Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Will not start, has no compression,bought new june-2010
    President:
  • Briggs & Str... Master
  • 1,383 Answers
If little or no compression problem may be stuck valve/s. Easy fix/ harder fix. Remove sparkplug and spray wd40 into cylinder and replace plug (hand tight because you may need to repeat), try to start. The oil will tend to raise the compression a bit if lucky enough to start, too much will wet plug, just clean and try again. If it starts you can keep spraying wd40 into carb till it runs better. Harder fix, remove plug wire, remove valve cover and pull starter rope slowly to see if valves are moving and rocker arms are not too loose. Loose rocker arms indicate stuck valves. If stuck, lightly tap top of valve/spring with wood handle of hammer or large screwdiver to free valve. Generally only a couple of taps are needed. If these procedures do not help a trip to small engine shop is indicated. Good luck
Posted on Sep 03, 2010
Compressions for 3.5 engine
Compression should usually run between 130-175 psi. The main thing is that there is no more than 25% difference in readings between all cylinders.
Dec 03, 2013 | 2010 Dodge Charger
Whistling noise when cooling on Kenmore built in oven model #790.48783900
These types of ovens are complex to troubleshoot and repair. I would contact an appliance tech.
May 23, 2012 | Ovens
WILL NOT START....NO POWER? BOUGHT AT SEAR JUNE OF 2010. HONEYWELL MODEL 17000
Make sure that the receptacle that it's plugged in to is still working. The circuit breaker for that outlet may have been tripped in your home's circuit breaker panel. Or there may be a loose wire or bad connection inside the outlet box. May not be air purifiers fault at all.
Mar 29, 2011 | Honeywell 17000 Air Purifier
I have a Samsung LE40C530 lcd tv. I bought it on the 2nd June 2010. I was watching it last night when, all of a sudden, it turned itself off. Now there is no power on LED and no seemingly no power. There...
It is probably a bad power supply board and yes I have had to replace this board on new machines before. You need to call 1-800-samsung and set up a warranty service call.
Jul 01, 2010 | Televison & Video
Hey Very Strange Issue
Send me the screen shorts if you can not send me through fixya then mail me at geekjango@hotmail.com.
I'll get back to you ASAP.
Jun 22, 2010 | Yahoo Mail
I get new number in airtel postpaid +918146811118 on 11 june 2010 but it's not activated why?
Please ask this question to your dealer from where u bought ur sim
Jun 13, 2010 | Nokia Lands Phones
BOUGHT JVC AV-56WP74 IN JUNE 2004. 52
It is worth getting an estimate. From the symptom you explained, it looks like the horizontal output transistor became defective.
Jan 16, 2010 | JVC AV-56WP74 56" Rear Projection...
Remove Nav disc for Lexus RX 350 2010
If you have a June 2009 model , may not be the latest version.Confirm with parts dept if they are compatible discs for the 2007 . A NAV update just came out this fall. The 2007 plays from the disc , in the back of the car . You might be able to swap your June disc into the 2007 and buy the latest version for your 2010, either in disc or one time USB down load.
Dec 12, 2009 | Lexus RX 350 Cars & Trucks
Screen on laptop won't light up
There is a board called an inverter behind the screen besel. The inverter is like a balast in a flouresent light. The inverter supplies the power to light the screen.
Oct 20, 2009 | Toshiba Satellite Pro L300-EZ1005X...
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
332 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
