Question about Kuppersbusch Ovens
We have a Kuppenbusch HTHB84K combi oven. Since we have owned this the microwave has malfunctioned 4 times, with the same problem. After a few seconds the microwave shuts down. The fault has been corrected each time and it will last about 4 months. The problem seems to be a timer and the repair cost is ?80 a go. The importing agent no longer supports spares.
  • 944 Answers
Note:Even you can't purchase this model in online.
The Kuppenbusch company is no longer present it is closed.So you can't get the Kuppenbusch timer for this model.But all timers basically have same property.Just get the Kuppenbusch timer to spare parts shop and ask him get the timer which looks like your model.Mostly many ovens timer matches with all models.
1)Whirl Pool ovens.
2)Kenmore ovens .
3)Frigidaire ovens.
These model timer will fit into your model.You have to just solder at the endings with the your model.The repair main can help you in this.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 03, 2010
Microwave combi oven
Putting any metal object inside any Microwave is a problem, a large metal object destroys a part called the Klystron tube (the part that makes the microwaves), the energy from the tube is reflected back and burns out the Klystron tube. The part is most likely more than the oven is worth when you throw in labor to install it.
Sep 08, 2016 | Neff Ovens
I have a Miele H147-2mb combi oven. If I start microwave in the 900w mode for a little bottle with milk i see a flame on the topplate of the oven. It's a circle with a diameter of 5 - 10 cm.
Hi there - the cover plate is most likely to be damaged or theres dirt build up behind the cover plate causing it the arc or short to the frame...
Worse case is the microwave cannot be used as it will cause more damage to the oven.. there are a few screws holding the cover plate to the top - remove it gently - if not damaged as its made of fibreglass you may be able to re-use it - inspect the hole/microwave entry for the damage caused by the arc reactions.
Pending on how bad it is - you may just have to use the oven only as one needs to replace the entire casing to overcome the problem which is costly. Wipe the carbon off the oven with a damp cloth - please don't scrap it off as it will enhance the arcing and if the damage is already excessive then reside to using the oven only.
Good luck
Aug 18, 2011 | Miele H147-2MB Electric Single Oven
Do you take the turn table out when using both the microwave and the oven (combie)
No; if you're using the microwave you need to leave the turntable in to ensure the food heats evenly.
If you use just the oven or grill you can still leave the turntable in; there's no need to remove it. But you could remove it if you wanted.
Jul 25, 2011 | Ovens
MY AEG OVEN IS IN SAFE MODE HOW DO I GET OUT OF THIS MODE
Just found out that the 'safe' mode on my oven is for child protection. I had to press 'p' en 'minus' (-) at the same time for a few seconds. Problem was solved immediately. My oven is an AEG-Electrolux Micromat-Combi.
Apr 23, 2010 | AEG B8139-4-M Electric Single Oven
Does a moffat oven need a 30amp cooker socket or is it ok on a 13amp plug
Unless your talking about one of those tiny, table top ovens, dont use a 13 amp socket / connection.
An electric oven must be connected via a 30 amp SUPPLY - the socket is just the connector at the end of the cable that runs from the fuse / breaker board. A 30 amp supply will use a much thicker cable capable of handing the higher currents.
Whilst a very basic oven may draw less than 13 amps current when operating in some modes, most will draw well in excess of this depending on what facilities they have, e.g. bake and grill at the same time, or maybe a combi-oven - one that can bake and microwave at the same time.
Oct 03, 2009 | Ovens
Difficulty in cleaning my Miele combi oven
I have the same cleaning problem as Denise503 with her Miele combination oven - help if anyone has a solution - I have got to the stage where I don't want to use it.
Apr 10, 2009 | Ovens
Samsung vitality combi microwave
Defrosen button ???
Oct 22, 2008 | Ovens
Microwave Combi not working
Left it plugged in for about 2 hours and it's OK now!
Feb 15, 2008 | Ovens
Ovens Logo
343 people viewed this question
Top Kuppersbusch Ovens Experts
ashburton
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Kuppersbusch Oven Expert? Answer questions, earn points and help others
