Question about Philips DVD740VR DVD Player/VCR
I have an aucma dvd player which does not play dvd but reads cd-r and vcd what could be the problem?
  • 79 Answers
SOURCE: AFTRON PORTABLE DVD PLAYER WON'T PLAY DVD
AFTRON PLAYER PROBABLY USED CHEAP LASER AND NOW HAS GOTTEN WEAK AND GONE BAD. I THINK THAT IS THE PROBLEM.
WHY ARE YOU USING ALL CAPS-LOCK??? THAT IS VERY RUDE
THANKS FOR READING
Posted on May 01, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: mp3 disk no audio when playing
First, make sure the CD is an AUDIO CD, and not a DATA CD
If you have recorded a Picture CD or MP3 CD
yourself, ensure that your disc contains at least 10
pictures or 5 MP3 tracks.
MP3(ISO 9660) 96, 112, 128, 256
kbps & variable
bit rate fs, 32, 44.1,
48 kHz
– MP3 discs, picture (JPEG) files
on CD-R(W).
– JPEG/ISO 9660 format
– Maximum 9 characters display.
– Supported sampling frequencies :
32 kHz, 44.1 kHz, 48 kHz (MPEG-1)
16 kHz, 22.05 kHz, 24 kHz (MPEG-2)
– Supported Bit-rates : 32~256 kbps
(MPEG-1), 8~160 kbps (MPEG-2)
variable bitrates
Posted on Sep 04, 2008
  • 6 Answers
SOURCE: player won't play any disks only says CANNOT LOAD DISK
http://forum.videohelp.com/topic350059.html
I think I found these adjustments! There are two tiny surface-mount potentiometers (could be capacitors also) sitting in the small circuit on laser assembly.
this is exactly response I would like to hear - an expert opinion!
What I did with help of 1mm-wide screwdriver:
1) There were two surface-mount potentiometers marked with C1 and D. I tried first D. Turned it clock- and counterclockwise by about 45 degrees.
2) After each turn I opened and closed tray to force the player read DVD disc.
3) It did not help, "NO DISC", then I tried the same with C1, and again, no luck.
4) Finally, I came back to D and turned it by about 180 degrees in one direction. IT WORKED!!!
Moreover, seem that now player reads content of the DVD discs faster then before. Probably manufacturer did not really adjust it properly and upon the time something has degraded, so it failed eventually.
Some Home dvd players may not have any adjustment abilities, but you would find such things not too far away from the lense, if they don't exist, get a new unit.
Posted on Nov 27, 2008
  • 6 Answers
SOURCE: does not play DVD,Vcd,video formats but Plays mp3
  • 45 Answers
SOURCE: Disc error when reading dvd
If cleaning of the lens did not help then it is possible that the laser beam torch needs a replacement. Different formats need different strengths of the beam and the torch would need to be replaced.
Posted on Jan 15, 2009
ONIDA DFX-7100 DVD player unable to play VCD/CD
dvd player s-video pin use to tv tuner card
May 18, 2010 | Televison & Video
My IBM R51 laptop can't read any other cd/vcd
its either its a lens problem or that was how the CD/DVD Drive was made.
There are some drives that doesn't play white face discs, that is, they select disc and don't play all CD's, so maybe yours fall under this category.
How long have you been using your laptop and has it ever played Cd/Vcd's before?
If it plays them before, then it means your drive's lens is weak, but if it has never played them before, then it means that's how the player was made.
Which ever way, you still have an option of replacing the drive if you wish.
Take care.
Apr 14, 2010 | HP Compaq nx6115 Notebook
Acer LAptops Optiarc DVD Player plays VCD but no DVD.
Only way to make sure it's the drive is to test it in another machine. If it's the drive just buy a new one, it'll cost more to repair in time alone!
Dec 14, 2009 | IBM (33P3297) DVD Drive
Unlock my DVD player to watch VCD's.
VCD's do not have "regions" specification. The DVD player either can play VCD's, or cannot play VCD's. It's a format that is not very popular among manufacturers. I have two players that both play my VCD's, but I had to make sure they accepted that format before I bought them. This player accepts DVD and CD's but it did not say VCD's. It's kind of a proprietary format that was only really popular overseas. The PHILIPS DVP5140 is one that I just found that does play pretty much everything.
Oct 28, 2009 | Televison & Video
I just don't know what program and format to use so I can listen on my AVH-P4900
It can play Audio CD, MP3, WMA, including formats like Video CD (VCD), DVD, Div. It has 4 channels, with In-Dash Player, In-Dash Monitor. Th inputs it recognizes & plays are DVD Video, VCD, SVCD, DVD-R, DVD-RW, CD (Audio), CD-R, CD-RW. In the radio you can hear AM, F. It has a 6.5 inch dipla. A quote from their website reads "The AVH-P4900DVD lets you take your digital music files with you, whether they're MP3 or WMA format. Burn files onto one CD-R and play them in any mix you want. Use the touch-panel to easily navigate through your file and folder lists to find exactly the song you are in the mood for." I hope this is enough to answer your query!......sodeep
May 08, 2009 | Pioneer AVH-P4900 Car Video Player
Kenwood DVD player 5 speaker system
There is nothing wrong with it, it is set to only play in the region it was purchased from. That is how all DVD players are made, with regional settings. No repair is going to help, you just need a DVD player from the proper region to play those disc's.
Nov 05, 2008 | Audio Players & Recorders
Cd player reads disc error
maybe you need to change the optical eye now.
but first try to adjust the variable resistor/trimpot resistor.
try this options to your player.
(TIP)
if using a cd/vcd/dvd products, we only should play a cd/vcd/dvd dics without a bad scratches. the scratches are making the optical eye worn-out easily.
Jan 28, 2008 | Tascam CD-A500 CD Player
When playing DVD no sound but VCD sound OK.
dvd are up to 6 times the density of a cd there making the laser eye read much closer rings on the disks. so in other words its having a hard time reading dvd. the only thing you can do is take a cotton swap dipped in alcohol and open the tray look with a flashlight for a small optical eye in exact center of dvd player and rub lightly on it to remove dust build up or spray some canned air into the dvd youll hit it. try it again and if no sound again the computer cant keep up with the dvd or vise versa.
Aug 21, 2007 | Sony DAV-X1 System
Sony dvp-ns425p will play regular CD, but won't play any DVD
just open the player (4-6 screws) and clean the lens. I had a similar problem (plays VCD, CD but no DVD - tray will open immediately). It worked afterwards
Aug 14, 2007 | Sony DVP-NS425P DVD Player
Philips DVD740VR DVD Player/VCR Logo
75 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
