Prior to closing Notebook I ran a registry clean program "CLEAN & FIX" that I have used for the last year or so. During the the fix process some error was encountered and I assume the registry was not closed or updted properly. PROBLEM - when i restart the Toshiba notebook it stops on the blue WIndow XP screen - if I try to re-install / repair the windows software it cant find the hard disks? Any help apprciated
  • 42 Answers
Ah, another "blue screen of death"
Your reg does sound as if it's damaged..
Have you tried a safe boot option?
If not, once the PC has booted, but before Windows starts loading, press F8 until you get the save boot menu.
Select the safe boot option (Without Network) and see if you can get in. If so then restore the old reg from your reg fix program.
If no backup, run the reg fix again.
If the safe boot option doesn't work, try pressing the "space bar" instead of F8, this should give the "Last good config" option to boot. Again try and restore the reg or run the reg fix.
Posted on May 11, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 268 Answers
Check whether the hard drive is detected in the BIOS or not.
Remove the hard drive & wait for 3 minutes and reseat the hard drive.
Check whether all the cables are connected properly.
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 1 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing & start the system.
Restart the system.
In this case you can make use of the system restore.
For XP :
Boot in to safe made by pressing F8 key(function key 8) can be found on the top row of the keyboard.
login to your account & start the system restore from start-all programs-accessories-system tools-system restore.
select the date on which it is working fine.
After completion the system will restart automatically.
Now you can boot normally.
For Vista :
Open this link to know how to do that :
http://support.microsoft.com/kb/940765/en-us
If the system restore doesnt help reinstall the whole OS.
If the hard drive is detected then you can now install the OS by changing the boot priority device to the cd.
Good Luck.
Live, Love, Laugh.
Dell inspron 2320 slow
Stop Unnecessary Background Programs:-
Sometimes there are some background programs that are running without our consent and eating up the memory and energy of the CPU. Closing down these programs will speed up your laptop performance. To do so follow the instructions below:
- Hold Windows+R button on your keyboard
- Type msconfig and press Enter
- Click on Startup tab
- Click on Disable All
- Restart your Computer
Fix Registry Errors:-
Mostly laptop/computers runs slow issue occurs due to broken Windows registry entries. Fixing registry will help you to boost up your laptop. You need to download and install a Registry Cleaner program to fix corrupt or broken registry entries. To download a reliable registry cleaner, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends. After downloading run all of its tools one by one except Internet Optimizer, to clean all the junks and registry errors from your computer.
Dec 08, 2013 | Dell Computers & Internet
Tip
INCREASING YOUR PC SPEED BY Cleaning & Fixing Windows XP Registry Errors
The USe of utility software in increasing pc speed has been shown to tune up pc peed up to 100%. <a href="http://618f9448ja45vlznf3j3xn9r3k.hop.clickbank.net/" style="font-weight: bold;">OPEN UTILITY TWEAK SOFTWARE HERE</a><br /><br /><br /> The Windows XP registry is your computer's repository for system settings and configuration data. Over time, the registry can become bloated and even corrupted. Problems with the registry can slow down your <a href="http://af3be13cq785qiu23hhen-r83p.hop.clickbank.net/"><span>computer</span></a> and cause programs to malfunction. To maintain a clean, healthy system, you should periodically scan your registry for errors and fix them when found. You could do this manually, but Microsoft suggests that you use registry cleaning software instead. These programs can be downloaded from <a href="http://1ce798yesa-crllct7rhppgx5f.hop.clickbank.net/"><span>the Internet</span></a>. Before you make any changes to the registry, back it up first.<span><br /><br /><span style="text-decoration: underline;"><a href="http://af3be13cq785qiu23hhen-r83p.hop.clickbank.net/" style="font-weight: bold;">The guide below is for technical person. But the software approach can do the operations without tasks of following instructions: open access <br /></a><br /></span></span> <span>Instructions</span> <b>Things You'll Need:</b> <ul> <li> <span>Registry cleaning software</span> </li></ul> <ol> <li> Back Up the Registry <ul> <li> <span>1</span> Click the Windows XP "Start Menu", type regedit and press "Enter". The registry window will open.<br /> </li> <li> <span>2</span> Click "file" (at the top of the window) and select "Export". You can choose any name that is easy to remember.<br /> </li> <li> <span>3</span> Type a name for the registry file that you want to create and click "Save". A copy of your registry will be saved to that file. If problems occur after you clean your registry, you can restore your Windows XP registry by double-clicking the file that you saved. It will have a file extension of reg. Be sure to remember where you save the file.<br /> </li></ul> </li> <li> Fix the Registry <ul> <li> <span>1</span> Download a registry cleaning program, such as CCleaner or nCleaner, and install it. These programs are specifically designed to clean and fix your registry. You can find links for this in the Resources section.<br /> </li> <li> <span>2</span> Run the program's "Scan for errors" function. The software will locate any problems that it finds and display a list along with recommendations for proceeding. This intermediate step enables you to view any errors before you fix them. All registry cleaners may not have a button that says "Scan for errors", but they will have one that performs the task. See your program's documentation for details.<br /> </li> <li> <span>3</span> Decide on a cleaning option. Some registry cleaners have an "auto-clean" button. Pressing this will automatically repair all errors shown on the error list. PC World suggests that you never select that auto-clean option. Instead, review the list of changes and select the ones recommended by the software.<br /> </li> <li> <span>4</span> Click the program's repair button to fix the registry. The software will repair the registry and show you a list of corrections when it is finished.<br /></li></ul><br /><a href="http://digitalpowering.blogspot.com/2010/12/guide-to-increase-computer-laptop-pc.html" style="font-weight: bold;">PC USe guide on COMPLETE PC WORLD BLOG- OPEN HERE</a><br /></li></ol><br /> <span>Tips & Warnings</span> <ul> <li>Many registry cleaners exist. Some of them perform remarkably well while others are only partially good at finding errors. <a href="http://af3be13cq785qiu23hhen-r83p.hop.clickbank.net/" style="font-weight: bold;">Check the Internet for reviews and recommendations</a> when choosing one to download. You can find many excellent free cleaners as well.<br /></li></ul><br /> <ul> <li>The Windows XP registry is a critical system component on your computer and serious problems can occur if the registry is incorrectly managed. Follow your registry cleaner's instructions carefully and you should not have any problems.<br /></li></ul><span><br /><br /><a href="http://www.ehow.com/how_6309011_clean-windows-xp-registry-errors.html#ixzz18AekXPrp"><br /></a></span><span><br /><br /><br /></span><br /><br />
on Dec 15, 2010 | Computers & Internet
Tip
Why Google Search Redirects Virus? How to Fix Google Redirecting Virus
Two good software tools can help you to fix the redirecting virus with Google search.One is the registry repairing program and the other is the malware removal tool. With the help of the registry cleaning program the infection is completely removed from the hidden registry entries of the Windows. While the anti-malware detects and removes the infection from the computer. If during search, Google redirects virus and produces undesired web results then follow these instructions:
Step 1:
Download a software to thoroughly repair and clean Windows registry. The Windows registry is an area which contains very sensitive information about all the programs running in the computer. Most of the viruses and malwares also attack the Windows registry. Unfortunately running the anti-virus/anti-malware scans only does not remove the infections from Windows registry.
Step 2:
Download a good malware removal tool and conduct scan through it. The Google search redirect virus is caused by the malwares that shall be removed from the computer. If properly used with the registry cleaning tool, the antimalware can greatly help to fix the Google redirecting virus.
Step 3:
Go to My Computer > Properties > Device Manager > Hardware > View > Show Hidden Devices. After this select the option "Non-Plug and Play Drivers" and disable 'TDSSserv.sys'. Don not uninstall it.
The above guidelines have been found to work well. Are you tired of this nuisance and want to have a quick fix to eliminate Google redirecting virus? Here are the tools which are recommended by PC experts to fix search redirect problem:
Use Intel Software Partner, RegInOut and Use Combofix Tool.You shall run RegInOut scan before and after this process if Google redirects virus in your browser.
on Jul 13, 2010 | Computers & Internet
Windows takes a longer time before it resumes
Its time to tune-up your laptop through following these tips given below:-
' Disinfect your system using some reliable antivirus program.
' Run disk clean up (start > programs > accessories > system tools > disk cleanup.)
' Disable background services.
' Fix OS registry errors with properly with PCFresher.
' Defragment the registry if needed.
' Uninstall all programs & software's and download latest versions of them.
Thanks
Oct 31, 2013 | Acer Aspire 5742Z6682 Notebook
Hi, My laptop taking so much time to switch on and it became very slow. Please tell me the soluiton for it.
Sometimes slow booting of computers and Laptops are caused by viruses and spywares. Also, a High temperatured Processor makes a computer slow.
Here are some solutions you might want to try.
  1. If you have a installed antivirus in your computer, i suggest you update your Antivirus and then Start scanning your computer for possible viruses and spywares.
  2. If viruses and Spywares are not the problem, maybe your Processor is feeling to much heat. I suggest you use Laptop Coolers like this one. heifentrixx_11.jpg
  3. This will help you cool down you Processor and Laptop.
Hope my solution will help. Thanks for using Fixya!
Jul 08, 2011 | Toshiba Satellite Pro L300 Notebook
Dear Sir, I removed WinDVD 9 from my notebook. The Windows installer is running there. I can't install any software and even can't turn off my machine. Then I tried to install WinVD 9 again. After a...
Yes it is possible to change from WinXP pro to Vista Ultimate, you will need to get a Genuine Vista Product and then follow the instructions, you will need to first remove all the programs or data you need so you can format the Laptop and then its clean and ready for something new. About the WinDVD 9 and other related errors am guessing you never used uninstaller (Recommended Uninstaller), there are programs meant to wipe clean your machine leaving no part behind if you are to uninstall a program, because if its an incomplete uninstall your machine will have problems as the registry will be messed up and corrupted leading to other fatal problems. After such incidences you will need a registry cleaner (Recommended Registry Repair Pro) to clean the mess and enable fixing all the problems you machine is facing because other means would be more technical.
Apr 13, 2011 | Sony Computers & Internet
My laptop keeps freezing no matter what i do...and i thought it was a software problem but they went in and scanned, deleted, replaced everything and the problem still exist
freezing cna be because of registry and suspicious programs that are running at the back end, close all suspicious programs from task manager, clean ur registry using reginout clenaer it will fix it
Oct 04, 2010 | Toshiba Satellite A135-S2276 Notebook
Runs for about 5mins and screen goes grey
Uninstall unwanted Programs: Unwanted programs installed oncomputer may cause Slow Windows XP issue on your computer. The best way to fixthis problem is to remove unwanted programs from your computer. Here are steps: 1. Click on Start button on thetaskbar.
2. Click on Control Panel.
3. Double click on Add or Remove Programs.
4. Select the application which is not in use.
5. Click on Remove button.
6. Follow simple instructions.
7. You are done. b> Update drivers: Outdated drivers often result inslow performance of PC. What happens is that duplicate keys are created whenprograms are updated or reinstalled. It is always good for your computer tokeep your device drivers updated. b> Why Windows XP Lags? Cluttered or fragmented registry isroot cause behind Slow Windows XP . When registry is cluttered the XP wouldresult in poor program executions, freezing during load time and it alsodecreases overall PC performance. Damaged entries in registry also cause Javascript errors, Windows errors and blue screen errors which are extremelyharmful. b> How to clean your registry?: The best way to clean your registryis to download and utilize a good registry cleaner. This software will scanyour registry for errors, corrupt keys and links, duplicate and unneeded files,and it will fix and eliminate what you need, all at the click of a button. Agood registry cleaner such as RegInOut will also defragment and organize yourregistry, recover lost keys, and perform regular scheduled scans to keep yourregistry into shape.
May 15, 2010 | Acer TravelMate 2355 Notebook
My Laptop is suddenly taking 15 minutes to load up after turning
clean the pc up to speed it up a little, download ccleaner and install it, run the cleaner and delete all the files it finds, then clean the registry and fix the issues found, if it asks you to save the changes to the registry click yes and fix do this a couple of times so no issues are found.
If the pc is still slow after this clean then the issue is either memory or the operating system is degrading.
http://www.filehippo.com/download_ccleaner/
good luck
Jan 26, 2009 | Acer Aspire 5100 Notebook
Open Questions:
Computers & Internet Logo
97 people viewed this question
David Payne
David Payne
