My HP Photosmart C8180 All in one Printer will not print Envelopes for my Hallmark Card Studio 2010 Deluxe.Everthing is set right on the printer, it just will not work. Is there a cheap printer that will work with this program.
  • Anonymous Mar 21, 2014
    will not print Hallmark card studio card second side
That printer will only do No.10 envelopes
Posted on Jan 02, 2011
I wish to use my HP Photosmart C8180 to print heavy weight cardstock... is there a setting that I can select to do this?
Step Three: Check the paper type Verify that only recommended paper is being used for printing. The recommended paper types and weights for most HP printers include:
  • Plain paper, 20 to 24 lb (75 to 90 gsm)
  • Legal size paper, 20 to 24 lb (75 to 90 gsm)
  • Card stock, up to a maximum of 110 lb (200 gsm)
  • Envelopes, 20 to 24 lb (75 to 90 gsm)
  • Photo paper, 145 lb (236 gsm)
NOTE: Supported paper weights and types vary by product. Check the Specifications sheet for your product for more information.
If you use card stock up to a maximum of 110lb then there should be no special mode to enter to print on this type of paper. Photo paper weighs in at 145 lb maximum which is heavier and can be printed on without selecting any special 'mode.'
Good luck on printing on heavy card stock.
Jan 21, 2011 | HP Photosmart C8180 InkJet Printer
Printer will not print onto Avery Clear Label paper
click START.,go to PRINTERS N FAXES n click it.,the window with list of printers on ur pc will open.selest ur printer icon n rightclick it.then click the PROPERTIES option.then click PRINTING PREFERENCES,u will find a PAPER SETUP or PAPER option.click it n select the type of paper as per ur requirement.apply the settings n carry on printing hassle free.thanks.
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
Jun 27, 2008 | HP Photosmart 2610 All-In-One InkJet...
APPCRASH WHEN TRYING TO PRINT 2010 DELUXE
I have thte same problem when trying to print. The way I get around this is by saving the card in Adobe Acrobat and then printing from there. Works but is a pain to do.
Apr 12, 2010 | Hallmark Card Studio 2009 Deluxe Full...
HP C8180 default settings
just go to control panel printers and faxes right click on the printer and from there you can change all the default settings. Here is a tip I wrote that may help you.
http://www.fixya.com/support/r3954871-save_money_using_less_ink_when_printing
Thank you,
lee
Apr 01, 2010 | HP Photosmart C8180 InkJet Printer
Unable to use Hallmark Card Studio Deluxe 2010
I'm having the exact same problem. I too have spyware doctor. Have you had any fixes?
Mar 07, 2010 | Hallmark Card Studio 2009 Deluxe Full...
Will hallmark card studio 8 work on windows 7
you are going to run on windows 7 since hallmark card studio 8 needs systems configuration such as Windows XP or Vista, Pentium III 500 MHz, 600MB of hard disk space, 2GB for full install,16-bit color, and color printer.
So have fine work!
Dec 21, 2009 | Creative Home Hallmark Card Studio Deluxe...
Will not configure for two sided card printing
What printer are you using? Many printers cannot print two-sided or duplex printing. If your printer cannot handle duplex printing, you'll need to do what's called "manual" duplex. Print one page then reinsert the paper and print the second page. Test this on cheap paper first to determine if you need to insert the paper printed side up and which way (if any) you'll need to roate the page.
Sep 13, 2009 | Hallmark Card Studio 2009 Deluxe Full...
Card Pictures will not print
Change the Printer's Spool Settings.
  • Go to START - SETTINGS - PRINTERS.
  • Right Click on the PRINTER and choose PROPERTIES.
  • Under Printer Properties, select the DETAILS tab and click on the SPOOL SETTINGS button.
  • Change "SPOOL DATA FORMAT" from EMF to RAW (it may already be on this setting.)
  • Click on PRINT DIRECTLY TO PRINTER. Then click on OK.
  • Now Select the GRAPHICS or COLOR tab. If there is an option for RASTER mode, select this mode. Then lower the DPI setting and click on OK.
  • Also, make sure that the Print Mode is set to NORMAL and not Best.
  • Close the Printer Properties window by clicking on OK.
    3. Now set the printer as a default Printer. Right click on the PRINTER icon in the Printers Window and select "SET AS DEFAULT" to place a check mark by this option.
    Please try printing and let me know if that fixes it.
  • Apr 02, 2009 | Creative Home Hallmark Card Studio Deluxe...
    Printer Error When Printing Envelopes
    I had the same problem with my 7260 and I finally changed the paper type from automatic to plain paper. Go to either Properties or Preferences in your printer set up window. Somehow this turns off some sort of sensor. It might work for you, too. To the person who is using the Hallmark program, that is where I first encountered the problem, I then tried to print an envelope from Word and the same error message came up. I found this solution online from someone using a three in one printer/fax/copier so I tried it and it worked for me, too! I hope this helps......
    Nov 04, 2007 | HP Photosmart 8250 InkJet Printer
    135 people viewed this question
    k24674
