Question about Acer (AV120) Computer Speakers
Problem for computer speaker
My speaker is not working.all the cables r connected properly.
control panel is showing no audio device is connected. can u help me?
  • 2 more comments
  • mcdo-mpc Aug 27, 2008
    computer speaker no sound at all
  • sridharran Sep 03, 2008
    my computer speakers are not playing.i try to adjust the volume but it is not working,also i try to adjust the speakers volume but still it did not help.it says no audio device.every thing is connected please help.
  • munybvt Nov 13, 2008
    the speker deosnot work no sound is coming out
  • 1sweetlady May 11, 2010
    well on my acer computer my speakers will not make a sound . they work on my other computer but i can't figure out what went wrong with the speakers.
  • 35 Answers
Hi chaitraraj,hope you connected the cables in the ryt connectors if yes does your pc show volume level indicator?if not you have to reinstall the audio driver of your motherboard.let me know if this helps.
Posted on May 11, 2008
Speakers will not work on e machine et1331g but are installed
Hi,Dear User..Flow instruction:-
1> Check you speaker all connection point.2> Check you connect speaker lead out put Point.3> Power point Check to speaker.4> Installed Audio driver to mother board. Not any other Driver install only proper driver.5> If driver install then check it. a> Go to control panel- Add or remove program, hear show audio driver or not. if not show then install.
b> My computer right click- property- hardware- device manager, if audio point yellow then install driver. if not yellow then install driver.
6> If all thing check then you speaker not support in you PC.
Note:- Batter then Contact good Computer Hardware Engineer.
More Computer Support.
Thanks...
Feb 13, 2013 | E-Machines eMachines Desktop PC
My speakers are not working. I made sure everything is connected properly. The speakers do not even show up under my sound device panel.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Aug 05, 2011 | Dell A215 Computer Speakers
I have no sound. my speakers are ok.
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
hope this helps
Apr 14, 2011 | Computers & Internet
Speakers not working, but cables all plugged in...
You will pobably need to load the driver for your system.
Go to Dell Support and click on the Drivers & Downloads box.
Follow the prompts to select your specific system model. you will end up at a page that lists all the available drivers for your computer. Click the + sign next to "Audio" and you can select "Download Now".
When the download window opens, select "Install".
Dec 14, 2008 | Microsoft Windows XP Professional for PC
You might have to reinstall the software that came with the speakers since you had to wipe your computer clean when the virus was on there. The speakers will not work until the software is installed back on your computer.
Oct 21, 2008 | Logitech S200 Computer Speakers
Please help me
If after connect your usb speaker cable the system it is asking for software (drivers) you have to install them to get your audio working properly. Check it out the box of your new speakers for a installation CD.
You can also verify:
Check if your audio es working properly (start >> control panel >> sound and audio devices)
Check if your sound card is properly installed (My pc >> Properties >> Hardware >> Device Manager >> Audio)
Oct 05, 2008 | Audio Players & Recorders
Computers
Then go to control panel,system ,hardware ,device manager option
There if u find any question mark or exclamation mark in yellow Color that means sound drivers are not installed properly
please reinstall sound drivers properly
or else
If no question mark or exclamation mark then check the cable connections of the speaker to the machine
or else
In control panel , select sound audio devices open it there u have
volume,sounds,audio,voice,hardware options
1)See whether it is mute
2)In audio option select default audio device and recording device
should be same
this should solve u r problem .if it is not solved please let me know u r problem briefly
or else put the model number and brand name followed by drivers search in ww.google.com
Aug 18, 2008 | Computers & Internet
No sound comming out of my computer
or else
or else
should be same
Aug 15, 2008 | Computers & Internet
No sound device found
check for devices in "other devices" in Device manager
Oct 22, 2007 | Computers & Internet
No drivers for your soundcard, this is a computer issue not a speaker issue, contact dell, if you can understand a word they say, ask them "I have Dimension (model number here), I need to know how to install my sound drivers", if you dont know how to do this.
Jun 21, 2006 | Dell A215 Computer Speakers
52 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
