My portable AC/heater is making a LOT of noise, intermittently and loudly. Then it returns to normal volume, only to return to loud noise level later on. What might be the cause? Mobilair MA-9000AH - six years old (manufactured 2004-05-5).
  • 17,130 Answers
It can be the fan which is at times going unbalanced and vibrating the body of the unit. It will be when the fan is touchin the sides of a metal part that the noise seems to come up.
Since the noise can be traced to the source of origin, it will be good to carefully open the set out and test.
If the blade are causing the issue, clean and set, if not the bearings/bush must be defective,
Posted on Sep 03, 2010
  • notmickey Sep 03, 2010
    thanks for the quick response. I'll check that out.
My Igloo ice 102C is making a loud noise when it pumps in water to make Ice. How do I fix this
It shouldn't make any loud noises at all. Most likely it's a water pump related problem. Most pumps make loud noises when they are lose from their base due to a broken clip or untighten screw. It could also be caused by a faulty pump. Either way, if you just bought it and have the receipt, return it and have them give you another one.
Dec 02, 2014 | Igloo Cooler Igloo Portable Countertop Ice...
My Kenmore gas range 2274233 makes a loud noise when the oven is turned on.
Since it is new--have them bring you a new one. That should have been fixed before shipment
Jun 26, 2014 | Kenmore Kitchen Ranges
Sony Bravia KDL46W4150 crackles and volume suddenly increases
Hello
There is some loose solderings or leaky ceramic capacitors at the audio output section of your sound card. Check it.
Feb 28, 2012 | Sony BRAVIA KDL52XBR2 Television
My Laney VS30 212 at band practice last week decided to intermittently cut out, but not fully just the volume would drop out then return about 5 mins later. Not sure if this was a common problem. It might...
Sounds like output valve, if the amp is more than few hundred hours then suspect this for sure. I don't know much about this amp specifically but does the sound fade/return suddenly or over a few seconds? Try running it with the back off and fan on the valves etc. Then play at loudness where problem occurs and see if any improvement. Remember that at band practice you always play much louder than you think and put a lot of stress on it.
May 03, 2011 | Laney VC30-212 VC Series 30 Watt Class A...
Camera records loud background noise.
Ensure your webcam mic is set as default
Vista
TEST SPEAKERS
Right click on speaker icon in System Tray or from Control Panel
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required (webcam) mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click 'OK'
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
If the problem is due to feedback try using a set of headphones
Jun 06, 2010 | Logitech Webcam
Steam Cast iron raditor makes a loud popping or banging sound.
Some cracking and pinging is normal due to the thermal expansion of the metal. If some make more noise than others, it could be an indication of a plugged or restricted steam vent (the chrome gadget on the side of the radiator) or that the return line at the boiler needs draining or that there is too much water in the supply lines. A good flushing of the supply and return lines will help. Check your water level after flushing. I would replace the original steam vent on the suspect radiator and see if that helps, it could be over heating.
Jan 31, 2010 | Honeywell Programmable Thermostat Heater
Dryer makes loud noise when operated.
Get your model number and get a set of glides or drum bearings, whichever your unit uses. Don't let this go too long or your drum could be ruined.
Dec 01, 2009 | Washing Machines
New unit has loud noise & doesn't drain. Too late to return!
drain line kinked? trying to diagnose a noise problem over the inter net really hard . could be compressor
Jun 17, 2009 | Danby Portable Air Conditioner
Heating & Cooling Logo
106 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
