Question about Goodman Heating & Cooling
The capacitor, the relay and the starter all burned out. I have a model # CKT 24-1. What would cause this to happen. And could you give me part #'s for these items.
  • Goodman Master
  • 17,130 Answers
Possible that there was a high voltage surge in your place for this to happen, otherwise the capacitor would have shorted and make the rest burn out.
Use can use the regular types inthe market that can suit the compressor of the AC.
Parrt no available only on service manuals or with the Goodman service .
Posted on Sep 03, 2010
?Had a new starter and new battery put on my 1999 Chevy Tahoe.. we by it starts sometimes and sometime it don't..what could the problem be
I'm assuming just by the fact you had a new battery and new starter that sometimes when you turn the key to the start position , nothing happens . Is your vehicle a automatic transmission ? When it doesn't start have checked for battery voltage at the starter solenoid S terminal ? Is there B+ voltage at pins 30 & 86 for the starter relay ? Pin 86 while cranking the engine or trying to crank the engine over . Pin 30 check with key on . Try moving gear selector to neutral . Videos on youtube for basic automotive electrical testing . How to voltage drop test starter motor circuit Find a wiring diagram at www.bbbind.com
Starting System Circuit Description
Voltage is applied at all times to the ignition switch from the IGN A fuse 6 through CKT 242 (RED). When the ignition switch is turned to the START position, voltage is applied to the CRANK fuse 8 through CKT 5 (YEL). From the CRANK fuse 8, voltage is either applied to the clutch pedal position switch (M/T) or the transmission range switch (A/T) through CKT 806 (PPL). When either the clutch is disengaged (M/T) or the transmission is in park or neutral (A/T), voltage is applied to the coil of the starter relay through CKT 1035 (PPL/WHT). Since the starter relay is permanently grounded at ground G105 through CKT 150 (BLK), the starter relay energizes.
Voltage is applied at all times to the starter relay contacts from IGN A fuse 6 through CKT 242 (RED). When the starter relay energizes, the starter relay contacts close, and voltage is applied to the starter motor solenoid. Since the starter motor solenoid is permanently case grounded, the starter motor solenoid will energize two coils. The pull-in winding coil energizes in order to pull the starter motor solenoid contacts closed. When the contacts close, a plunger on the contacts causes the pull-in winding coil circuit to open. The hold-in winding coil then holds the starter motor solenoid contacts closed. Voltage is then applied to the starter motor from the battery through CKT 1 (BLK) and the closed contacts of the starter motor solenoid. Since the starter motor is also permanently case grounded, the starter motor will run until the ignition switch is moved out of the START position. When this happens, a spring in the starter motor solenoid moves the starter motor solenoid contacts and the plunger back to the rest position.
Jan 07, 2017 | 1999 Chevrolet Tahoe
How can the lights be disabled that stay on all the time ?
Have you tried replacing the headlamp power relay in the underhood fuse/relay box ?
Headlights Circuit Description
Voltage to the headlamp switch is available at all times from the HDLP SW fuse 7 through CKT 1940 (ORN). When the headlamp switch is turned to the HDLP position, the headlamp power relay coil is energized through CKT 352 (WHT). A signal is also sent to the body control module (BCM) that the headlamp switch is ON. When the headlamp switch is in the AUTO or PARK position, the ambient light sensor (located in the right speaker grill) senses either daylight or darkness and sends the signal to the BCM. When the Ambient Light Sensor detects a dark condition, the BCM produces a signal that will energize the headlamp power relay through CKT 352. The relay coil is grounded through terminal F7 connector 2 of the UBEC to CKT 350 (BLK) to G102. When the headlamp power relay is energized the relay supplies power to the LT HDLP and RT HDLP fuses. The RH low beam headlamp receives current through CKT 198 (DK BLU) from the RT HDLP fuse. The LH low beam headlamp receives current through CKT 712 (YEL/BLK) from the LT HDLP fuse. Both headlamp low beam bulbs are grounded by CKT 524 (PPL) through the UBEC to the multifunction switch (low position) contacts through CKT 10 (YEL) to the headlamp grounding relay in the body relay block through the normally closed contacts to CKT 1850 (BLK) to G200.
Dec 22, 2015 | 1998 Chevrolet S-10 Pickup
2010 ford f150 keeps blowing the starter relay where do i look for a short?
make sure it is not grounding out at the starter itself ,also ck the alterantor wire same deal then goes to batt.
Jan 19, 2015 | 2010 Ford F-150
Why does the starter stay engaged on my 99 Chevy suburban when I use the remote start
Check the batteries. If remote is the one that came with it. could be wore out.
Nov 21, 2014 | 1999 Chevrolet Suburban
Starter relay burning out
The large wire to the starter from the battery is corroded at the starter terminal, or the large earth wire is not clean.
Aug 30, 2014 | Suzuki Boulevard C50 Motorcycles
1999 GMC Sonoma 2.2L will not start.
What is wrong????????? That would be a guess on anyones part here ! Testing the electrical circuits involved would be the proper way to diagnose this no start problem ! Using a volt meter an wiring diagram to check voltage at different point's in the starter circuit . voltage drop testing ! Plus knowing how the starter system works !
Starter Circuit Operation
Voltage is applied at all times to the ignition switch from the IGN A fuse through CKT 42 (RED). When the ignition switch is turned to the START position, voltage is applied to the CRANK fuse through CKT 5 (YEL). From the CRANK fuse , voltage is either applied to the clutch pedal position switch (M/T) or the park/neutral position switch (A/T) through CKT 806 (PPL). When either the clutch is disengaged (M/T) or the transmission is in park or neutral (A/T), voltage is applied to the coil of the starter relay through CKT 1035 (PPL/WHT). Since the starter relay is permanently grounded at ground G102 through CKT 150 (BLK), the starter relay energizes.
Voltage is applied at all times to the starter relay contacts from IGN A fuse through CKT 42 (RED). When the starter relay energizes, the starter relay contacts close, and voltage is applied to the starter motor solenoid. Since the starter motor solenoid is permanently case grounded, the starter motor solenoid will energize two coils. The pull-in winding coil energizes in order to pull the starter motor solenoid contacts closed. When the contacts close, a plunger on the contacts causes the pull-in winding coil circuit to open. The hold-in winding coil then holds the starter motor solenoid contacts closed. Voltage is then applied to the starter motor from the battery through CKT 1 (RED) and the closed contacts of the starter motor solenoid. Since the starter motor is also permanently case grounded, the starter motor will run until the ignition switch is moved out of the START position. When this happens, a spring in the starter motor solenoid moves the starter motor solenoid contacts and the plunger back to the rest position.
Starter Voltage Drop
Jun 23, 2017 | 1999 GMC Sonoma
Fedders 208/230 split system w/ dual cap , compresser runs but fan wont unless you give it a push , compresser won't restart if relay is hot
All kinds of stutt happens when you dont have a condensor fan motor. You need to change the run cap on the motor.
Aug 06, 2011 | Heating & Cooling
Smell electircal burning
The Starter Relay consists of various parts depending on the make and model of your unit. Most larger Refrigerators have these 3 components: The relay itself, the Overload, and a capacitor. If you replace the Relay and if another component is bad then you would still have a problem. A service technician could test each component individually. The first move I would make is to use an Amprobe electricians meter and check the amperage that the compressor is pulling. If the compressor is VERY HOT to the touch and pulling a lot of amperage current, than you'd need to have the compressor replaced. THis is usually the case if the unit is approx 10 years give or take. This is a very expensive fix...usually around $500 or more so it's probably worth buying a new Refrigerator if that's the case.
Nov 17, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Compressor clicking on and off fridge now warm
looked up your model number and got a part number of 8201799. is that the number you got??? cause in the pic it looks like there are 3 terminals on the relay(brown piece) there should have also been instructions in the package no???
Mar 28, 2008 | Refrigerators
I HAVE AN INSGNIA 24" (NOT SURE OF MODEL)
as it has developed watching tv so it is a part failure in vertical section. in vertical there is a feed back ckt.it is due to electrolytic capacitor (most probably)or any other component but in feed back ckt. it is a common failure it is not major problem.can be rectified at your place with in no time by a skilled tech.
Sep 24, 2007 | Insignia IS 20" TV040919 TV
Heating & Cooling Logo
73 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
