio Shack near you they should have them. I believe that the temperature should be around 400F.
May 08, 2015 | Lexmark T632 Laser Printer
I have a Lexmark C534n color printer error message comes up 120.10 service fuser error. What does this mean.?
It means there's an issue with the fuser, and the fuser likely needs service or replacement. I would not recommend doing this yourself if you haven't done this before, take it to a repair shop.
Feb 24, 2011 | Lexmark C534N Printer
Fuser error 924.01
924 .01
Open thermistor check
failure. Fuser page
count between 0 and
99,999.
• Noisy thermistor signal.
• Intermittent connection.
• Thermistor cable not connected or
thermistor actually open.
Go to “924.xx—Hot fuser
service check” on page 2-91.
Error Code 923.xx, 924.xx, and 925.xx may display for a hot fuser failure.
CAUTION: .The fuser may be hot, use caution before removing or servicing.
CAUTION: There is a danger from hazardous voltage in the area of the printer where you are
working. Unplug the printer before you begin, or use caution if the printer must receive power in
order to perform the task.
Service tip: Set the Fuser Temperature to NORMAL before starting this service check. In Diagnostics mode, In
Diagnostics mode, select EP SETUP, and Fuser Temp.
1 Fuser assembly
Fuser to system board
cable
Check the thermistor cable for correct installation to J5 on the fuser
card. If installed correctly, check for correct installation of J10 on the
system board. If all cables are installed correctly, go to step 2.
2 Fuser top cover assembly
(thermistor/thermistor cable
assembly)
Turn the printer off and disconnect the thermistor cable from J5 on
the fuser board. Measure the resistance between the two pins on the
thermistor cable, if the resistance measures infinity (open circuit),
replace the fuser top cover assembly.
3 Fuser to system board
cable.
System board
Fuser assembly
Reconnect the thermistor cable to J5 on the fuser board. Disconnect
the fuser to system board cable from J10 on the system board and
measure the resistance between J10-3 and J10-4 on the cable. If the
resistance measures infinity (open circuit) check the continuity of
pins 3 and 4 of the cable. If correct, replace the fuser assembly. See
“Fuser assembly removal” on page 4-26. If incorrect, replace the
fuser to system board cable.
Note: If the error code still displays, replace the system board. See
“System board and inner shield removal” on page 4-76.
Most likely just replace the fuser (part of usage kit)
Enter Diagnostic mode:
1. Press and hold (Down Arrow) and (Up Arrow).
2. Turn on the printer.
3. Release the buttons when Performing Self Test displays.
Mar 29, 2010 | IBM Infoprint 1572 Laser Printer
We have a Canon IR400S with the following error message - Switch main power on & off, E005. Switching power on & off did not clear error. Can you tell me what the error message means?
The error message means that the Fuser web has a problem. This is the part that cleans the upper fuser roller on the copier. It's located inside the left door of the copier and more than likely requires a copier technician to replace it. Fuser webs(belts) gradually get consumed after about 100,000 prints. The other possibility is that you may have had a brown-out or some other kind of power fluctuation in your area and the error just needs to be reset in service mode, but I'd check the first solution 1st, the part is cheap $25-$50.
Dec 10, 2009 | Canon Office Equipment & Supplies
Fusher eror 924
924 Fuser Error - Open circuit detected in thermistor circuit. The thermistor provides feedback on the temperature of the fuser roller and when it fails, the fuser normally does not heat up.
It means either disassembling the fuser and replacing the thermistor ( if you can find one) or replacing the fuser assembly.
so i would suggest that take it to nearest service centre of lexmark. best of luck
Oct 27, 2009 | Lexmark T430 Laser Printer
Fuser error on my ibm infoprint color 1464
The error is Fuser cam position not found. Have you tried reseating the fuser? Does the fuser make any loud sounds? Based on the error message, it could either be the fuser, or the system board.
Apr 08, 2009 | IBM Infoprint 1116 Laser Printer
123 Service Fuser Error - Lexmark C762 Colour Printer
This error refers to a thermistor error with your machine (assuming that you meant 923 error and not 123 error). Chances are that you will have to replace your fuser. Part number is: 56P2851.
To replace open the right side door (the one with the blue handle) and the lower door below it. Your fuser is the one with the 2 blue clips. Pull clips down and remove fuser. Replace fuser and push clips into locked (upright) position and that is it.
Hope that helps.
Mar 19, 2009 | Lexmark C762 Laser Printer
LEXMARK T620 FUSER ERROR 924
Explanation
A 924.xx error message indicates that an "open circuit" has been detected in the fuser unit.
What to do
  1. If this is the first time you have seen the error, turn the printer off.
  2. Leave the printer off for at least 10 seconds to give it a chance to reset, then turn it back on.
  3. If this does not clear the fuser error, the printer will probably require service. The parts most likely to be causing this error are the following:
    1st, the fuser unit ( this is the most likely of the three )
    2nd, the system board
    3rd, the low voltage power supply unit.
    These parts will need to be inspected by a service technician and replaced as necessary.
    IMPORTANT!
    If this is an intermittent error, you may want to check how the printer is plugged into the wall. Make sure it is plugged straight into the wall and not through a surge device or power strip. Power strips and uninterrupted power supplies can cause a low amperage problem in the printer which can trigger a false fuser error. This is true even if the printer has worked on this surge device previously.
Sep 26, 2008 | Office Equipment & Supplies
I have a Lexmark X422 It has a error message when I try to print anything. It says 922 service fuser error
This means Fuser failed to reach
standby temperature.
The only answer is to replace the fuser, part number 56P0648 110 VOLTS, 56P0671 220 VOLTS.
Please advise if you require instructions
Aug 04, 2008 | Lexmark Office Equipment & Supplies
Lexmark T632 Laser Printer Logo
932 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
