Question about AOC LM 700 (White) 15" LCD Monitor
I am working on a aoc lm-700 .The original problem appeared to be the vga cable. It would flicker and black out when the end of the cable was wiggled. I couldn't find another cable with the inline connector so I made up one . By some miracle I got a picture . There is some differences in the new cable,the grounds for the R,G &B video are separate on one and common on the other.. When I turned it on and got a pic, there was in the background , a what looks like interference on the old analog TV's (fine horizontal lines that roll randomly up and down the screen. I also still have some flickering and light and dark er bars appear momentarily at random without regard to tapping on the unit or the pcb.They are dim and do not affect the imagemuch, but are annoying. I still suspect my improvised cable. Where can I get an exact replacement.(male vga plug on one end, and inline plug on the other that plugs into the pcb?.
2 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: (external monitor AOC LM765 flickers white
Hook up that monitor to another laptop or computer. If it works then its an issue with the vga port on your laptop. If the monitor still shows those lines then you know for sure the monitor is bad and it will have to be replaced.
Posted on May 15, 2011
Hi i am looking for vga cable 9 Pin Female to 15 Pin Female thanks
The 9-pin port on your PC tower is NOT a video port, it is a serial data port. All VGA connectors are 15-pin. Hooking up to the 9-pin port will not get you a picture. There should be a VGA port on the PC, or else a DVI an/or HDMI port. You can get DVI-to-VGA adapters that work, but only if the DVI port is an analog DVI, not if it is a digital DVI (DVI-D or DVI-DD).
Feb 02, 2016 | LG Computers & Internet
AOC 2036S won't connect to laptop
Is the cable working? try reducing your laptop screen resolution and connect to your monitor. Your monitor may not support full hd resolutions....
Jan 09, 2014 | AOC 2036S 20 INCH BLK LCD MONITOR
Desktop computer monitor goes black but works on other computers
It sounds like the resolution is set wrong. Go to the minimum and see if that solves the problem. If so keep working up.
Nov 25, 2012 | AOC V22 22" Monitor
I am trying to connect and use my monitor as a tv moniter how do i do that
The only way possible i believe that that model aoc. is to use what we call a break out cable, this is a cable used to attach vga on one end and component or rca on the other end, the only issue is that the aoc 912sw has no audio outputs so what ever source you wanted to use to push the image on your tv must also have audio and external speakers must be used. here is a link to a breakout cable break out
May 29, 2011 | AOC 912SW-1 Monitor
(external monitor AOC LM765 flickers white lines) My laptop screen is damaged. I plugged an external monitor (AOC LM765 via RGB), works fine for the past three days but suddenly ghostly lines appear. Any...
May 15, 2011 | AOC LM765 (Silver) 17" LCD Monitor
Monitor flashes the "AOC Eyes Value" logo without evr turning on
Man that really hurts.
Flashing logo of company on monitor screen means your monitor has power but not receiving data. Have to find a way to fix data, may be data cable ( vga cable ) of booting of computer itself
Try few things not sure solve your problem or not but really doesnt hurt to try
First, It looks you have loose VGA cabling. Try removing VGA cable completely and connect again
Link how VGA cable looks like
http://files.sandberg.it/products/images/lg/501-93_lg.jpg
Second, if above doesnt solve the problem, may be your VGA card has problem or your CPU is not booting up. Feel the breeze of fan on SMPS to see if it is working or not.
Hope this helps
May 20, 2010 | AOC 193FW LCD Monitor
When I turn on my MAc G4 my 19'' AOC Monitor turns on but then says ''No signal going to sleep''
When you are turn on the power supply going through cable is remain good but somewhere it is found in monitor that cable is broken,then it might be problem of monitor.
Oct 31, 2009 | AOC LM929 (Black) 19" LCD Monitor
AOC LCD MONITOR TROUBLE SHOOTING
it is screen resolution issue.
For that when you power up the computer press F8 key then enter in enable vga mode then go to control panel -> display ->settings->screen resolution to 1024*768 .
Jul 27, 2009 | AOC LM 520A 15" LCD Monitor
AOC LM700 17" LCD Screen switches to black and then comes back to normal. Power light never goes green but monitor works. LED is orange when off and in sleep mode, wakes correctly on getting input. Just...
According to LCDParts, an inverter for an AOC LM700 would cost $69.99. Specs (with picture) are available here.
Perhaps you can do a Google for lesser priced versions.
Good luck and kind regards.
Feb 08, 2008 | AOC LM 720 17" Flat Panel LCD Monitor
AOC LM 700 (White) 15" LCD Monitor Logo
48 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
