Question about Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher
SGS45E02GB: Water is entering the DW as normal, all accessible filters are clean, pump is going, but something is stopping the water reaching the spray arms (yes, they are clean as well). Where is the blockage (if that is the problem) likely to be and how do I get at it?
  • kandsb Sep 04, 2010
    Thanks Seth, but I doubt that I need a new motor. But possibly a valve?
  • Bosch Master
  • 3,247 Answers
You may be hearing the wash pump running but that does not mean it is sending the water through.
I am assuming the water is collecting in the base of the dishwasher.
You will have to confirm if the pump is working the correct way.
Posted on Sep 04, 2010
  • 1,531 Answers
Once the water is in the machine try adding about 3 cups more water and see if the changes any thing if it does then you have a water flow problem not allowing enough water in the dishwasher,if there is no change then you need to replace the main wash motor
Posted on Sep 03, 2010
Electrolux esl7220ro is beeping twice. This points to the drain pump but i have checked the pump by adding water to the sump which drains fine. Is there water drain switch/sensor or something else?
Before you go on, keep in mind computers and water are not compatible and most issues with control panels stem from association with water. But if you feel this is not a computer glitch try this: I assume you have cleaned out filters and catch basin under the filter including any debris that maybe lodge in there, There maybe a seed, glass or something in the well by the pump. Before taking DW apart, try disconnecting the drain hose to drain of kitchen sink. Clean the rubber around hose and blow as hard as you can to dislodge whatever obstruction is in the pump. Anything that comes out, clean out. Of course if this does not work it could reverse this by taking drain hose from bottom of dishwasher and blowing any object into the sink drain. If beeping continues ensure that all electrical connections are secure. Should this not work and you feel handy and you still think it may deal with pump, you can always drain mechanism. Should this not work, dissemble and clean pump. Repost should these steps do not work. With as much information on actual noise and or symptoms of DW
Sep 19, 2017 | Dishwashers
Bosch dishwaser. starts and stops, it will say clean. leaves water in the bottom. we purchased a new pump and still not working? :( :(
All dishwashers leave a little water in the bottom. However, I suspect there's an appreciable amount in the machine. I'd suggest you lift out the filter and check the drain port.
Feb 11, 2015 | Bosch Dishwashers
What could be the problem on my Samsung DMR57LFS dishwasher with an E9 error after the low-level sensor is cleaned but the error still exists?
This is an exhausting procedure you have described here. Have you checked the float in the low water reservoir is actually working.
Sep 15, 2014 | Dishwashers
Skipping cycle
I think that # 4 is the solution to your problem. Something isn't right with the world, the DW is thinking. The sticking float seems like the problem here. If not, consult the owners manual on the error message you receive if any.
Is their debris in air gap or in the bottom of the DW, where the drain is screened?
1. The air gap is usually located on top of the sink. Lift off the pretty cover, and unscrew the top cap nut. Is there rice and debris there? Remove it then. Reassemble and check it out.
2. The DW drains to the bottom of the unit where the pump is. This area is screened off so that the pump doesn't get clogging debris in it. is their leaf lettuce and stuff covering this? Remove that debris. Some times this area can only be accessed by removing the bottom spinning spray head. It comes off with a nut, possibly this nut is reverse thread. Reassemble when done looking for debris.
3. Is the drain line between the DW pump (located under the DW) and the waste pipe kinked? This line is a plastic corrugated line about 7/8" around the outside. It is a pumped waste and won't work if it is kinked, so unkink it.
4. Is the float stuck. This is a device on the bottom of your DW that tells the DW how much water is in the bottom of the DW basin. It looks like a mushroom. Gently move it up and down. Does it move freely or is it stuck? Unstick it.
Good luck.
Jan 11, 2014 | Bosch Dishwashers
Danby dishwasher not washing
see this possible causes: 1) water heating cycles;the water must be preheating,test the heating elements and thermostat. 2) Timer: test for defective, clean contact, repair any wires loose, burn, or break. 5_9_2012_1_15_39_pm.gif
May 08, 2012 | Danby DDW1899WP Portable Dishwasher
The water wont drain and the is a clicking noise coming out of the water pump motor
Something may be stuck in the pump impeller causing it to make a clicking or rattling noise. Disconnect power then remove the lower front access panel to access the pump filter and the pump impeller.
Remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Drain the water into a bucket or shallow pan and lay a piece of towel under the pump filter prior to the removal of the filter. Turn the filter knob counterclockwise to remove and clean it. Reach in the pump to check if it is restricted or detached from the pump motor spline. Replace the pump assembly if the impeller is broken or detached.
Oct 04, 2010 | Kenmore Elite 45986 Front Load Washer
F 02 was flashing and the water is still in the machine how do i get the water out
Based upon your description, the drain pump has either failed or the pump filter has become clogged.
To check the pump, remove the bottom access panel. There you will find access to the pump clean-out.(Large,white screw cap) Take care of lot of water going to the floor, unscrew the pump clean-out, catching and discarding the water. When the water flow finally stops, completely remove the clean-out filter. Inspect the clean-out filter, the drain hose from the tub as well as inside the pump impeller for any additional debris.
Jun 20, 2010 | Kenmore Elite 45986 Front Load Washer
Dishwasher stopped draining after cycle
Some water always remains in the bottom of the DW (al least with most DW) but here is some help....
GE dishwashers will have a sump entrance screen ( #4 ) that should be removed and checked for any gookus, see 1 or 2 screws on the cover top, which is behind the lower spray arm. Almost all ( some newer GE dishwashers have a separate drain pump and motor - but for our purpose, we will talk about the most common GE dishwashers ) GE dishwashers have a drain solenoid ( #1 ) that can fail and stop the draining. If the solenoid cannot pull in the silver plunger, the drain port will not open to allow the motor and pump assembly to drain the water out. The solenoid can be ohmed with an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GE dishwashers have a self clean filter ( #3 ) inside at the back. The draining water must pass through a plunger in the self clean filter body. This can get clogged up, or the plunger may twist and distort and not allow the draining water to get past. The filter can be removed from the inside and the plunger will twist out of the self cleaning body for testing/checking. Next obstacle for the draining water in the back flush valve ( #2 ). This valve can twist or distort and block the water flow as well. The drain port will need to be accessed to check this flapper valve, the drain port will untwist from the self clean filter body. All hoses in-between the items mentioned above and the drain hose itself all the way to the house plumbing should be checked for restrictions.
Some extra filter, draining tips and pictures....
During the wash and rinse modes of the cycle, soiled water falls down the back of the tub and into the filter area. The water comes through the filter and back into the tub. During the wash and rinse periods all ( we hope! ) the water will pass through the filter. The soil will settle into the collection chamber and is held there. When the dishwasher goes into the pump out mode the water in the sump is pumped through the collection chamber. This closes the piston valve to the inside of the tub. The pump flushes the collection chamber of all the food soil and pumps it down the drain. A check valve is located in the drain line port. This valve allows the water to flow in the drain direction only and prevents the water from coming back into the tub. The drain line check valve must close in the back flow direction or the piston valve in the collection chamber may not reopen into the tub after the pump out is complete. Water should "fall" through the filter and go back into the tub....the heavier food particles go down into the chamber and are collected.
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and ggod day...please rate my effort......thanks....The Fang.
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Bosch SHX46A dishwasher
there is a new product out that actually filters the water going into your dishwasher. I use to have ugly,white and cloudy looking glasses until i installed this product. after the first load my glasses looked fantastic!!!! its affordable and you can get it at dishwasherfilter.com.
Apr 01, 2008 | Bosch 24 in. SHE56C05UC Stainless Steel...
I have a Bosch SHX46B05UC/14 and it stopped functioning right. It filled, it ran, it drained, it sounded okay, but I finally determined there wasn't enough circulation pump pressure to swing the spray arms. Turns out the problem was a pump pressure adjustment screw, accessible under the kick plate, had backed off--now if I can only figure out how to set it properly, low enough to clean the glassware, high enough not to break the pots and pans--or is it the other way around. I also found some beans in the drain sump (easy to remove cover plate from inside with a torx driver, large object trap not locked down properly and a riser for the upper spray arms not press fit sufficiently into pump outlet (I wonder if I blew the line while setting pump pressure. I AM looking for guidance on how to properly set the pump pressure, for the moment, I simply turned it into its spring loaded range and cranked it down a few turns.
Oct 04, 2007 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch 24 in. SGS45E02 / SGS45E08 Exxcel Free-standing Dishwasher Logo
69 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
