Question about HP Pavilion a1450n PC Desktop
A1450N had mobo failure, swapped for refurb board, had to clear cmos to get it to boot. Now the integrated nic card shows up as 1394, shows a connection but there is no funtion.
5 Suggested Answers
SOURCE: NIC hardware failure
Maybe your problem is software related. Maybe a virus changed some settings. I would check all the internet settings and the network card settings. I've seen this happen before. In windows xp click Start/Control Panel/Network Connections. Then right click on your local area connection and Click Properties. Slide the bar down to the TCPIP protocol and highlight it, then click Properties. Make sure you are obtaining the IP Address and DSN Server address automatically. Click the Advanced button and make sure DHCP is enabled.
Posted on Jan 28, 2009
SOURCE: Looking for replacement card for Nic integrated
The server could not connect to the network. The network and its cables are all okay.
Posted on Feb 03, 2010
edgedev
  • 81 Answers
SOURCE: video froze during operatiom. after re-boot, no
If you hear a beep, then that means that it cleared through POST. If you hear one beep, it's fine. More than that, you will need to know how many.
If it's twice, it's the Video card. I suggest to take it out, and use a VGA cord and connect it to the VGA slot on the built-in graphics on the motherboard. That SHOULD work. If not, there might not be a problem with the video card at all. It might be a RAM issue.
To know that, you will need to take out one RAM stick at a time and try starting it up. If you have multiple (2+) you will continue to add the sticks until the computer doesn't boot again, and you will find out which of them is bad.
The power supply would not be an issue, because if your computer froze during a video operation it would have nothing to do with the other causes.
Please Rate. Thanks.
Posted on Apr 04, 2011
maxcarson
  • 7627 Answers
SOURCE: boot up hp pavilion a1340n and get no vga signal
Have you checked , verified monitor cable, pins bent? You can try a PCI or better a PCI e Graphic Card. Does it boot? Have you tried another monitor?
Posted on Dec 26, 2012
Powers up, fans work, but nothing happens. Can not even get into the Bios. red light on between the power connection and the IDE connections?
I will assume that you have everything connected properly and are using the integrated video on the motherboard (not a separate video card installed in a slot). Usually the red light on the motherboard (mobo) is a power-on light, meaning that it is plugged in to a power socket.
First try to clear your CMOS settings:
Unplug the power cord and remove the CMOS battery for 15 minutes. If your mobo has a BIOS reset jumper, move it to the Clear position and back to normal. If you aren't sure what these things are, it will be in your manual that came with the mobo. Now re-connect everything and try again. Make sure that you are plugging the video cable into the proper socket and your monitor is working. If you can use a DVI cable on that board, try that connector. Make sure your monitor is working.
>Visually check for failed capacitors; caps that have ruptured are increasingly common and can stop booting.
>Your CPU may have failed; this is a typical situation then the chip fails. Everything works except there is no video on the monitor.
For more detailed testing and information, go HERE.
Oct 10, 2013 | QDI Group QDI Advance 6T Motherboard
Istalling new computer components, first boot up and nothing will display.
If the board has built in graphics, connect the monitor to that temporarily. In the BIOS you can select the preferred order of the GPU.
Something like PCI - PCIe - IGFX should be your choice.
You may have a bad video card, or a bad mobo. Swap a different card in first to make sure. Also if this is a gaming machine with a high power card you may not have a powerful enough PSU to start the system. The PSU is actually the most important component, and many times the most often one people cheap out on.
Hope this helps!
Jun 01, 2012 | Biostar TPower X79 Ver. 5.x
I have a Geforce 8400gs PCI video card
Helo frnd i sugest u to reset ur bios by opening the mobo n find a jumper were clear cmos is written then fix the jumper to the other two sides oor read the mobo manual to do it
Feb 19, 2010 | Asrock P4VM890 - Motherboard - micro ATX -...
When I turn on the computer it starts to beep every four or five seconds; it doesn't even turn on the screen. The display at the motherboard is "04". What does it mean? There was nothing wrong with my...
This is do with a device failure it can be the RAM of your system , Try swapping the RAM and if you find two RAM in your system remove one to check the error.
Kindly send me your valuable feedback.
Jan 16, 2010 | Abit KV8 Pro Motherboard
What kind of mobo does this Toshiba V3100 desktop machine have? And what kind of NIC do I need? Besides the origanal RJ 11 NIC that came w/it?
Here is a pdf file showing the specs of your computer:
http://www.bjassociates.com/toshiba_v3100.pdf
The MB is a micro ATX board with 3 PCI expansion slots. The one slot appears to have had a NIC card to which you refer. You would have to obtain a PCI Ethernet card (NIC).
Thanks for using Fixya.
Oct 01, 2009 | Toshiba V3100 Plus PC Desktop
I cant boot up my computer(memory address line failure)
This is clearly a problem with the memory. You can try two things:
1) Remove and reseat the memory sticks (with the unit unplugged)
2) Swap the boards around. Windows is not very tolerant of errors in the lower portion of memory. Swapping around the boards will change the relationship of physical memory addresses to virtual addresses. At the very least, the memory swap may help to determine which memory stick is defective.
Please keep us posted.
Dan
Aug 20, 2009 | Dell OptiPlex GX110 PC Desktop
System will not boot
Do you have any pci devices installed? Bad PCI deviced, especailly modems, will cause a PC not to post. Did you try swapping the memory for a different module? It could be the stick and not the slot. Also, are there any blown capacitors on the MOBO, you would know this if they are puffed up at the top.
Aug 05, 2009 | Soyo SY-7VBA133U Motherboard
P5RD2-VM mobo will not post at boot
Three beeps for that bios is a memory error.Are you sure it's not a memory issue? Did you clear the CMOS and try to boot up again?
Dec 10, 2008 | ASUS P5RD2-VM Motherboard
When i boot Gigabyte K8N-SLI a long beep is heard untill completely booted
Long beeps can indicate a processor or board failure, but i would check your graphics card first, uninstall it in device manager and then remove and reseat the card. Although i think there is mobo failure imminent
Apr 23, 2007 | Gigabyte K8N-SLI (GAK8NSLI) Motherboard
HP Pavilion a1450n PC Desktop Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
