Question about Element Electronics Zr-Element Digital Media Player
What is the hold thing for? - Element Electronics Zr-Element Digital Media Player
  • 44 Answers
HOLD button is used to prevent accidental pressing of the MP3 player keys.
Posted on Sep 03, 2010
    President:
  • 1,932 Answers
This function prevent you from unknowingly pressing some keys/touch pad.So you can peacefully listen to songs
Thank You
UNABLE TO CONNECT TO INTERNET
Simple things you can do: reset tablet, hold home and power down for 30 seconds. Reset Modem/Router same thing hold power down for 30 seconds. Test the internet with another device if it is down could be provider issue.
Mar 07, 2016 | Tablets & eReaders
When im on browser everthing large and i pressed something on accident on setting while i was on internet and it wont go back to norman please help
If you mean you pressed something and everything you see now is LARGER... I've done that often. Easy fix.... hold down the "CONTROL" or "CTRL" as is is on my computer.... and while holding it down... hit the - (minus key one time). If still to big hit the key again while still holding down the ctrl key. The same can be accomplished to make things larger.... by doing the same thing.... (holding down the control key (ctrl) and hitting the + key one time. (or two times to make it smaller. Hope this fixes the problem.
Jan 27, 2015 | Computers & Internet
Stuck on loading, won't go pass loading even after resetting
First thing to do is try a soft reset. Hold volume up button and whilst holding it, hold power on button till it boots up. Really hope this works for you.
Mar 22, 2014 | Ematic 4GB EM63 7" HD Dual-Core...
I have ( WGR614v7 ) wireless router.1st thing i got the problem with internet connection....2nd thing is I've mistakenly change WAN IP...now i got huge problem. i couldn't inter the setup wizard . so...
Best way is do a factory reset.Press and hold reset button during this procedure ,do not release the button until you are finished and you will be back to factory default.
1)Hold button 30 sec.
2)remove power cord hold 30 sec.
3)plug in power cord 30 sec.
You should now be in default factory mode,good to go.
Oct 26, 2013 | NetGear WGR614 Wireless Router
Medion mdjuke 220
ive seen a lot of people seem to ask this question. i found out how to use my mp4 by my self because i didn't get an instruction booklet.
you do the same thing you do to change both of them. as you know, unlike how you would normally scroll down, you need to do it with the side buttons on these. unless i have a different model which i doubt if you have a blue one.
you go to "settings" at the bottom and go "time and date". select one of them. you use the side buttons to change the number and them you hold the middle button for a while to go to the next section. and press the bottom play button to save it. and do the same for the other thing. (out of "time" or "date")a lot of things involve needing to hold down the middle button. like for the music settings while music is playing you hold it and it comes up with all these things like equaliser speed e.t.c.
Jul 05, 2013 | Audio Players & Recorders
Wild thing chain saw chain came off
The drive links are burred.
512b519.jpg Use a file on the flats of the drive links to remove all burrs.
Then install and properly tension the chain
Chain Adjustment
  1. Make sure the chain brake is off (gloves will protest your fingers).
  2. If necessary, loosen the bar nuts that are clamping the clutch cover in place (or whatever holds the clutch cover and bar on). They do not need these really loose - finger tight will do.
  3. Ease the tension adjustment until the chain is obviously loose.
  4. Using one hand, hold the nose of the bar up.
  5. While holding the nose up, adjust the tensioner so that the center of the chain just touches the underside of the bar, add a touch more.
  6. Continue holding the nose of the bar up & tighten up the bar nuts / bolts / quick-release system. HTH
Lou
Dec 02, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My ipod is locked.cant find the reason why.
First thing to try is a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
If that doens't solve the problem try this
http://www.fixya.com/support/r977231-disabled_or_code_forgotten
Nov 28, 2008 | Apple iPod mini M9160LL/A MP3 Player
Tail Light Housing Removal on '02 S-10/Blazer...
It won't hurt trying to remove these screws. Or the interior panel if you have too. that's what I would do.
Nov 22, 2008 | 2002 Chevrolet Blazer
Element Electronics Zr-Element  Digital Media Player Logo
42 people viewed this question
Top Element Electronics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Are you an Element Electronics Audio Player and Recorder Expert? Answer questions, earn points and help others
