Question about Maxon MCB-30 40-Channels Base CB Radio
I was given a maxon mcb30 and wanted to hook it in my car, no book with i,t what is the orange wire for?
  • deandowdall Sep 04, 2010
    thanks for all your help.100% good
  • 1,274 Answers
Hi, my name is John. The orange wire is for the (+) hot ....hope this was helpful....
Posted on Sep 03, 2010
  • 2 more comments
  • deandowdall Sep 03, 2010
    Thanks John, if the orange is what is red
  • JOHN BABA Sep 03, 2010
    Red is also hot have (2) two hots and (1) one wire.......please rate this solution......thanks John....
  • JOHN BABA Sep 04, 2010
    Hi Dean, You rate by clicking the 4 thumbs up on the thumbs to your right....thanks John
  • David Schlein
    David Schlein May 25, 2017
    The red is hot the orange is hot but is meant to go to accessory fuse so it turns off when you turn off the ignition.
How do you install a Maxon radio repeeter. It only has two wires that apear to be a Hot(Red) wire and a Black(ground). Should I just ground it and hook it up to a power suply?
Your correct the red wire is the positive and the black is the negative. You must also make sure to use a power supply with enough current to operate the radio. Usually a 12 volt supply that supplies about 4 to 8 amps should do the trick
Oct 29, 2011 | Maxon MCB-30 40-Channels Base CB Radio
Microphone din pin wiring for mcb30
Look at Defcom Radio mods or other sites. Snake doctors radio mods. Look up Microphone wiring for Maxon MCB-30. Just type it in to
May 01, 2011 | Maxon MCB-30 40-Channels Base CB Radio
I don't know how I copied and pasted so much sorry about that. But my question is I have orange and red wires with fuses and black wire without do I hook both red and orange to hot and black to ground?
it depends on what radio if you have a cobra 18wx style or maxon's, or a radioshack type the red is constant power 12v, orange is a switched 12v.. IE key like a stereo, and black is ground. if you have a 25 or 29 ltd types or exports they only have 2 wires red 12v and black ground. but you do find some power cords that have all three, and the orange on the 25 / exports are not used.
Feb 09, 2011 | Cobra 25 WX-NW-ST 40-Channels Base CB...
What is the orange wire for
Hi, my name is John. Welcome to FixYa. The orange wire is a hot (+) wire just like the red wire, and the black wire is the ground (-) wire. Thanks for choosing FixYa....John
Sep 28, 2010 | Maxon MCB-30 40-Channels Base CB Radio
On a Maxon MCB-30 cb radio, there are three wires. Red, Black and Orange. Red and black are the power and ground, but whats the point of the orange wire and what do you connect it to?
Hello stud
The orange wire is for memory retention for the last channel you were on if the red wire loses power as in switched on and off with the car ignition just hook up the orange to a 12 volt source that is on all the time. By the way those are some neat little radios wish I had one.
May 05, 2010 | Maxon MCB-30 40-Channels Base CB Radio
Maxon mcb30 which way to turn the mod
RV 2 is the modulation pod that needs to be turned
Mar 18, 2009 | Maxon MCB-30 40-Channels Base CB Radio
Have a Maxon CB Model MCB30 that has a resistor that is red hot resistor part number R999 Any idea as to why this is happing and what the value of the resistor is as the color code has burned off and it is...
Hello, This means that the unit is drawing excessive current which is usually an indication of a short circuit within the unit. Now since the resistor is glowing red hot this narrows down the possible causes. I would suspect the RF amplifier stage as the possible cause, more to the point the RF amplification IC or FET is the item that has shorted out. I would also advise checking the audio signal amplifier to. You will need a schematic diagram of the CB, a Multimeter, an antenna dummy load, and a 12V power supply. If you have a background in electronics this task should be doable, if not I would suggest that you take the unit to a qualified technician for servicing. I hope this helps, Thank you, Shuttle83
Mar 17, 2009 | Maxon MCB-30 40-Channels Base CB Radio
red is positive, orange is continuous power, black is ground.. then just the antenna and mount it
May 14, 2008 | Maxon MCB-30 40-Channels Base CB Radio
Twist red and orange together and hook to power then put the black to ground
Nov 17, 2007 | Maxon MCB-30 40-Channels Base CB Radio
Maxon MCB-30 40-Channels Base CB Radio Logo
142 people viewed this question
Top Maxon Radio Communications Experts
Mike Charette
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
