Question about A4tech PK5
My webcam i cannot get my webcam to work. When I click my YM to activate webcam, the message is "the server is busy". I dont know how to fix this. I have a A4tech viewcam pro.
    President:
  • 8,637 Answers
Normal 0 This ptogram will eliminate your problem of the camera being busy or being used by another program. Really works great.
Double click on this site http://download.cnet.com/SplitCam/3000-2348_4-10500269.html
And then click on Download Now (3.5MB)
  1. Install Splitcam saying yes to everything during installation including the any warnings.
    2. Then run the Splitcam program by double clicking the downloaded program.
    3. Clicked on "Video" at the bottom right of the program window and selected your cmera.
Note: This will result in your camera being switched on and viewable in the
SplitCam program.
4. Opened up Skype (or other messengers) and go to "Tools" then "Options" then "Video settings."
5. Also setup your “Audio” while you are there.
6. Selected "SplitCam Capture" as my webcam, then click on save.
7. Webcam image will appeared in Skype or what ever messenger you are using.
Hope this Helps. Bud
Posted on Apr 22, 2009
Im using yahoo messenger version 11 .i cant sign in anymore .. other website like facebook n search are okay except in yahoo ..what are solution of this problem..pls help
i got the same problem with my ym 11 too.. but honestly looks like its ym problem that it may just work whenever it want to.. :( but try this.. open Yahoo Messenger click on "Messenger" (on top), choose "Connection Preferences" select "Connect via Proxy Server" try to log in ..
if it doesn't work put it back to the original settings, same instruction go to YM, click Messenger then Connection Preferences select "Connect directly to the Internet".. this time try to disconnect your internet connection first.. and then with your YM open enter your username & password but dont click "connect" yet.. connect to internet & log in to ym (you should click "connect on ym right after a second you are connected to the internet)
Sep 10, 2011 | Yahoo Messenger
Dont know how to activate the webcam
The web cam works when you are online in YM or some other chat room. Look to the top of the YM when in chat mood. You will see "Invite to Web Cam" click on this and your cam should automaticly open
Apr 06, 2011 | Compaq Presario PCCOM2232US Notebook
My webcam cannot broadcast. Everytime I activate it, I get the message ''The server is busy. Close the window and try again later.''
I haven't seen that message since I was on dial-up connection, using msn and yahoo messenger - so I think you have a resource problem and operating below the bandwidth for webcam broadcasts.
Since upgrading to broadband 3 years ago its been OK.
Jan 19, 2010 | A4tech PK5
Problem on cam
I used to get this when I was on dial-up but never since going broadband - so the bandwidth may be fragile.
You need to interrogate what is happening when the webcam is transmitting by opening the webcam menu on the webcam frame and click "statistics" Its best to transmit the "small" image and use the zoom 200% when established ( same as sending large photos by email ) - if I go for speed rather than quality on the slider I can achieve 5-6 frames per second ( small size) but I normally transmit about 1-2 f/s.
I have my webcam under VFW (video for windows) control as I used to get freeze problems. This involves a registry change - detailed in Messenger help
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstacamfix.html
You can tell when its under VFW control because VFW will be on the bottom of the Statistics box. You may need a little bit of software to make it work, if like me you do not have Directx on your pc - if so download the software featured here.
http://help.yahoo.com/l/us/yahoo/messenger/messenger9/webcam/mstatestcamie.html
Dont worry about using the proxy server in "Connections" - Use it when you have to - I had to use it today to make my my webcam work - I also had to increase my virtual memory but that was as a result of error messages
Aug 12, 2009 | Labtec 961307-0914 Webcam
"SERVER IS BUSY, TRY AGAIN IN A FEW MINUTES" Broadcasting problem
theres no problem in your webcam but definitely you have a problem in your messenger. try re installing the messenger, will surely work.
Jul 15, 2009 | Labtec 961307-0914 Webcam
Webcam doesn't work with yahoo messenger
There is a simple solution to this kind of issue but I can't figure why. Here it is:
If you are using YM and having issue with webcam, try this:
open up a new account with YM then try access your webcam in the YM Setup. Let me know if this works.
May 06, 2009 | Computers & Internet
A Plug and Play Webcam wont work on Yahoo Messenger
in your YM.. open the Messenger tool bar.. then.. My Web cam.. then.. .Preferences.. then Camera source... and select the installed webcam.. and see how it works..
Jan 13, 2009 | Yahoo Messenger
Yahoo messenger keep loging me off
after logging in ym, do you go to chatrooms? there are so-called yahoo booters that boots your ym when you join a certain chatroom.
Make sure messenger is off, then go to regedit then open up HKEY CURRENT USER then open up SOFTWARE then open up MICROSOFT then open up WINDOWS then open up CURRENT VERSION then click on Internet Settings but dont open it just click on it then go half way down the list to find PROXY ENABLE,PROXY SERVER,PROXY OVERRIDE then click on PROXY ENABLE click modify binary and change from 0x00000000 (1) to 0x00000000 (0) then delete PROXY SERVER and PROXY OVERRIDE and there you go sign into messenger this has worked perfect for me hope it does for you.
or
It's either one of the two:
- Yahoo! servers are down for maintenance, the only fix would be to wait.
- Your connection preferences are wrong:
Messenger tab just above where you sign in and then click the Connection Preference option
Oct 18, 2008 | Yahoo Messenger
Why my webcam dont work?
i have a logitech webcam. it doesnt work. I can see myself and i can see my "cousin" on her webcam. But she can't see me. Whats wrong??? She says that on her computer it says that my webcam is not connected. but it is!!!!
Jul 01, 2008 | Computers & Internet
Webcam not connecting to yahoo messenger
!st, let me explain the problem more clearer, then I'll explain the solution.
Problem) My camera worked fine. Even when logging on to Yahoo messenger, i could still veiw myself when chatting. But when I clicked on the "broadcast" button, the "idle" status would change to "connecting" for a few seconds. Then the the following message would pop up, " The server is busy, Please close this window & try again in a few minutes".
Solution) In Yahoo messenger, click on "Messenger", scroll down & click on "preferences". In Category:, click on "connection". Make sure that "no proxies" is selected.
Jul 01, 2008 | Labtec 961307-0914 Webcam
A4tech PK5 Logo
138 people viewed this question
Top A4tech Computers & Internet Experts
micky dee
Tony
Are you an A4tech Computer and Internet Expert? Answer questions, earn points and help others
