Question about Hotpoint Ovens
Hotpoint gas range RGB746HED2WH: Oven not maintaining temp. Sometimes reaches pre-set, but rarely maintains temperature. Works fine on the CLEAN cycle (only way to bake bread now!). Broiler gas ignites after less than 1 minute. Oven gas is anywhere from 1 minute to 4 minutes before ignition.
mastatech
  • 478 Answers
SOURCE: GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Posted on Mar 14, 2009
SolutionGuy
  • 331 Answers
SOURCE: GE JKP26G Electric Oven Doesn't Maintain Temperature
Diagnosis= failed thermister (temp probe inside the oven cavity) The part number is WB23X5340 and it lists for ~$72.00 at your local appliance parts place.
Bad news is that you have to pull the oven out of the wall to do this repair.
Good news is that it's not difficult to do.
TURN THE POWER OFF AT THE BREAKER BEFORE YOU PROCEED! Otherwise you'd look like this...
Ready? OK!
All you need is;
1.) Phillips screwdriver
2.) 1/4" socket/nutdriver
3.) Ratchet if you don't have a nut driver
4.) 36 quart Igloo ice cooler (like what you'd take to the lake or the beach)
5.) Sturdy wire (smaller than a coat hanger, preferably)
6.) Flashlight
Did I mention TURN THE POWER OFF AT THE BREAKER BOX?
Now we're ready for surgery.
Open the oven door and look where the oven meets the wood. You'll see a couple of screws there... remove them. Now the oven is ready to pull.
Place your Igloo cooler under the oven. Slowly pull the oven from the cavity until you have it out and sitting on the cooler. (don't sweat it... the oven is light. maybe 75 pounds or so.)
Now that you have it out, open the oven door and remove the oven racks. Look inside (may need a flashlight) and locate the temp probe, there are 2 screws holding it in place. Remove those 2 screws and set them inside the oven cavity, you'll need them soon.
Now go to the back of the oven (slide it if necessary) and remove the back panel. (*Here's a tip... some of these GE units? All you have to do is remove one screw to access the temp probe, so look carefully... don't go nuts here. Sometimes the whole panel/panels DON'T have to come off)
You'll see the temp probe wires... they are 2 small white thermally insulated wires coming from the cavity to the wire harness in the back. Disconnect this harness and pull the old probe out from the front of the oven cavity.
OK... now to get the new probe installed... See that plastic thing on the end of the new probe? It's a pain to get through the cavity where you'll be plugging it into. It's best to have help. but it can be done alone (I've never had help, it's just harder)
Take the sturdy wire (from the tools list) and make a small hook at the end of it. Poke it through the hole that the old probe was stuck through. Now hook your new probe into the hook. Now go to the rear of the oven and gently (did I say gently?) pull it through to the back of the oven.
Now that you have it through, connect it to the harness. Now all you have to do is reinstall the rear panel/s and the oven. No biggy. Just take care not to scratch your wood trim... line it up before lifting and installing.
All in all about an hour's worth of work. I know it sounds like alot more but I could have done this in less time than it took me to type it.
Congrat's on your first major oven fix! Let us know how it turned out.
Posted on Mar 17, 2009
  • 126 Answers
SOURCE: maytag gas oven wont restart after pre heat
you have a bad oven sensor /faulty connection or bad control board.look for probe coming thru inside rear wall.should read 11k ohms cold.go bad a lot part number Hope this helps ,please rate my response :)
12001655
Posted on Jun 25, 2009
SOURCE: My Frigidaire es300 gas range
To Set or Change the Temperature for Baking
The oven can be programmed to bake at any temperature from 170°F to 550°F (77°C to 287°C).
To Set the Controls for Baking:
1. Press "Bake" key. "— — —" appears in the display.
2. Within 5 seconds, press the up or down arrow . The display will show "350°F (177°C)." By pressing and holding the up or down arrow, the temperature can then be adjusted in 5°F increments (1°C if the control is set to display Celsius).
3. As soon as the up or down arrow pad is released, the oven will begin heating to the selected temperature. When the
displayed temperature reaches the desired baking temperature, the preheat indicator light will turn OFF and the control
will beep 3 times.
4. To cancel baking, press "Clear/Off".
To Change the Oven Temperature after Baking has Started:
1. Press and make sure the bake temperature is displayed.
2. Press the or pad to increase or decrease the set temperature.
To Set Control for Continuous Bake or 12 Hour Energy Saving
The oven control has a built-in 12 Hour Energy Saving feature that will shut off the oven if the control is left on for more than
11 hours and 59 minutes. The oven can be programmed to override this feature for continuous baking.
To set control for continuous baking:
1. Press and hold "Timer On/Off" down for 5 seconds until tone is heard, " — — hr" will appear in display for continuous cooking.
The current time of day will return to the display.
2. To cancel the Continuous Bake function, press "Timer On/Off" and hold for 5 seconds until tone is heard. "12hr" will appear in
display indicating that the control has returned to the 12 Hour Energy Saving feature.
Posted on Jan 25, 2010
SOURCE: top oven bake igniter comes on, but gas does not.
If the bake ignitor comes on (starts glowing) - check the amperage on the bake ignitor wires when it's on. If the ignitor is a round style - amperage should be 2.5-3A, if the ignitor is rectangular - 3 - 3.6A. If less than 2.5A or 3A respectively - replace ignitor. If the ignitor does not come on - check the voltage on the ignitor, should be the line voltage 110-120v AC. Faulty gas valve is uncommon, but still a small possibility. Ignitor part numbers for round style ones: 4342528, WB2X9154, SGR403, 5304401265;
rectangular styles: 12400035, WB13K21, WB2X9998, SGR412, NR020, 5303935066, 814269, 9753108.
Ignitors of the same shape (i.e. rectangular) are interchangeable, if you can splice the wires.
Posted on Jul 15, 2010
I have a Kenmore Elite oven. The upper oven doesn't maintain temp setting. Eg, if I set baking temp at 375, oven may get to that temp but a few minutes later, it's at 325 or less. Broiler works fine.
im taking that it,s gas....do you smell gas at anytime? sounds like you migh have a light gas leak if it,s gas...also how old is this oven?
Aug 13, 2016 | Kenmore Ovens
Ge gas oven jgbp28dej3ct.. oven pre heats good to right temp but wont maintain temp during cooking.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jul 29, 2011 | GE 30 In Freestanding Gas Range ...
I have an SL100 - 10W La Germania table top oven (gas) I did not receive a operations manual with purchase of the oven and I do not understand its operation. Questions 1. How does it maintain the set...
I GOT THE SAME QUESTION .. IT IS A GAS OVEN . WHEN THERMOSTAT IS SET TO GAS MARK 4 WHICH IS EQUIVALENT TO 350 DEGREES , AFTER 10 MINUTES, IT REACHES ITS DESIRED TEMP. BUT IF I DON'T ADJUST THE FLAME, THE TEMP WILL RISE HIGHER AND HOTTER THAT I NEED TO OPEN THE OVEN DOOR TO DECREASE THE TEMPERATURE INSIDE. ANYONE KNOWS IF THAT IS NORMAL? THANKS12_1_2012_3_54_19_am.jpg
Oct 26, 2010 | Ovens
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
Oven sometimes doesn't heat up. Sometimes heats up to desired temp, then quits working. Sometimes doesn't even heat up at all. When preheated light comes on, thermometer in oven usually says about 100...
This sounds like a weak igniter, it would have to be a gas oven and the symtoms usually are: takes longer than normal to ignite the burner, may or may not smell gas in the oven, does not maintain set temperature, eventually won't heat at all. On gas ovens, a glo igniter is like a light bulb, the more you cook, the faster it wears out. Bottom line, needs to be replaced. Good luck.
Jan 14, 2010 | Amana Ovens
Mar 14, 2009 | Ovens
Gas oven won't maintain temp. It turns off after reaching temperature set.
Hi ya mate sorry to hear your having problems with you oven,
The problem wiht your oven seems to ba a faliure of the fsd/ffd, it seems to me that this device is not completey gone but is faulty.
This device is used as a safety feature on gas ovens and is there to turn the gas off to the oven when the flame has failed.
The way it works is that the intial small flame heats up the the phile at the end of the cappliary tube which is connected to a valave which realses the gas to the oven..
what you need is to have it change
hope this helps
washdoctor
cheers
Aug 28, 2008 | Ovens
Ovens Logo
167 people viewed this question
Top Hotpoint Ovens Experts
Jason Harris
Jason Harris
ashburton
 Fix Your Board
Fix Your Board
Are you a Hotpoint Oven Expert? Answer questions, earn points and help others
